Topic: Playback Statistics won't work.  (Read 980 times) previous topic - next topic
Hi Everyone,
I upgraded to Windows 10 on my Dell Latitude 3440, and now the PLAYCOUNT column stays blank. Here's the list of my installed components:
[codebox]Core (2015-11-02 13:34:32 UTC)
    foobar2000 core 1.3.9
foo_albumlist.dll (2015-11-02 13:31:02 UTC)
    Album List 4.5
foo_cdda.dll (2015-11-02 13:30:24 UTC)
    CD Audio Decoder 3.0
foo_converter.dll (2015-11-02 13:30:32 UTC)
    Converter 1.5
foo_dsp_eq.dll (2015-11-02 13:30:52 UTC)
    Equalizer 1.0
foo_dsp_std.dll (2015-11-02 13:30:38 UTC)
    Standard DSP Array 1.3.1
foo_fileops.dll (2015-11-02 13:30:04 UTC)
    File Operations 2.2.1
foo_freedb2.dll (2015-11-02 13:30:14 UTC)
    Online Tagger 0.7
foo_input_shorten.dll (2016-01-19 16:14:04 UTC)
    Shorten decoder 0.4.2.3
foo_input_std.dll (2015-11-02 13:34:32 UTC)
    Standard Input Array 1.0
foo_playcount.dll (2016-01-19 16:13:56 UTC)
    Playback Statistics 3.0.2
foo_rgscan.dll (2015-11-02 13:31:02 UTC)
    ReplayGain Scanner 2.2.2
foo_ui_columns.dll (2011-02-27 20:22:58 UTC)
    Columns UI 0.3.8.8
foo_ui_std.dll (2015-11-02 13:34:32 UTC)
    Default User Interface 0.9.5
foo_unpack.dll (2015-11-02 13:30:38 UTC)
    ZIP/GZIP/RAR Reader 1.7.1[/codebox]
The troubleshooter says none of these are problematic. I checked component updates, and none are available.  This is my main layout:
And here is the column layout:
I've tried entering PLAYCOUNT, PLAY_COUNT and %PLAY_COUNT% without any luck.
Suggestions?
Re: Playback Statistics won't work.
Switch to 'Scripts' tab instead of 'Options' on the right side and input %play_count% there.
