Topic: unrecoverable playback error: Unknown error code (0x8888001) (Read 1115 times) previous topic - next topic
Has anyone else ever seen this message?  I have a new installation of V1.4.8 on a HP laptop, 64 bit, Windows 10 Pro, and have not been able to play anything.
Re: unrecoverable playback error: Unknown error code (0x8888001)
Hi there,
Firstly try a Windows restart and see if that fixes it.
Otherwise you could try the advice in this thread. That is, check that the sound card output is set correctly in Windows sound device properties. (Start > Settings cog > System > Sound > Output device properties > Additional device properties > Advanced tab > set Default Format to the minimum)
Set foobar to the same Output device, or 'DS: Primary Sound Driver'. (Preferences > Playback > Output > Device)
Cheers
anamorphic,
Thank you very much.   Your suggestions have worked for me.   Now, I can finally use the program.
