Topic: autoplaylist sorting question (Read 3467 times) previous topic - next topic
sorry it's maybe stupid but can somebody help me with finding a sorting method.
I would like the tracks to be sorted in the autoplaylist on rating and within the rating on playcount so you got something like:
5 stars=> all the songs with 5 stars and then the songs that are played the most till the songs with 5 stars that aren't played a lot
etc. with all the other ratings
Sorry if I'm not clear but my english isn't great so I hope you will forgive me for that...
If you don't understand it just ask than I will try to say it on a other way.
thanks in advance and greets
I'm using Foobar with the autoplaylist and custom info plugin.
My current sorting method is this $sub(999999,%rating%), but I would like something that first sorts on rating and then sorts the same way on playcount.
thanks
Try:
$sub(99,%rating%)-$num(%playcount%,10)
thanks for the reply but this doesn't work, the rating sorting is good but it doesn't sort the most played first.
I don't use ether of the playcount plug-ins so I was just guessing  , use whatever you use to display the playcount in playlist/trackinfo/etc.. If that doesn't work it might be a bug, check the appropriate playcount plug-in thread.
Try this if you use official playcount:
$sub(5,%rating%)$sub(9999,%play_count%)
Or this if you use the unofficial playcount:
$sub(5,%rating%)$sub(9999,%play_counter%)
They should work (if your ratings are from 0-5)..
thanks these work
sorry for the n00b question, but i cant see where to put this code.. help?
you have to have the autoplaylist plugin.
when you have it you got to put it in sort format...
i have autoplaylist manager 1.0 listed in my components.. is this what you mean? i dont see any config options for it in prefs.. where do i look?
you have to look in your menu in library not in preferences
oh ok my problem that got me confused is that if i leave the query box empty i get 'invalid filter string'... but what do i query if i just want to listsort my enitre music directory?
[edit: seems to work if i just put: .]
