I was wondering, is there some software that automatically removes noise in real-time? Say, I connect my CB Radio to line-in, start an application and get rid of the background white noise Or maybe the big audio editor suites can do that in real-time too, like Adobe Audition (I really liked its Adaptive Noise Reduction effect)?
Thanks in advance
Thanks in advance
I'm not sure you'd be able to get good noise reduction in real-time without latency issues. Noise reduction software typically looks at big chunks of samples, say 4096 (or more), at a time, so there is 4096 samples of latency (around 1/10th of a second with a 44.1kHz sampling rate.)
Such latency would be negligible with my use in mind...
I have just discoverd this Noise Reduction plug-in (http://www.savioursofsoul.de/Christian/vst-plugins/effect-plugins/#NoiseReduction). It looks like it is exactly what you are looking for.
You could use it with any VST hosting application. or you could use in a simple VST host like VSTHost (http://www.hermannseib.com/english/vsthost.htm).
http://www.digidesign.com/index.cfm?navid=...amp;itemid=1041 (http://www.digidesign.com/index.cfm?navid=115&itemid=1041)
runs also as AU plugin (TDM requires Pro Tools) but is rather expensive
I think Cedar Audio (http://www.cedaraudio.com/) is still the technical leader in this field. I played with DNS3000 real-time noise suppressor at the AES show this fall. Magic audio shit (in a good way).
We had a demo of Cedar Audio at work this last spring and it was truly impressive. But with a $30,000+ price tag, impressive should be in the description.
G²
