Topic: foo_dsp_avs, applying Avisynth filters real-time (Read 2883 times) previous topic - next topic
Since ffdshow has its own Avisynth filter to use Avisynth filters in real-time on a video-stream, I was wondering if it's possible to create a foobar dsp-plugin that can do the same for an audio-stream. I've never come across such a filter before, so I take it no such filter yet exists.
I imagine that such a filter would have a config-dialog ("Configure selected" in the Active DSPs column) where you could enter your Avisynth script to apply to the current audio-stream.
Instead of creating an Avisynth script for every audio file or album, such a plugin would save a lot of work.
Album? Yes, FILE "<filename>.avs" WAVE in the album's cue-file, whereas the avs-file contains: BassAudioSource("<filename>.flac"), works fine in foobar (together with foo_input_avs of course).
where is the api for this?
..I mean the functions for processing audio.
I suppose looking at what exports ffdshow calls would yield something i suppose.
none.
