HydrogenAudio
Lossless Audio Compression => WavPack => Topic started by: gism on 2013-08-14 18:43:47
Title: WavPack on 64-bit OS?
Post by: gism on 2013-08-14 18:43:47
My question is can I run the original WavPack 4.60.1 on Windows 7 64 bit?
I have a virtual PC installed where I can run programs that are incompatible with the 64-bit OS, but it's slow and unwieldy.
I'd like to know if it can be used on x64.
Post by: saratoga on 2013-08-14 18:46:15
The codec itself won't care about 32 or 64 bit, but if you want to use any operating system extensions or wmp plugins, they'll need to be 64 bit as well.  Otherwise no, 32 bit programs work fine on 64 bit windows.
Post by: azaqiel on 2013-08-14 18:49:50
the provided binaries are 32 bit, which can run on 64-bit windows 7 (tested this myself).  in the off-chance that you're compiling it yourself, 4.60.1 doesn't have a 64-bit target in Visual Studio (if I remember correctly).  I believe 4.70.0 (beta) does.
Post by: gism on 2013-08-14 18:55:15
My intention is to use it for encoding (.wav)/decoding (.wv). Will it work fine on Windows x64 then?
I'm talking about the program of course: http://www.wavpack.com/ (http://www.wavpack.com/)
Post by: gism on 2013-08-14 18:58:04
I have this version WavPack Win32 (Windows command-line programs and user documentation) 4.60.1: http://www.wavpack.com/downloads.html (http://www.wavpack.com/downloads.html)
Post by: azaqiel on 2013-08-14 19:01:16
short answer: yes.
Post by: gism on 2013-08-14 19:05:17
short answer: yes.
Well, thanks haha. I didn't want to install it without being sure.
Post by: saratoga on 2013-08-14 19:06:52
short answer: yes.
The only things that won't work on 64 bit windows are drivers and OS components that require 32 bit Windows.  If you try to install one of these, it will refuse to install.
Post by: azaqiel on 2013-08-14 19:28:47
to be precise, the OP shouldn't be "installing" anything; there is no setup.exe or the like.  it's just copy the binary and use it.  but outside of this specific case, you're right.
Post by: saratoga on 2013-08-14 19:44:58
Drivers and windows components have to be installed, hence if something isn't compatible with 64 bit you will almost certainly be trying to install it when you discover it doesn't work.
Post by: gism on 2013-08-14 19:46:32
It's a zipped file which contains the following:
wavpack.exe
wvgain.exe
wvselfx.exe
wvunpack.exe
changelog.txt
license.txt
wavpack_doc.html
I'm not familiarized with it but it must work very similar to the official FLAC command-line tools.
Post by: DARcode on 2013-08-16 22:13:39
As mentioned by azaqiel version 4.70.0 beta has got 64-bit binaries here (http://www.hydrogenaudio.org/forums/index.php?s=&showtopic=101073&view=findpost&p=835446), but you'll do fine with the stable 4.60.1 32-bit ones, comprehensive manual at the official website here (http://www.wavpack.com/wavpack_doc.html).
