Topic: Did I install WASAPI Component properly (Read 853 times) previous topic - next topic
I followed the instructions, and it is listed in the "installed components" section, but in the past I had to select it from some output setting somewhere. I don't see that option anywhere.
I just want to make sure I have done everything I need to make it work.
Re: Did I install WASAPI Component properly
You don't need to install any WASAPI component at all. WASAPI shared is built in to v1.6.0+ and native support for exclusive mode was added in v1.6.7. So even if you're avoiding 2.0, you should have it anyway.
See the Preferences here for picking a device with exclusive mode...
https://hydrogenaud.io/index.php/topic,124105.msg1026553.html#msg1026553
Thank you, I knew those settings were somewhere, I forgot about expanding the selections nested in playback.
Any thoughts on Push vs Event? I have an RME ADI2 DAC FS.
I have found that WASAPI (or the default driver for my RME ADI2 DAC fs) doesn't dynamically change the sampling rate, but apparently ASIO does. Is ASIO also integrated into Foobar?
