Topic: Cue Sheet is not working when file is played from FTP server (Read 623 times) previous topic - next topic
I'm using cue sheets with my audio files. They'll work without any problems when I'm playing files from the internal memory or from a SD card.
But the same audio files and cue sheets are not working when I'll ty to play them from my NAS.
I can access the NAS without any problems and can also play the audio file without the cue sheet. I also see the cue sheet and can click on it, but nothing happens when I'll try to start playing my audio file using the cue sheet.
There is no error message and also nothing will be written into the Console log.
So is someone else here that ever tried to play audio files using a cue sheet via FTP or can someone maybe try to do this?
It's also working fine, when I'm playing the same files from FTP in the Foobar PC version and also works when I'm playing it with my Dune HD Mediaplayer.
Anyone an idea why this is not working in the mobile version of Foobar?
Thanks and Regards
Tri
Re: Cue Sheet is not working when file is played from FTP server
Fixed in today's build, thanks for reporting.
Thanks for fixing this.
