Topic: Update tag mapping - WORK, MOVEMENT, etc (Read 1203 times) previous topic - next topic
Please consider below requested foobar2000 tag mapping changes for fields - WORK, MOVEMENT, etc.
***** existing foobar2000 tag mapping (v1.4.1beta2) *****
foobar-frame   {*1}               mp3-frame   {*2}                             m4a-frame   {*3}{*4}                   itunes-field (v12.9.0.167)
GROUPING                           TIT1   {*a}                                        @grp   {*b}                                  Work (name) [mp3], Grouping [m4a]
WORK                                   TXXX.=.WORK                                @wrk   {*c}                                   Work (name) [m4a only]
MOVEMENT                          TXXX.=.MOVEMENT                       @mvn   {*c}                                 (Movement) Name [m4a only]
MOVEMENTNUMBER           TXXX.=.MOVEMENTNUMBER        mean..MOVEMENTNUMBER        [no defined field]
MOVEMENTTOTAL               TXXX.=.MOVEMENTTOTAL             mean..MOVEMENTTOTAL           [no defined field]
SHOWMOVEMENT               TXXX.=.SHOWMOVEMENT            mean..SHOWMOVEMENT           [no defined field]
{*1} master system flac files used foobar2000 converter with FLAC (libFLAC 1.3.2)  [Vorbis Comment]
{*2} user device mp3 files used foobar2000 converter with MP3(LAME) VBR V0 (LAME 3.100)  [same results with ID3v2.3 or ID3v2.4]
{*3} user device m4a files used foobar2000 converter with AAC(Apple) VBR Q64 (qaac 2.64)  [same results for Apple Lossless]
{*4} "mean.." is abbreviated for "mean....com.apple.itunes....name...." in m4a files
{*a} note: foobar2000 v1.3.17 and earlier mapped CONTENT GROUP to TIT1
{*b} note: foobar2000 v1.3.17 and earlier mapped CONTENTGROUP to @grp
{*c} note: foobar2000 v1.3.17 and earlier did not provide mapping to @wrk or @mvn
***** requested foobar2000 tag mapping changes *****
foobar-field   {*5}                       mp3-frame                                m4a-frame                          itunes-field   {*6}
GROUPING                                 TIT1   {*d}                                  @grp                                   Work (name) [mp3],  Grouping [m4a]
WORK                                         GRP1   {*d}                                @wrk                                   Grouping [mp3],  Work (name) [m4a]
MOVEMENTNAME                     MVNM                                      @mvn                                  (Movement) Name  [255 characters max]
MOVEMENTNUMBER                 MVIN   {*7}                                @mvi                                   Movement (#)  [integer only 1-999]
MOVEMENTTOTAL                     MVIN   {*7}                                @mvc                                  of (#)  [integer only >= movement (#)]
SHOWMOVEMENT                     {*8}                                             shwm                                  (show) Work & Name  [to show set to 1]
{*5} foobar-field NAMES are suggested to provide compatibility with other programs and prevent confusion
{*6} itunes-field NAMES which currently provide relevant field mapping to mp3-frames and m4a-frames
{*7} mp3-frame MVIN contains MOVEMENTNUMBER (at start before / separator) and MOVEMENTTOTAL (at end after / separator)
{*8} no mp3-frame is yet defined for SHOWMOVEMENT, it could be SHWM  (still waiting for update in itunes)
{*d} note: it appears that mp3-frames TIT1 & GRP1 would have be switched to make the itunes-fields consistent,
       itunes forums quit questioning why TIT1 mapping changed from Grouping to Work (name) when itunes was updated in 2017,
       discussion in 'foobar2000>support-(fb2k)>%CONTENT GROUP% mapping error' indicates GROUPING is to be mapped to TIT1,
       adding a check box in 'Advanced->Tagging->MP3->ID3v2 revision and quirks' to 'Map TIT1 to Work and GRP1 to Grouping'
       would provide a way to make foobar2000 mapping of mp3-frames '(more compatible with iTunes)' for anyone that needs it.
Thanks foobar2000 for all that you can do, it is the best thing out there, everyone keep supporting it.
