Poll
What lossy format(s) do you use/encode to on a regular basis?
AAC or HE-AAC v1/v2 (.m4a, .aac…)
LossyWAV; .lossy.flac, .lossy.wv, .lossy.tak…
MP3 (.mp3)
Musepack (.mpc)
Ogg Vorbis (.ogg)
Opus (.opus)
WavPack Lossy/Hybrid (.wv)
xHE-AAC (USAC)
I don't encode/listen to lossy audio on a regular basis
Voting closes: 2025-12-31 15:36:56
Topic: 2025 Lossy format poll (Read 46989 times) previous topic - next topic
As last year's results are in, here's your chance to cast your votes for whatever lossy formats currently take your fancy.
Bear in mind you can vote for up to 5 formats.
• Listen to the music, not the media it's on
• The older, the 'lossier'
Re: 2025 Lossy format poll
Do Bluetooth devices count as encoding to the format that's being used for transmission?
That would definitely open a can of worms. The same applies to streamed content, IMHO.
since i have a "once it touches my harddrive it stays that way" policy on my music archive, should i just do what i use for mobile or what do you think? After all my codec mix wont change that much anymore.
And so, with digital, computer was put into place, and all the IT that came with it.
Been there. Done that.
There's no rule, when that was the case, I'd usually go with either the format(s) I've been encoding to lately or else the one(s) making up most of my on-disk audio collection. YMMV.
My moblie lossy folder Is just Lame 3.99.5 at V2 ~ V1 with some edge cases with Lame 3.99a3 at V2. I'm in the middle of coverting my lossless flies into a single OptimFrog bestNew since I'm not getting another HDD untill my 4TB from a old build Is 95% full.
OptimFrog PC | QAAC at Q109(Phone)
I don't encode to a lossy format anymore, except to hand over a copy of something to someone without a good computer. I sometimes use .opus. However, I'm entirely fine with WavPack. (No Lossless poll this year?)
audiophile // flac & wavpack, mostly // using too many audio players
Since the results over the last two years weren't very different, it won't hurt to have this poll open for two years (2025-2026) instead of one year (2025) like FLAC poll
I'll admit it took me a while but, Exhale really made me rethink the whole concept of what is attainable from a lossy codec at a specific range of bitrates and there's always room for impressive results when somebody likes what they do. I started using it on every chance that I get to target content on scenarios that support it.
Someone else is (was?) "in charge" of it and even so, quite sporadically, as results didn't vary much AFAICR.
In any case, anyone here can naturally get one going whenever they feel like.
I started to encode to opus for a while but then realized that most of the affordable bluetooth earbuds (if not all) only support 44.1khz SBC or AAC. Opus is natively 48. And add in the fact that most commercial music is in 44.1khz still, which means "double" resampling. Both during encoding (44.1 to 48) and then again during decoding (48 to 44.1). This can't be good. So i went back to mp3. We had a good relationship for so many years now. I also tried ogg vorbis and musepack at some point, but is the difference really worth it in around 192kbps? Or shall i say, is it worth the lack of support? Can i even abx it? Probably no. Those formats are slowly dying anyway. When i look at recent listening test results, i can see that the last version of lame in 128kbps is not really very far off from the modern codecs in similar bitrates. New codecs like opus "only shine" in lower bitrates which is why they were created, to sound better with low latency internet streaming.
So yeah, i think opus is not a good idea unless you will stream your own radio. I encode with lame using v2 which should be more than enough for my cheap audio setup. And widespread support is guaranteed so no need to worry about that either.
Well i think i should admit that i was wrong with my comments above. Opus, even though it resamples everything to 48kbit, still maintains a much better quality at "lower" bitrates compared to mp3 (or even other formats too). Resampling, as suggested and probably rightfully so, has lesser and even negligible impact on audio quality compared to the compressing alghoritm of these codecs themselves. So yeah, ignore my comment above.
Opus is used because the source is from the internet.
After more A/B'ing I think I'll stick to (QAAC/FHG)AAC at 160 ~ 192kbps VBR.
I choose OPUS because it's open source, gapless, multichannel, and efficient.  It works seamlessly through foobar2000 with any format I convert from. Basically, it just works and it works great. I don't want to have to fart with Apple AAC binaries when OPUS is just as good.
Nothing wrong with Opus, but it's not gapless by design, that's my main reason for still using Ogg/Vorbis for lossy encoding.
I use Opus for lossy because it simply is great.
The OGG tagging is much nicer than that of MP3 and AAC and its support is basically universal now.
Opus makes things very simple because you can feed the reference encoder anything and it will take care of any needed resampling, there are no difficult things to worry about or to take into account like with all the different AAC encoders and profiles.
If the input is some high res audio you can be sure any of those silly wasteful upper bits will all be gone without having to hurt your head thinking about it and the result will be great quality with great savings.
The same for movies, also including surround sound.
Just don't go below 90kbps for music to be sure (if you care a lot about the material keep it somewhere between 140-190kbps).
And as a bonus you can have youtube do all your encodings ;)
What’s the current status of xHE-AAC support on Android and Windows?
Last I checked, foobar2000 still requires the FDK plugin to play xHE-AAC files. It's no surprise adoption remains limited with such minimal out-of-the-box support.
xHE-AAC was added in Windows 11 and Android 9. In Windows world that means software using Media Framework sees the native support.
Peter tested this decocer in foobar2000 long ago, but MF doesn't allow bypassing dynamic range compression so it wasn't good enough for foobar's purposes.
Btw there's already decoding support on FFMPEG (native and FDK) and in some media players (not VLC, but MPV, MPC-BE and PotPlayer at least).
