Hi
There is/was an older component "foo_keep_queue" but development seems to have stopped in 2014.
Is there any other way to set Foobar to NOT wipe the queue if I click and play a track from the library? Something that supports v1.4 etc.
thanks
Why? foo_keep_queue still works fine on foobar v1.4
@Vicas you are indeed correct, it does work with the current v1.4. Thank you for point that out. Consider this thread closed.
I use different playlists for this purpose.
