Please post your found problems and bug issues at this thread.
After reading this thread please check the XLD Master Thread List (http://www.hydrogenaudio.org/forums/index.php?showtopic=66074) for other important XLD threads.
Guide lines for reporting problems or bugs in XLD on this thread.
- Incude the version of XLD you used when the problem occured.
- Include the system configuration:
- (Computer used Power Mac, iMac, MacBook, etc.)
- OS version (10.5.2, 10.5.4, and so on)
- Specific architecture (PPC G4, PPC G5, Intel, etc.)
- Drive model and firmware (if log is not posted)
- Amount of system memory
- An accurate description of how XLD's settings are fixed before the problem occurs.
- A detail report of the undesired or incorrect result that is occurring when using XLD.
- Post any XLD logs that were produced during the problem situation when using XLD.
Okay, I have a *slight* problem with XLD. I tried to encode a CD to AAC (settings True VBR, Max quality, no accurate bitrate information, no add gapless information for iTunes 7). The CD is ripped properly and encoded to m4a-files but when I try to play them in iTunes there's a problem: First track(track1) is played properly but the next one starts with the beginning of the track1, plays it for 10-15s and then starts another track(track2). If I try to play these songs separately (by clicking them), they all include a piece of track1 and after that the actual track that it's supposed to play...
I used version 20080921a (I think), the problem still persists with the newest version (which is at the moment 20080925).
Here's the logfile (if it helps or anything). I only ripped first two tracks this time:
X Lossless Decoder version 20080925 (93.2)
XLD extraction logfile from 2008-09-25 00:01:53 +0300
Conception / In Your Multitude
Used drive : MATSHITA DVD-R UJ-835E (revision GAND)
Use cdparanoia mode : YES (CDParanoia III 10.2 engine)
Disable audio cache : OK for the drive with cache less than 2750KB
Make use of C2 pointers : NO
Read offset correction : 0
Max retry count : 100
TOC of the extracted CD
Track | Start | Length | Start sector | End sector
1 | 00:00:32 | 05:09:70 | 32 | 23276
2 | 05:10:27 | 03:39:68 | 23277 | 39769
3 | 08:50:20 | 03:12:00 | 39770 | 54169
4 | 12:02:20 | 03:46:62 | 54170 | 71181
5 | 15:49:07 | 02:57:15 | 71182 | 84471
6 | 18:46:22 | 07:44:60 | 84472 | 119331
7 | 26:31:07 | 04:35:08 | 119332 | 139964
8 | 31:06:15 | 04:21:72 | 139965 | 159611
9 | 35:28:12 | 03:56:40 | 159612 | 177351
10 | 39:24:52 | 06:39:18 | 177352 | 207294
Track 01
Filename : /Users/Trikimees/Music/01 Conception - Under A Mourning Star.m4a
CRC32 hash : 4EDBD281
CRC32 hash (skip zero) : BF189EC7
Statistics
Read error : 0
Skipped (treated as error) : 0
Edge jitter error (maybe fixed) : 0
Atom jitter error (maybe fixed) : 0
Drift error (maybe fixed) : 0
Dropped bytes error (maybe fixed) : 0
Duplicated bytes error (maybe fixed) : 0
Track 02
Filename : /Users/Trikimees/Music/02 Conception - Missionary Man.m4a
CRC32 hash : 6D60D46C
CRC32 hash (skip zero) : 16E45CD0
Statistics
Read error : 0
No errors occurred
End of status report
[!--sizeo:1--][span style=\"font-size:8pt;line-height:100%\"][!--/sizeo--]Moderation: Code changed to codebox.[/size]
Did you rip the tracks individually or save as one file? I just ripped 2 tracks as separate as files with include pregrap. I had accurate bitrate information, add gapless information for iTunes 7 both checked. Sorry misread your post I did the opposite of your settings. I did not have any issues with the outputted files playing correctly in iTunes 8.0.
XLD extraction logfile from 2008-09-24 17:44:27 -0400
Blues Traveler / Four
Used drive : SONY DVD RW DW-D150A (revision 1.MD)
Make use of C2 pointers : YES
Read offset correction : 48
1 | 00:00:32 | 04:40:03 | 32 | 21034
2 | 04:40:35 | 05:19:15 | 21035 | 44974
3 | 09:59:50 | 05:41:57 | 44975 | 70606
4 | 15:41:32 | 04:46:63 | 70607 | 92119
5 | 20:28:20 | 05:05:47 | 92120 | 115041
6 | 25:33:67 | 04:01:18 | 115042 | 133134
7 | 29:35:10 | 02:59:27 | 133135 | 146586
8 | 32:34:37 | 05:16:63 | 146587 | 170349
9 | 37:51:25 | 04:50:15 | 170350 | 192114
10 | 42:41:40 | 01:55:60 | 192115 | 200799
11 | 44:37:25 | 05:34:35 | 200800 | 225884
12 | 50:11:60 | 06:38:07 | 225885 | 255741
List of alternate offset correction values
# | Absolute | Relative | Confidence
1 | 89 | 41 | 50
2 | 2362 | 2314 | 48
3 | 85 | 37 | 36
4 | 59 | 11 | 18
5 | -143 | -191 | 16
6 | 1220 | 1172 | 10
7 | 2381 | 2333 | 9
8 | 1915 | 1867 | 8
9 | 1027 | 979 | 8
10 | 1313 | 1265 | 6
11 | 75 | 27 | 3
Track 07
Filename : /Users/macman4hire/Music/Blues Traveler/Four/MPEG-4 AAC/07 Crash & Burn.m4a
CRC32 hash : 3846F82B
CRC32 hash (skip zero) : 2215C4FA
AccurateRip signature : E89CD3F9
->Accurately ripped! (confidence 110)
Statistics
Read error : 0
Inconsistency in error sectors : 0
Track 10
Filename : /Users/macman4hire/Music/Blues Traveler/Four/MPEG-4 AAC/10 The Good, The Bad, And The Ugly.m4a
CRC32 hash : E6B0BE50
CRC32 hash (skip zero) : FA738070
AccurateRip signature : 1434A565
->Accurately ripped! (confidence 111)
Statistics
Read error : 0
No errors occurred
Edit: Just ripped to the same two tracks with no accurate bitrate information, no add gapless information for iTunes 7 and both play fine in iTunes 8.0. Sorry don't know whats going with your rips. Try a different CD and see what happens!
I believe it would really help if those posting in this thread provided some information about the system they are using. I have found (and tmkk has fixed) a couple of PPC-specific bugs in XLD.
With that in mind, I think it would be beneficial to mention:
1. Computer used (Power Mac, iMac, MacBook, etc.)
2. OS version (10.5.2, 10.5.4, and so on)
3. Specific architecture (PPC G4, PPC G5, Intel, etc.)
4. Drive model and firmware (if log is not posted)
This will help zero in on any problems. Thanks.
I ripped them individually with pregap and without pregap. I had accurate bitrate information and gapless information for iTunes 7 both checked. I also ripped the same CD (individually) with and without pregap and both accurate bitrate information and gapless information for iTunes 7 *unchecked*.
So in total I made four different rips and the problem persisted. I had no problems whatsoever when I ripped the cd with iTunes 8.
As requested, here's my system:
Mac PowerPC G4, Mac OS 10.4.11 (Tiger); MATSHITA DVD-R UJ-835E (revision GAND).
***Edit: I tested another cd: no change.***
XLD extraction logfile from 2008-09-25 10:01:11 +0300
Yann Tiersen / Tabarly
1 | 00:00:00 | 03:05:05 | 0 | 13879
2 | 03:05:05 | 03:38:08 | 13880 | 30237
3 | 06:43:13 | 01:14:65 | 30238 | 35852
4 | 07:58:03 | 03:33:72 | 35853 | 51899
5 | 11:32:00 | 00:55:63 | 51900 | 56087
6 | 12:27:63 | 02:14:35 | 56088 | 66172
7 | 14:42:23 | 01:12:50 | 66173 | 71622
8 | 15:54:73 | 02:19:45 | 71623 | 82092
9 | 18:14:43 | 02:38:20 | 82093 | 93962
10 | 20:52:63 | 01:18:37 | 93963 | 99849
11 | 22:11:25 | 02:45:30 | 99850 | 112254
12 | 24:56:55 | 03:37:53 | 112255 | 128582
13 | 28:34:33 | 01:32:07 | 128583 | 135489
14 | 30:06:40 | 02:38:03 | 135490 | 147342
15 | 32:44:43 | 01:07:10 | 147343 | 152377
Track 01
Filename : /Users/Trikimees/Music/01 Yann Tiersen - Tabarly.m4a
CRC32 hash : 6BD0FA61
CRC32 hash (skip zero) : 7D58BD1B
AccurateRip signature : 09B2245C
->Track not present in AccurateRip database.
Statistics
Read error : 0
Track 02
Filename : /Users/Trikimees/Music/02 Yann Tiersen - Naval.m4a
CRC32 hash : 1AAD21DF
CRC32 hash (skip zero) : 92B869B6
AccurateRip signature : 3C7F64C3
Statistics
Read error : 0
No errors occurred
Esanssi from the information displayed by you I don't think its the way you have XLD setup. I hope someone with a similar system configuration will try to duplicate the same problem. If another user with a similar system configuration does obtain the same result, then we will be able to report the problem with this useful information to developer and let him concentrate on programming instead of testing. Sorry nothing has helped so far!
Pepzhez I added a guide lines for reporting problems and bugs to the 1st post of this thread. Hopefully this will inform all new posters of this thread what information is necessary for other HA members to hopefully find a solution their problem.
I've noticed an issue during format conversion that I believe it XLD related and not user related ... although I'm happy to be corrected!
It looks like XLD does not respect the "Format of filename" setting when converting from one format to another, it only outputs converted files to the output directory setting. For example,
[blockquote]Output Directory: /Volumes/library/music/xld
Format of filename: %f/%a/%T/%n. %t
Formats: FLAC, AAC[/blockquote]
Output therefore looks like:
[blockquote]/Volumes/library/music/xld/FLAC/<artist>/<AlbumTitle>/etc.
/Volumes/library/music/xld/MPEG-4 AAC/<artist>/<AlbumTitle>/etc.[/blockquote]
When converting a file, e.g. from FLAC to Ogg Vorbis, the converted file is output to the output directory only. I'm losing all of the filename formatting and consequent structure. Mass conversion is not usable at this time.
mookr I do know that there is an issue when you rip a CD and try to output two formats simultaneously. XLD will not let you choose to output Save as a single file(+cue) for one of the choosen formats and to select Include pregap in the end of the previous track or Exclude pregap for the other output (which output separate track files). The developer is aware of this. You can only pick one output type when ripping!
I think my work flow may solve some of the problems you seem to be having.
This is my current work flow with XLD:
1. I choose FLAC and I rip the CD Save as a single file(+cue) the Output directory: to Specify User/macman4hire/Music, the Format of filename: to Specify %A/%T/%f/%T The following outputted structure 1st Arist 2nd Album 3rd Format 4th the file saved with correct Album Title is saved in my Music folder.
2.I next open the newly created FLAC file from the freshly ripped CD and select MPEG-4 AAC for my next format(note you can select Multiple Formats if your desire more than one format) and change the Format of filename: to Specify %A/%T/%f/%n %t next I hit Decode and the output is place in the existing 1st Arist 2nd Album folders with newly created format folder which is reads MPEG-4 AAC , inside the new format folder are the separate tracks with the track number first and the correct track title.
I tried using the Multiple Formats selection with MPEG-4 AAC, LAME and OGG without any issues. This seems to work for me. I hope this was useful.
Hi macman4hire - I'm successfully ripping to multiple formats, no problem there (and I'm ripping to individual files, not cue sheet). The problem I'm experiencing is when I want to convert already ripped files to a different format. For example, I have an already ripped FLAC file I want to convert to AIFF or Ogg Vorbis. The conversion output is not respecting the filename format setting - the converted file will be placed into the output directory only, ignoring any filename format structure that would otherwise have put the file in the correct place. Or am I missing something in what I'm doing that would otherwise correct this behavior?
The other small issue I've found recently was with the logging. Log files now go in the directory of the album, but only if the file is in the AR db (I *think*). Now, I've not tested to determine whether AR settings in preferences have any impact on this, but I've noticed that two albums that were *not* in AR have their log files in the output directory and not with the album. I've got "Test and Copy" set if the album is not in AR; "Query AR db to check integrity" is also set, but "Treat AR mismatch as inconsistency" is not set.
Example albums:
Nick Cave and the Bad Seeds: Abattoir Blues
California Guitar Trio: Whitewater
Edit: Updated with example albums
The FLAC file you already have ripped how did save it Single cue+, Include pregap, Exclude pregap? If you are using individual FLAC files XLD will out the file to the Output directory and not into the Format of filename structure. Unfortunately XLD does not recognize cue for multiple file yet! This why rip to a Single(+cue) file.
.. If you are using individual FLAC files XLD will out the file to the Output directory and not into the Format of filename structure ...
Yes, that's what I'm experiencing. I'm ripping in multiple formats (FLAC and AAC) to single files with pregap included. Occasionally I want to transcode and would like to see the transcoding respect the output filename convention as well. Currently, outputting files to the output directory doesn't make it that useful to me. If I want to mass-transcode, I'm left with a lot of structural tidying up to do!
I will send this info along to the developer tmkk. Sorry it took so long to isolate the problem.
No problem - it hardly took long, but I'm not measuring in "tmkk minutes"! Thank you for collating all the info (and raising the feature request - thanks!).
I think my problem (look above) is somehow related to the way the XLD rips the cd's. Today I used this method and everything worked as it should (songs played properly etc.):
well, just to throw it out there, here's the process I use to encode my CD's to AAC (it works like a charm with my 2G iPod Touch), assuming both Max and XLD are installed-
- rip/encode CD to FLAC using Max (paranoia enabled, etc.)
- navigate to the folder containing the FLAC files, select all/right click, and choose "Open with XLD"
An oddity noticed with the current release of XLD with multi-session disks and the use of GraceNote CDDB (iTunes open): after pregap analysis, the track listing is not displayed per the iTunes listing - no values are reported so you have to update via FreeDB or MusicBrainz (or whatever is available). This does not happen with single session CDs. Also, it's not possible for force a re-read via GraceNote (I'll put that in as a feature request).
I have a badly scratched CD that XLD consistently hangs on. Most of my disks rip within a half hour, but I left this one overnight (8 hours) and came back and found it not making any progress. XLD was able to quit cleanly, but the "cancel" button did nothing for several minutes. I was able to get a log at one point with dozens of suspicious sectors; unfortunately I don't have it on me... I've been overwriting the files every time.
Machine: Macbook
OS: 10.5.5
Processor: Intel Core 2 Duo 2.4 GHz
Drive: HL-DT-ST DVDRW GSA-S10N Revision BP10 ("Superdrive") (Caches 36kb)
Memory: 2 Gb
XLD settings:
Convert to FLAC w/ embedded cue sheet
cdparanoia mode
No C2 pointers (does this drive support it? I'm guessing no)
Retry count: tried 100 and 50
Offset correction: 667 (set automatically)
AccurateRip query activated (the disk isn't in accuraterip anyway)
Automatically save log when ripping to single file + cue
Verify suspicious sectors
Don't test before copy (see below)
Don't scan ReplayGain
Anyway, I'm trying it again now with a max retry of 20 and no suspicious sector verification. I'm not that "paranoid" about this one since it's technically a Taiwanese bootleg anyway (that was a nasty surprise when I found out), I just want to get as much quality out of it as possible. So since I'm not getting any data with verification on, let's see if that helps. Would the old cdparanoia engine help here?
Ok, good, the time remaining is now in the low thousands... seems like it's working better so far :/
The key phrase is badly scratched CD, that is the reason for the hang up in XLD. I have been using XLD for sometime now and find it will on occasion hang up when ripping a badly scratched CD. It will hang up at the same location during a 2nd attempt at ripping. If you have another drive you want to try ripping the CD on that drive. Certain CD's rip well on one drive and not on the other! What you can do is uncheck to the CD Paranoia box and attempt a rip using the burst mode. I would still use AccurateRip to verify the tracks. For me on several occasions the problem was only on one track and all the other tracks were verified using Accurate. I then would listen to the track that was not verified by AccurateRip for any readily apparent audio distortion. If I can not detect any audio distortion on the non verified track, I will then put it to bed. I will not repurchase a CD for one or two tracks that I can not detect any audio distortion on. Another solution would be to try ripping the CD with EAC if you have Windows on your Mac. EAC will work under Boot Camp, VMware Fusion and Parallels.
Good Luck,
macman4hire
Good Luck,
macman4hire
I'm afraid AccurateRip is a no go since the disk isn't listed (I'm sure the bootleg part doesn't help with that). I don't have any other drives either, and though I can get a discounted copy of Windows I oppose that on principle
That said, I would consider burst mode a last resort. There's got to be a way around this...
A few options:
1. I have Max installed as well; I can just use the comparison ripper on that. Problem is, cdparanoia reports that my drive caches 36kb... doesn't that render the comparison ripper useless? Also, I really like embedded .cue sheets. But I can always rip to a separate .cue and convert again with XLD... awkward but effective, assuming the comparison ripper works on caching drives.
2. There's a Darwin port for command-line cdparanoia, but it hasn't been updated since 2006... supposedly. How exactly is XLD using a Linux ripper anyway? Does tmkk have a Darwin port lying around, and would he be willing to distribute it seperately from the GUI? I understand XLD has a command line interface, but it doesn't mention cdparanoia (or any ripping capability for that matter) anywhere in the documentation. Then again, Darwin's UNIX-based... is it possible for me to download the cdparanoia source and compile it on my Mac? I'm not exactly an experienced programmer; my only training is in Java, so this cross-platform stuff isn't really in my playbook.
Any suggestions, or is burst mode and crossed fingers my best bet? To tell you the truth, I actually have in my possession an old FLAC of this disk from a copy of EAC I had on my old PC... but all these errors are making me question its integrity, especially since I recall EAC generating some pretty bizarre .cue files for that rip (multi-minute pregaps and other strange things). Fortunately I had daemon-tools and didn't have to worry about pregap for individual track conversions (at least I think that's how I ended up with decipherable files, either that or I ripped them directly).
Not that it matters much (bootleg specter again), but well... you know... once this kind of thing pops up, you have to nip it in the bud or computers will think they can do whatever they want with our data. They're plotting something big, I'm tellin' ya... Seriously, at this point I just want to see it through and get this data if it kills me. What's the best course of action?
XLD uses cdparanoia 10.2 via libcdio. No, tmkk does not have a ported version of the command line 10.2, sadly.
I think your best bet would be to use the extant command line cdpanoia III 9.8 OS X port, slowing down the drive to 1x speed. I've actually had good luck salvaging certain tracks via this method.
It's available through Fink and Macports. You can also Google around for a standalone installation. Your drive caches far less than 300KB worth of audio, so using 9.8 won't be a problem for you.
No one has yet ported the command line cdparanoia III 10.2 to OS X. Sadly, no one seems very interested in creating one either. I attempted to do a simple update of the cdparanoia engine with the old port, but couldn't get it to work properly. You can compile cdparanoia 10.2, but you'll still need a hardware interface in order to use it on OS X. An all new cdparanoia OS X port is definitely needed. It probably wouldn't be all that difficult to make one using libcdio (which didn't exist when the original cdparanoia OS X port was made).
Have you tried repairing the scratch?
I just use a big slowdown in ripping speed as my cue to take out the CD and spend a few minutes on repairing the disk. Beats waiting hours for a rip that will only most likely come out with problems anyway.
Posted below are some links about CD repair:
CD Repair Info Post 1 (http://www.hydrogenaudio.org/forums/index.php?showtopic=2633&st=0)
CD Repair Info Post 2 (http://www.hydrogenaudio.org/forums/index.php?showtopic=65962)
CD Repair Info Post 3 (http://www.hydrogenaudio.org/forums/lofiversion/index.php/t60491.html)
The text posted below and highlighted was from a specific iTunes/Mac question. I did not post it in this thread initially because I did not want to limit the responses from just XLD users. I am sure one of XLD users would have the answer but was wanting an immediate response. Anyway Pepzhez had the answer to my question. The reason I posted question below in the first place was to test a potential workaround for a problem I was having with XLD.
XLD Version 20080926 (93.3)
Mac Pro Model Identifier: MacPro1,1
Tiger 10.4.11 OS
Intel architecture
Sony DVD RW DW-D150A with the following firmware: 1.MD
1 Gig of Memory
Does any know how to clear the audio CD history on Mac? I want to clear the cache of all opened audio CD's. When you open a CD with iTunes and search Gracenote for the CD info it is cached some where so the next time you insert the CD it will display the title. I currently have a problem with a new CD coming up as previously played CD when using XLD. XLD displays the incorrect CD info and creates a cue sheet for the wrong CD. I think it is title issue because this the second time it has occurred with the title "The Greatest Hits". I don't really care about maintaining this cache. Be advised I removed the XLD and iTunes cache and the incorrect title is still displayed instead of just" Audio CD". So if I could clear the cache I think that I will not have this problem when using XLD.
Work around to XLD displaying incorrectect CD title info (http://www.hydrogenaudio.org/forums/index.php?showtopic=66313&hl=)
garden,
1. How does the CD playback in a stand alone CD/DVD player?
2. How does the CD playback in your computers drive?
The reason I asked you the above posted questions is that if you hear less audio distortion when playing the CD on either of the stand alone CD/DVD player or your computers drive than the ripped version you have other options. Players have error correction that can do a decent on guessing what information should be on an audio disc. You can leverage this correction capability to your benefit. Depending on which player yields the best playback result over the ripped version you may have the following options.
1. A..If the stand alone CD/DVD player plays back the CD the best you can use an optical or coaxial connection from the stand alone player and connect it to your computer to record the digital signal using the error correction of the stand alone player. Note this option is the preferred option over B. because it leaves everything in the digital domain. On the Mac there is a an application called Disk Doctor that facilitates this.
B.If the stand alone CD/DVD player plays back best you can use the analog rca outputs and hook it up to your computer analog rca inputs if you have them. Disk Doctor again will work here.
2. If the computer drive plays back the CD the best over the ripped version you can record the analog signal from the sound card to a digital file. On the Mac there is an application called Audio Hijack that facilitates this. Note option 1 A is still preferred unless the playback result on the stand alone player is less than the computers drive.
Before anyone chastises me about that fact it is better to keep things in the digital domain note I would rather have the ability to archive a deteriorating CD before it is to late to a decent sounding digital file. This circumstance warrants leaving the completely digital ideal.
See, I'm a college student, so the most sophisticated equipment I have available is my Macbook. From what you've told me, no software solutions exist for this problem, unless I try the command-line cdparanoia port. Can that even handle cue sheets, or online DB's?
So right now I'm sticking with my previously ripped, vaguely suspicious copy of the file. Once I go home for Thanksgiving I can try to scrounge up some sandpaper and silver polish, or try using a stand-alone player. macman, does that software you mentioned cost anything? Cheap-as-free solutions are preferred. But even if not, that's a pretty good idea I hadn't considered. But I'm not sure if our home system even has any digital ports.
Unfortunately both Disk Doctor and Audio Hijack are commercial applications with a cost. Disk Doctor is bundle with an disc burning application called Toast. I have seen a freeware application to record audio from external sources but can not recall the name. I am sure if you search the web you can find a freeware app. Also Audio Hijack provides a trail mode which allows you to record for 10 minutes or less, any recordings longer than 10 minutes the application introduces noise into the recording after the 10 minute mark. So if the songs are not to long this may still be a free option depending on you use it.
Toast (http://www.roxio.com/enu/products/toast/titanium/overview.html)
Audio Hijack (http://rogueamoeba.com/audiohijackpro/)
Edit:
I just checked the Audio Hijack site and it seems that it will now use the System Audio input source to record all audio being played on your machine. So it looks like it is capable of employing all of the strategies I recommended to you. This gives you several of options as long as your tracks are 10 minutes or less. Also you could splice two recorded segments together if a track is longer than 10 minutes using a freeware application called Audio City. This will be a time consuming task but if you really care about the music and you can't Audio Hijack it is an option.
Audio City (http://audacity.sourceforge.net/)
2nd Eit:
The latest version of Audiocity will facilitate recording through the 1/8 stereo input and is free. What you will need to purchase is a stereo rca to 1/8 mini plug cable. Just check to see if you Mac Book has this input. An icon will look something like this >O<above 1/8 input jack(note the current models do have this input jack). If you do you are golden. I would use this strategy before attempting to the repair CD. Hopefully a repair effort makes a CD rip and playback better but sometimes it can it cause more problems than before the attempted repair. Remember you can't undo a failed CD repair! Some video game stores, movie rental and used CD stores also offer disc repair services with specialized commercial grade repair equipment.
Amazon 1/8 stereo mini plug to rca cable (http://www.amazon.com/3-5mm-Mini-Plug-Computer-Stereo/dp/B000V0G2C4/ref=pd_cp_e_2?pf_rd_p=413863501&pf_rd_s=center-41&pf_rd_t=201&pf_rd_i=B000FEHO0U&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=08T5BFFD8XY7PJ0FZPGK)
Radio Shack 1/8 stereo mini plug to rca cable (http://www.radioshack.com/sm-6-ft-gold-series-phono-to-1-8-y-adapter--pi-2103865.html)
Good Luck,
macman4hire
It seems that when I drag an audio (wav) file onto the XLD player, the Left and Right channels are reversed on playback.
I didn't have enough time to dig into it much. The wav files plays correctly in the finder (preview).
MacBook OS X 10.4.11, built-in audio digital out.
Can anyone confirm this bug ?
Kees de Visser
(15 min. later) the problem seems to be linked to the cue sheet. When I use another cue sheet, L/R balance is ok.
Interesting because AFAIK the cue sheet doesn't contain any channel routing info.
I had the same problem. What seems to solve it for me is to
check the box in the "CD Rip" settings called "Use C2 error pointers". I don't really know what that means. Does it have any risks or drawbacks?
Anyway, I hope knowing this can help in ironing out this bug.
Ugh, XLD does not seem to be getting all of my Gracenote info from iTunes?
What am I doing wrong??
Here is my log file.
2.5GHz MBP 10.5.5
X Lossless Decoder version 20080926 (93.3)
XLD extraction logfile from 2008-11-20 22:03:08 -0600
AC/DC / Black Ice
Used drive : MATSHITA DVD-R UJ-867 (revision HA13)
Read offset correction : 102
1 | 00:00:00 | 04:21:38 | 0 | 19612
2 | 04:21:38 | 03:34:13 | 19613 | 35675
3 | 07:55:51 | 03:57:05 | 35676 | 53455
4 | 11:52:56 | 03:22:12 | 53456 | 68617
5 | 15:14:68 | 03:09:59 | 68618 | 82851
6 | 18:24:52 | 04:06:31 | 82852 | 101332
7 | 22:31:08 | 03:17:06 | 101333 | 116113
8 | 25:48:14 | 03:28:37 | 116114 | 131750
9 | 29:16:51 | 03:33:66 | 131751 | 147791
10 | 32:50:42 | 03:10:16 | 147792 | 162057
11 | 36:00:58 | 03:52:71 | 162058 | 179528
12 | 39:53:54 | 04:15:34 | 179529 | 198687
13 | 44:09:13 | 04:40:68 | 198688 | 219755
14 | 48:50:06 | 03:22:37 | 219756 | 234942
15 | 52:12:43 | 03:25:08 | 234943 | 250325
Track 01
Filename : /Users/todd/Music/01 AC/DC - Rock 'n' Roll Train.m4a
CRC32 hash : 28939EFE
CRC32 hash (skip zero) : 52140DF7
AccurateRip signature : 0B33BB38
Statistics
Read error : 0
Track 02
Filename : /Users/todd/Music/02 AC/DC - Skies on Fire.m4a
CRC32 hash : FBF30B4D
CRC32 hash (skip zero) : 64C0EC18
AccurateRip signature : C70C290B
Statistics
Read error : 0
Track 03
Filename : /Users/todd/Music/03 AC/DC - Big Jack.m4a
CRC32 hash : EA9C6FD5
CRC32 hash (skip zero) : DC12C6CF
AccurateRip signature : 362E8490
Statistics
Read error : 0
Track 04
Filename : /Users/todd/Music/04 AC/DC - Anything Goes.m4a
CRC32 hash : 03DBA257
CRC32 hash (skip zero) : 989DAEBE
AccurateRip signature : D2C3B47E
Statistics
Read error : 0
Track 05
Filename : /Users/todd/Music/05 AC/DC - War Machine.m4a
CRC32 hash : 79FE9808
CRC32 hash (skip zero) : DE76F6C2
AccurateRip signature : D12EB4D0
Statistics
Read error : 0
Track 06
Filename : /Users/todd/Music/06 AC/DC - Smash 'n' Grab.m4a
CRC32 hash : 8249CC3A
CRC32 hash (skip zero) : 303D8508
AccurateRip signature : DC51E30D
Statistics
Read error : 0
Track 07
Filename : /Users/todd/Music/07 AC/DC - Spoilin' for a Fight.m4a
CRC32 hash : 451C26A4
CRC32 hash (skip zero) : 10FAB849
AccurateRip signature : C64A110B
Statistics
Read error : 0
Track 08
Filename : /Users/todd/Music/08 AC/DC - Wheels.m4a
CRC32 hash : 2FD77A3A
CRC32 hash (skip zero) : BA778A68
AccurateRip signature : 45AD2BBB
Statistics
Read error : 0
Track 09
Filename : /Users/todd/Music/09 AC/DC - Decibel.m4a
CRC32 hash : 70F8F7E6
CRC32 hash (skip zero) : 25B87126
AccurateRip signature : 032BA370
Statistics
Read error : 0
Track 10
Filename : /Users/todd/Music/10 AC/DC - Stormy May Day.m4a
CRC32 hash : 20DCCE7D
CRC32 hash (skip zero) : 5A622D02
AccurateRip signature : 367179BD
Statistics
Read error : 0
Track 11
Filename : /Users/todd/Music/11 AC/DC - She Likes Rock 'n' Roll.m4a
CRC32 hash : 222106CB
CRC32 hash (skip zero) : AC8F1714
AccurateRip signature : 63B448AE
Statistics
Read error : 0
Track 12
Filename : /Users/todd/Music/12 AC/DC - Money Made.m4a
CRC32 hash : 34FA8390
CRC32 hash (skip zero) : 84E85039
AccurateRip signature : 739504F9
Statistics
Read error : 0
Track 13
Filename : /Users/todd/Music/13 AC/DC - Rock 'n' Roll Dream.m4a
CRC32 hash : E5FE861D
CRC32 hash (skip zero) : 84C4938C
AccurateRip signature : D1B5F2A3
Statistics
Read error : 0
Track 14
Filename : /Users/todd/Music/14 AC/DC - Rocking All the Way.m4a
CRC32 hash : 8F8B4D42
CRC32 hash (skip zero) : FC66274B
AccurateRip signature : 1C17419C
Statistics
Read error : 0
Track 15
Filename : /Users/todd/Music/15 AC/DC - Black Ice.m4a
CRC32 hash : 8629A0D6
CRC32 hash (skip zero) : CF317F05
AccurateRip signature : 8BF780BB
Statistics
Read error : 0
No errors occurred
[!--sizeo:1--][span style=\"font-size:8pt;line-height:100%\"][!--/sizeo--]Moderation: Codebox is the forum's best friend for this kind of thing. Please learn how to use it. [/size]
I am having an issue with XLD effectively hanging when trying to rip certain CDs with little to no visible damage. With some of them, the problem starts right away when XLD takes forever to read the gap info. In all cases, the ripping of one or more (or all) tracks slows to a virtual crawl, registering "0.0 x" rip speed and showing many hundreds or thousands of minutes to finish ripping a single track.
All of these discs play back without problems in all my CD players and will play from the same drive in iTunes. I can also rip them no prob in Max.
I have listed my machine specs and XLD rip prefs below.
Anybody have any ideas to resolve this? This is kind of a pain.
Machine and set-up:
2 Ghz DP G5
OS 10.5.5
Pioneer DVR-107D
XLD version 20080926 (93.3)
XLD CD rip prefs (checked or with values entered):
Rip as accurate as possible
Max retry count: 100
Offset correction: 48 (auto)
Query AccurateRip
Automatically save log file: Always
Test before copy: only when track does not exist in AccurateRip DB
- Version 20080926 (93.3)
- system configuration:
- iMac 2.16 HGz Intel Core 2 Duo
- 10.4.11
- Intel
- MATSHITA DVD-R UJ-85J (revision FCQA)
- 1 GB 667 MJz DDR2 SDRAM
- Preferences General: output format: WAV - output directory: specified to working folder for rip - filename: %n - %t - max threads: 2 - remaining selections only automatically add tags if possible
- Preferences CD rip: following selected: rip as accurate as possible - max retry 100 - read sample offset 102 - set automatically - query AR DB - automatically save log file always - verify suspicious sectors
Using XLD for one day. First rip of silver CD bootleg went fine and log file appeared at completion of rip. On subsequent attempt to rip again three tracks from the same disc that had slight atom jitter errors, this time with "test before copy checked," XLD will NOT produce any logs for any rip. I've tried several times, searched with finder for any .log file and the only ones that show up are the ones from the first rip.
Solved: XLD lets you rip from File > Open as well as File > Open Audio CD. For some reason I started ripping from the first option, then locating the tracks in finder. Do it that way and no log is generated.
- System Configuration:
- 10.4.11
- 2GHz Intel Core Duo
- MATSHITA DVD-R UJ-857 (revision HAE4)
- 2GB 667 MHz DDR2 SDRAM
- output format: FLAC
- CDDB freedb.freedb.org /~cddb/cddb.cgi
- max threads: 2
- Problem:
- I seem to be having a problem where every single unsuccessful CDDB query causes XLD to crash. This happens after pregaps are detected and I 'get CD track names', and even happens when I do a query after having ripped a song off the then untagged album.
XLD extraction logfile from 2009-01-05 12:56:32 -0500
/ Beyond The Horizon
Used drive : MATSHITA DVD-R UJ-857 (revision HAE4)
1 | 00:00:00 | 04:26:65 | 0 | 20014
2 | 04:26:65 | 04:46:62 | 20015 | 41526
3 | 09:13:52 | 04:26:39 | 41527 | 61515
4 | 13:40:16 | 04:12:11 | 61516 | 80426
5 | 17:52:27 | 04:35:09 | 80427 | 101060
6 | 22:27:36 | 03:34:37 | 101061 | 117147
7 | 26:01:73 | 05:17:44 | 117148 | 140966
8 | 31:19:42 | 04:02:69 | 140967 | 159185
9 | 35:22:36 | 03:51:08 | 159186 | 176518
10 | 39:13:44 | 05:28:56 | 176519 | 201174
11 | 44:42:25 | 03:45:39 | 201175 | 218088
12 | 48:27:64 | 05:08:03 | 218089 | 241191
Track 01
Filename : /Users/brent/Music/XLD/Unknown Artist -- Unknown Album -- 01 -- Unknown Title.flac
CRC32 hash (test run) : 5A2451E9
CRC32 hash : 5A2451E9
CRC32 hash (skip zero) : 46F527A7
AccurateRip signature : A6649789
Statistics
Read error : 0
No errors occurred
This can be worked around by manually inputting the metadata, but is still a bug I believe. Might be nice to have a message reading that the CDDB query returned no results perhaps?
thanks
Brent
@bkhl
Thank you for posting that solution!!!! I had gone through about 15 CDs before I had noticed that error.
The 10-15 seconds from Track 1 would appear regardless of the file format selected. The error only occurred when I selected Open Audio CD from the File menu. If I clicked File>Open, XLD would just start ripping without the CDDB metadata & the error wouldn't occur. I uninstalled and reinstalled XLD, and tried two different versions: 20090215 and 20090217. It didn't matter which version I used the error remained the same.
Here's the log file from one of the files that had the 10-15 seconds from Track 1 included>
X Lossless Decoder version 20090217 (101.1)
XLD extraction logfile from 2009-02-20 16:14:53 -0600
The Miles Davis Quintet / Relaxin' With Miles
Used drive : SONY DVD RW DW-U10A (revision A43h)
1 | 00:00:00 | 08:17:30 | 0 | 37304
2 | 08:17:30 | 05:20:05 | 37305 | 61309
3 | 13:37:35 | 05:10:72 | 61310 | 84631
4 | 18:48:32 | 05:54:05 | 84632 | 111186
5 | 24:42:37 | 06:39:65 | 111187 | 141176
6 | 31:22:27 | 05:01:63 | 141177 | 163814
Track 01
Filename : /Desktop/rips/01 The Miles Davis Quintet - If I Were A Bell.mp3
CRC32 hash (test run) : 18AD8357
CRC32 hash : 79FFFBB6
->Rip may not be accurate.
CRC32 hash (skip zero) : 6214B14B
AccurateRip signature : 3DA7E008
Statistics
Read error : 0
Track 02
Filename : /Desktop/rips/02 The Miles Davis Quintet - You're My Everything.mp3
CRC32 hash (test run) : 3C6A42EA
CRC32 hash : 9A1E6B04
CRC32 hash (skip zero) : 330DE008
AccurateRip signature : 15C6A04E
Statistics
Read error : 0
Track 03
Filename : /Desktop/rips/03 The Miles Davis Quintet - I Could Write A Book.mp3
CRC32 hash (test run) : 660F2DF6
CRC32 hash : F105E3ED
CRC32 hash (skip zero) : 554AB774
AccurateRip signature : EA7EAF56
Statistics
Read error : 0
Track 04
Filename : /Desktop/rips/04 The Miles Davis Quintet - Oleo.mp3
CRC32 hash (test run) : 6137D6BF
CRC32 hash : B6D6F62A
CRC32 hash (skip zero) : F1B82687
AccurateRip signature : A91F3896
Statistics
Read error : 0
Track 05
Filename : /Desktop/rips/05 The Miles Davis Quintet - It Could Happen To You.mp3
CRC32 hash (test run) : CA7ADE79
CRC32 hash : 27FE3DC9
CRC32 hash (skip zero) : C2A86233
AccurateRip signature : CA86A656
Statistics
Read error : 0
Track 06
Filename : /Desktop/rips/06 The Miles Davis Quintet - Woody'n You.mp3
CRC32 hash (test run) : 4D65E615
CRC32 hash : 7E19B91E
CRC32 hash (skip zero) : 89B2E9DA
AccurateRip signature : 20839996
Statistics
Read error : 0
Some inconsistencies found
Power Mac G5
Leopard 10.5.6
PPC architecture
Sony DVD RW DW-U10A with the following firmware: A43h
1.5 GB of memory
version: Version 20090217 (101.1)
system configuration: MacBook, Intel Core Duo processor, OS X 10.5.6, 1GB RAM
XLD settings: Format of filename: Specify (String: %a/%T [%f]/%n - %t)
incorrect result that is occurring:
In each CUE file generated, [%f] is not expanded to [MP3] or [FLAC]. Instead the cue file contains the string value [%f] in each filename. String expansion was accomplished in the actual file naming, just not in the file location specified in the CUE file.
(I didn't include the log because it didn't seem relevant to this problem.)
All the tags are blank after Transcoding mp3 (or ogg) > aac.
But with cuesheet (ape or flac), the freedb request is effective and all the tags come in the files.
Is this problem normal ?
Transcoding can't work with freedb or there is a solution ?
My problem is similar to that of tubegeek as it has to do with proper file naming but erroneous cue sheet generation.
XLD version 20090320 (105.1) used on an iMac Aluminium (Intel Core 2 Duo) 2GB RAM running Mac OS X 10.5.6.
When using the "Format of filename (when using cuesheet / ripping)":
%A/%T/%n - %t
Files will be properly created in their respective folders but the cuesheet will be generated with "/" folder level separators and the preceding %A argument like in the included cuesheet:
TITLE "Beast"
PERFORMER "Beast"
CATALOG 0823674100322
REM GENRE "Electronic"
REM DATE "2008-11-18"
REM REPLAYGAIN_ALBUM_GAIN -8.68 dB
REM REPLAYGAIN_ALBUM_PEAK 1.000000
FILE "%A/Beast/01 - Devil.wav" WAVE
TRACK 01 AUDIO
TITLE "Devil"
PERFORMER "Beast"
ISRC CAM370800864
REM REPLAYGAIN_TRACK_GAIN -8.40 dB
REM REPLAYGAIN_TRACK_PEAK 1.000000
INDEX 01 00:00:00
TRACK 02 AUDIO
TITLE "Finger Prints"
PERFORMER "Beast"
ISRC CAM370800865
REM REPLAYGAIN_TRACK_GAIN -8.54 dB
REM REPLAYGAIN_TRACK_PEAK 0.992615
INDEX 00 03:20:17
FILE "%A/Beast/02 - Finger Prints.wav" WAVE
INDEX 01 00:00:00
Anyone else still having issues with XLD treating enhanced cds correctly?
On my external drive enhanced cds always hang on the external drive. Also, I can never seem to get AR or CDDB (iTubes) metadata import to work properly on enhanced cds either.
I am having a similar problem...
TITLE "Songs In The Night"
PERFORMER "Samantha Crain"
REM GENRE "Folk"
REM DATE 2009
FILE "/%A - Songs In The Night [%f]/01 - Rising Sun.wav" WAVE
TRACK 01 AUDIO
TITLE "Rising Sun"
ISRC US4BW0900300
INDEX 01 00:00:00
FILE "/%A - Songs In The Night [%f]/02 - Songs In The Night.wav" WAVE
TRACK 02 AUDIO
ISRC US4BW0900301
INDEX 01 00:00:00
FILE "/%A - Songs In The Night [%f]/03 - Long Division.wav" WAVE
TRACK 03 AUDIO
TITLE "Long Division"
ISRC US4BW0900302
INDEX 01 00:00:00
I have a very strange problem! When I use XLD as a ripper File > Open Audio cd it is adding the first 15-20 seconds of track 1 to every track. I am most confused by this. I used XLD to convert about 600 gigs of FLAC files to AIFF and had no issues. But I have this problem whenever I try and rip a disc. Any help would be greatly appreciated.
System
Mac Mini 2.26 GHz Intel Core 2 duo
4 gigs of RAM
can anyone help me with this?
Have you tried using a different ripping drive?
I had an iMac a few years ago, with an internal Matshita that was simply incompatible with cdparanoia (I was using Max at the time). Apparently, it would frequently dump some of the contents of it's cache on the end of many tracks - often just as rude noise, sometimes as recognizable musical content from earlier in the CD.
Sounds like this is happening to you.
This is my first time using XLD. I'm having trouble ripping 2 enhanced CD's, on the last track on the CD it just hangs at 99%. I tried ripping a regular CD and there where no problems. Any help?
iMac 24"
2.93 GHz Intel Core Duo
4GB RAM
OSX Version 10.5.7
XLD Version 20090320 (105.1)
OPTIARC DVD RW AD-5670S:
Firmware Revision: 2AHC
Interconnect: ATAPI
Burn Support: Yes (Apple Shipping Drive)
Cache: 2048 KB
Reads DVD: Yes
CD-Write: -R, -RW
DVD-Write: -R, -R DL, -RW, +R, +R DL, +RW
Write Strategies: CD-TAO, CD-SAO, CD-Raw, DVD-DAO
Media: Insert media and refresh to show available burn speeds
I have tried it with both my external drive and the internal drive and it has the same issue. It adds the same 30 seconds to every track! It is very annoying and I have no idea how to fix it.
Is this truly the place to go for bugs with XLD? or should I be going somewhere else?
system Imac
Intel
OSX 10.5.7
Description of the problem:
When I try to convert a CD image file (FLAC/WAV with cue sheet) to single Apple Lossless tracks I get the following problem. Some tracks are ripped and others are skipped, the skipped tracks show up in the folder but are like 300 kb or something. I tried this a couple of times and keep running into the same problem. When I convert flac files to apple lossless i have no problems, so the problem only arise with coverting from a single file with cuesheet.
If you quit XLD during a rip, it doesn't save the log file before exiting.
Canceling a track in the middle of a rip can take ages (as in tens of minutes) before stopping. In some cases, XLD won't ever stop.
Anyone having issues with XLD not grabbing the iTunes CDDB metadata like its supposed to?
The data is showing in iTunes but XLD never grabs it.
It is not supposed to do that. XLD grabs FreeDB, iTunes grabs Gracenote.
Are you hitting "Refresh List" in "Open Audio CD"?
Hi guys.
I have an issue with XLD where sometimes it takes a very long time to detect the pre-gaps using my new external Plextor Premium 2. Once that is done, everything works smoothly and quickly but initially the pre-gap detection is often very slow indeed.
I should add that I am still running XLD on Leopard 10.5.8 and I'm using a PPC machine. It's a Powerbook G4.
I cannot seem to identify where the problem might be. For instance, a disc that has slow pre-gap detection on my Plextor will not exhibit this behavior using the Powerbook's internal MATSHITA DVD-R UJ-845E.
I should add that the problem is complicated by the fact that it only happens on some compact discs (maybe older ones - but I couldn't really say).
I like to ask anyone very familiar with XLD where the problem most likely stems from. Is it the Plextor or maybe the PPC architecture or perhaps I should upgrade my machine in order to run Snow Leopard?
Your help would be much appreciated.
Regards
I'm using XLD to rip CD's to FLAC files. I'm using "Allow to embed cue sheet" and ripping as "Save as single file (+ cue)".
After creating the FLAC file, I intend to extract the tracks as MP3 an add them into iTunes.
I plan to use Max for that, so that I don't need to keep changing the XLD preferences everytime.
When I try to open the FLAC file in Max, it says it can't find the a cue sheet in the file.
It works ok if I open the CUE file.
I used metaflac in some of the FLAC files I've already created and it says that "FLAC file has no CUESHEET block".
Here is the command I tried and the result:
$ metaflac --export-cuesheet-to=- Creedence\ Clearwater\ Revival\ -\ Chronicle\,\ Vol.\ 1.flac
Creedence Clearwater Revival - Chronicle, Vol. 1.flac: ERROR: FLAC file has no CUESHEET block
It appears that XLD isn't embedding the cue sheet as I understand it was supposed to.
Am I doing something wrong, or is this an actual bug?
My configuration: MacBook Pro (Mid-2009), Leopard (10.5.8), XLD (20090924).
Best regards!
This is to echo DNOBel's problem on page 2, where there don't seem to be any solutions for....yet.
My (Test) gets to 25% then just hangs and reads 0.0x, 783:45 remaining. It hasn't even begun ripping the audio file yet. It has satyed like this for an hour so I shut off my machine before it ignited in flames.
my machine prefs:
OS 10.6.1
Macbook Intel Core 2 Duo, 2gHz
drive: MATSHITA CD-RW CW-8221
XLD Version 20090924 (109.9)
using Lame MP# encoder
all the following are checked:
CD Paranoia Mode
Offset correction value 102
Query AccurateRip database to check integrity
TEst before copy
apparently, the same issue as this guy:
Machine and set-up:
2 Ghz DP G5
OS 10.5.5
Pioneer DVR-107D
Query AccurateRip
Did you contact the developer (write a mail)? He tends to react to bug reports (he did to mine at least). I don't think he reads this forum though.
I too sometimes see xld taking ages or hanging in the pregap detection phase. not sure what causes this but it would be great to have a.) the option to turn of pregap detection, b.) have a cancel button.
otherwise this is an excellent app!
wow - skipping pre-gap just got added. awesome responsiveness by the devs. thx so much and happy new year
while trying to rip two lightly scratched cd's xld made no progress for hours on certain tracks. hitting cancel did nothing so ultimately I had to force-quit the app. xld will disappear from the active processes list in activity monitor but the icon will stay in both the dock and the taskbar. also the cd will stay in the drive which can't be accessed by any other application.
restarting finder does not fix this. restart required. problem is reproducible for me. mabook 4.1., osx 10.5.8, uj-857e drive.
anybody else seeing similar problems?!
thx!
thx!
This has been a problem for some time.
I found a way at one point to eject the disk using another application without having to restart. It was a while ago, but I think Rip did it ... perhaps iTunes too.
A graceful exit from a hung up rip is one of the last parts missing from XLD.
I suspect that this problem is caused by a hung, or thrashing, cdparanoia. cdparanoia will try very hard to extract data from a damaged CD and can become unresponsive and impossible to quit at times. At least, I've experienced that behavior when ripping a bad disc with the command line cdparanioa and then the same problem when ripping with paranoia turned on in XLD.
When trying to get CD Track names (CDDB) with XLD Version 20091230 (115.2), the application crashes.
This was with Disney's Princess and the Frog Soundtrack
Process: XLD [1206]
Path: /Applications/XLD.app/Contents/MacOS/XLD
Identifier: jp.tmkk.XLD
Version: 20091230 (115.2)
Code Type: X86 (Native)
Parent Process: launchd [175]
Date/Time: 2010-01-04 17:45:50.310 -0800
OS Version: Mac OS X 10.6.2 (10C540)
Report Version: 6
Interval Since Last Report: 660056 sec
Crashes Since Last Report: 9
Per-App Interval Since Last Report: 1548 sec
Per-App Crashes Since Last Report: 6
Anonymous UUID: FDF3280B-A366-4074-9608-0B389E8139CC
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000008
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Thread 0 Crashed: Dispatch queue: com.apple.main-thread
0 Musicbrainz 0x0008aedd MusicBrainz::Artist::getName() const + 13
1 jp.tmkk.XLD 0x0002c308 -[XLDCDDBUtil query] + 878
2 jp.tmkk.XLD 0x000162da -[XLDController cddbGetTracksWithAutoStart:] + 489
3 com.apple.AppKit 0x98d34f86 -[NSApplication sendAction:to:from:] + 112
4 com.apple.AppKit 0x98d34e39 -[NSMenuItem _corePerformAction] + 435
5 com.apple.AppKit 0x98d34b2a -[NSCarbonMenuImpl performActionWithHighlightingForItemAtIndex:] + 174
6 com.apple.AppKit 0x98d34a16 -[NSMenu performActionForItemAtIndex:] + 65
7 com.apple.AppKit 0x98d349c9 -[NSMenu _internalPerformActionForItemAtIndex:] + 50
8 com.apple.AppKit 0x98d3492f -[NSMenuItem _internalPerformActionThroughMenuIfPossible] + 97
9 com.apple.AppKit 0x98d34873 -[NSCarbonMenuImpl _carbonCommandProcessEvent:handlerCallRef:] + 336
10 com.apple.AppKit 0x98d28f79 NSSLMMenuEventHandler + 404
11 com.apple.HIToolbox 0x90aebe29 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567
12 com.apple.HIToolbox 0x90aeb0f0 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
13 com.apple.HIToolbox 0x90b0d981 SendEventToEventTarget + 52
14 com.apple.HIToolbox 0x90b39e3b SendHICommandEvent(unsigned long, HICommand const*, unsigned long, unsigned long, unsigned char, void const*, OpaqueEventTargetRef*, OpaqueEventTargetRef*, OpaqueEventRef**) + 448
15 com.apple.HIToolbox 0x90b5eb20 SendMenuCommandWithContextAndModifiers + 66
16 com.apple.HIToolbox 0x90b5ead7 SendMenuItemSelectedEvent + 121
17 com.apple.HIToolbox 0x90b5e9d3 FinishMenuSelection(SelectionData*, MenuResult*, MenuResult*) + 152
18 com.apple.HIToolbox 0x90b2e212 MenuSelectCore(MenuData*, Point, double, unsigned long, OpaqueMenuRef**, unsigned short*) + 440
19 com.apple.HIToolbox 0x90b2d9a9 _HandleMenuSelection2 + 465
20 com.apple.HIToolbox 0x90b2d7c7 _HandleMenuSelection + 53
21 com.apple.AppKit 0x98d224ba _NSHandleCarbonMenuEvent + 285
22 com.apple.AppKit 0x98cf7076 _DPSNextEvent + 2304
23 com.apple.AppKit 0x98cf6306 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 156
24 com.apple.AppKit 0x98cb849f -[NSApplication run] + 821
25 com.apple.AppKit 0x98cb0535 NSApplicationMain + 574
26 jp.tmkk.XLD 0x00002a9a _start + 216
27 jp.tmkk.XLD 0x000029c1 start + 41
Thread 1: Dispatch queue: com.apple.libdispatch-manager
0 libSystem.B.dylib 0x94b040ea kevent + 10
1 libSystem.B.dylib 0x94b04804 _dispatch_mgr_invoke + 215
2 libSystem.B.dylib 0x94b03cc3 _dispatch_queue_invoke + 163
3 libSystem.B.dylib 0x94b03a68 _dispatch_worker_thread2 + 234
4 libSystem.B.dylib 0x94b034f1 _pthread_wqthread + 390
5 libSystem.B.dylib 0x94b03336 start_wqthread + 30
Thread 2:
0 libSystem.B.dylib 0x94b03182 __workq_kernreturn + 10
1 libSystem.B.dylib 0x94b03718 _pthread_wqthread + 941
2 libSystem.B.dylib 0x94b03336 start_wqthread + 30
Thread 3:
0 libSystem.B.dylib 0x94add8da mach_msg_trap + 10
1 libSystem.B.dylib 0x94ade047 mach_msg + 68
2 com.apple.CoreFoundation 0x94d3377f __CFRunLoopRun + 2079
3 com.apple.CoreFoundation 0x94d32864 CFRunLoopRunSpecific + 452
4 com.apple.CoreFoundation 0x94d32691 CFRunLoopRunInMode + 97
5 com.apple.Foundation 0x91001430 +[NSURLConnection(NSURLConnectionReallyInternal) _resourceLoadLoop:] + 329
6 com.apple.Foundation 0x90fc88d8 -[NSThread main] + 45
7 com.apple.Foundation 0x90fc8888 __NSThread__main__ + 1499
8 libSystem.B.dylib 0x94b0afbd _pthread_start + 345
9 libSystem.B.dylib 0x94b0ae42 thread_start + 34
Thread 4:
0 libSystem.B.dylib 0x94afc856 select$DARWIN_EXTSN + 10
1 com.apple.CoreFoundation 0x94d72ddd __CFSocketManager + 1085
2 libSystem.B.dylib 0x94b0afbd _pthread_start + 345
3 libSystem.B.dylib 0x94b0ae42 thread_start + 34
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x00000000 ebx: 0x00615040 ecx: 0x006b5760 edx: 0x006b5768
edi: 0x15831d00 esi: 0xbfffea68 ebp: 0xbfffe9c8 esp: 0xbfffe9b0
ss: 0x0000001f efl: 0x00010282 eip: 0x0008aedd cs: 0x00000017
ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
cr2: 0x00000008
Binary Images:
0x1000 - 0x5efe7 +jp.tmkk.XLD 20091230 (115.2) <E2FE6829-8A92-485B-8E9A-2CF974B834F7> /Applications/XLD.app/Contents/MacOS/XLD
0x73000 - 0x7efff +CDDB ??? (???) /Applications/XLD.app/Contents/Frameworks/CDDB.framework/Versions/A/CDDB
0x8a000 - 0xebfcf +Musicbrainz ??? (???) /Applications/XLD.app/Contents/Frameworks/Musicbrainz.framework/Versions/A/Musicbrainz
0x152000 - 0x174fdf +Cdio ??? (???) /Applications/XLD.app/Contents/Frameworks/Cdio.framework/Versions/A/Cdio
0x18c000 - 0x1e7fe7 +Sndfile ??? (???) <5486AA14-2EB2-4708-9100-B8BA6C13247F> /Applications/XLD.app/Contents/Frameworks/Sndfile.framework/Versions/A/Sndfile
0x29b000 - 0x29dfff +net.culater.SIMBL 0.8.2 (8) /Library/InputManagers/SIMBL/SIMBL.bundle/Contents/MacOS/SIMBL
0x2e2000 - 0x2e9ff3 +jp.tmkk.XLDAacOutput ??? (1.0) /Applications/XLD.app/Contents/PlugIns/XLDAacOutput.bundle/Contents/MacOS/XLDAacOutput
0x2ef000 - 0x2f9ffb +jp.tmkk.XLDAacOutput2 ??? (1.0) /Applications/XLD.app/Contents/PlugIns/XLDAacOutput2.bundle/Contents/MacOS/XLDAacOutput2
0x789000 - 0x78dffb +jp.tmkk.XLDAlacDecoder ??? (1.0) /Applications/XLD.app/Contents/PlugIns/XLDAlacDecoder.bundle/Contents/MacOS/XLDAlacDecoder
0x793000 - 0x79afff +jp.tmkk.XLDAlacOutput ??? (1.0) /Applications/XLD.app/Contents/PlugIns/XLDAlacOutput.bundle/Contents/MacOS/XLDAlacOutput
0x79f000 - 0x7bafe5 +jp.tmkk.XLDApeDecoder ??? (1.0) /Applications/XLD.app/Contents/PlugIns/XLDApeDecoder.bundle/Contents/MacOS/XLDApeDecoder
0x7c8000 - 0x7caff3 +jp.tmkk.XLDFlacDecoder ??? (1.0) /Applications/XLD.app/Contents/PlugIns/XLDFlacDecoder.bundle/Contents/MacOS/XLDFlacDecoder
0x7cf000 - 0x7d4fd3 +Ogg ??? (???) /Applications/XLD.app/Contents/Frameworks/Ogg.framework/Versions/A/Ogg
0x7db000 - 0x7defff +jp.tmkk.XLDFlacOutput ??? (1.0) /Applications/XLD.app/Contents/PlugIns/XLDFlacOutput.bundle/Contents/MacOS/XLDFlacOutput
0x7e4000 - 0x7e9fff +jp.tmkk.XLDHEAACOutput ??? (1.0) /Applications/XLD.app/Contents/PlugIns/XLDHEAACOutput.bundle/Contents/MacOS/XLDHEAACOutput
0x7ee000 - 0x7efffb +jp.tmkk.XLDLibsndfileDecoder ??? (1.0) <A3003289-D079-46A0-ABA4-C23BCADEF830> /Applications/XLD.app/Contents/PlugIns/XLDLibsndfileDecoder.bundle/Contents/MacOS/XLDLibsndfileDecoder
0x7f4000 - 0x7f5ffb +jp.tmkk.XLDMP3Decoder ??? (1.0) /Applications/XLD.app/Contents/PlugIns/XLDMP3Decoder.bundle/Contents/MacOS/XLDMP3Decoder
0x7fa000 - 0x7fafff +jp.tmkk.XLDSparkleUpdater ??? (1.0) <FEC6C495-3DB7-4083-B9FD-DE45448D9EBC> /Applications/XLD.app/Contents/PlugIns/XLDSparkleUpdater.bundle/Contents/MacOS/XLDSparkleUpdater
0x2559000 - 0x25a0fd7 +FLAC ??? (???) /Applications/XLD.app/Contents/Frameworks/FLAC.framework/Versions/A/FLAC
0x25bd000 - 0x25c4fef +jp.tmkk.XLDShortenDecoder ??? (1.0) /Applications/XLD.app/Contents/PlugIns/XLDShortenDecoder.bundle/Contents/MacOS/XLDShortenDecoder
0x25cc000 - 0x25dffff +org.andymatuschak.Sparkle 1.5 Beta (bzr) (1.5) <C1C2F3B9-7EC8-116D-B7C6-4900BAAF3197> /Applications/XLD.app/Contents/PlugIns/XLDSparkleUpdater.bundle/Contents/Frameworks/Sparkle.framework/Versions/A/Sparkle
0x25ed000 - 0x25f0ff3 +jp.tmkk.XLDTtaDecoder ??? (1.0) /Applications/XLD.app/Contents/PlugIns/XLDTtaDecoder.bundle/Contents/MacOS/XLDTtaDecoder
0x25f5000 - 0x25f7ff3 +jp.tmkk.XLDWavpackDecoder ??? (1.0) <ADCD0EC9-B288-4A67-94C4-18A9F7C1F930> /Applications/XLD.app/Contents/PlugIns/XLDWavpackDecoder.bundle/Contents/MacOS/XLDWavpackDecoder
0x12f8d000 - 0x12fc5fff +com.yourcompany.yourcocoabundle ??? (1.0) /Applications/XLD.app/Contents/PlugIns/XLDLameOutput.bundle/Contents/MacOS/XLDLameOutput
0x12fe2000 - 0x13097fe7 libcrypto.0.9.7.dylib ??? (???) <4917E4F2-817F-5AC4-3FBE-54BC96360448> /usr/lib/libcrypto.0.9.7.dylib
0x130dd000 - 0x130fcfff +jp.tmkk.XLDVorbisOutput ??? (1.0) <1B74F58F-4102-47D9-BB81-3486963A8C84> /Applications/XLD.app/Contents/PlugIns/XLDVorbisOutput.bundle/Contents/MacOS/XLDVorbisOutput
0x13229000 - 0x13252fe3 +WavPack ??? (???) <A9286F5E-D2B3-4AA4-95E6-9E27AF1AD5B8> /Applications/XLD.app/Contents/Frameworks/WavPack.framework/Versions/A/WavPack
0x13261000 - 0x13264fff +jp.tmkk.XLDWavpackOutput ??? (1.0) <55E6C932-1F36-40CA-BC9E-16612B36789F> /Applications/XLD.app/Contents/PlugIns/XLDWavpackOutput.bundle/Contents/MacOS/XLDWavpackOutput
0x8fe00000 - 0x8fe4162b dyld 132.1 (???) <211AF0DD-42D9-79C8-BB6A-1F4BEEF4B4AB> /usr/lib/dyld
0x90003000 - 0x9000eff7 libCSync.A.dylib ??? (???) <9292E6E3-70C1-1DD7-4213-1044F0FA8381> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x9000f000 - 0x9000fff7 com.apple.vecLib 3.5 (vecLib 3.5) <17BEEF92-DF30-CD52-FD65-0B7B43B93617> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x90057000 - 0x900ffffb com.apple.QD 3.33 (???) <196CDBA6-5B87-2767-DD57-082D71B0A5C7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x9010e000 - 0x9010eff7 com.apple.Accelerate.vecLib 3.5 (vecLib 3.5) <3E039E14-2A15-56CC-0074-EE59F9FBB913> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x9010f000 - 0x9011fff7 libsasl2.2.dylib ??? (???) <C8744EA3-0AB7-CD03-E639-C4F2B910BE5D> /usr/lib/libsasl2.2.dylib
0x90120000 - 0x90148ff7 libxslt.1.dylib ??? (???) <769EF4B2-C1AD-73D5-AAAD-1564DAEA77AF> /usr/lib/libxslt.1.dylib
0x90433000 - 0x90474ff7 libRIP.A.dylib ??? (???) <9F0ECE75-1F03-60E4-E29C-136A27C13F2E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x90475000 - 0x907dcff7 com.apple.QuartzCore 1.6.1 (227.8) <8B90AB08-46A4-1C5C-4E71-C6AB652477B9> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x90827000 - 0x90928fe7 libxml2.2.dylib ??? (???) <B4C5CD68-405D-0F1B-59CA-5193D463D0EF> /usr/lib/libxml2.2.dylib
0x90929000 - 0x909fafe3 ColorSyncDeprecated.dylib ??? (???) <1CEB1F35-EF10-A63D-AD9E-D7BD391D4719> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
0x909fb000 - 0x90a16ff7 libPng.dylib ??? (???) <3F8682CD-C05B-607D-96E7-767646C77DB8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x90ae4000 - 0x90e07fef com.apple.HIToolbox 1.6.2 (???) <E02640B9-7BC3-A4B4-6202-9E4127DDFDD6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x90e38000 - 0x90f02fef com.apple.CoreServices.OSServices 352 (352) <D9F21CA4-EED0-705F-8F3C-F1322D114B52> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x90f03000 - 0x90f85ffb SecurityFoundation ??? (???) <29C27E0E-B2B3-BF6B-B1F8-5783B8B01535> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x90fb2000 - 0x91222ffb com.apple.Foundation 6.6.1 (751.14) <CD815A50-BB33-5AA1-DD73-A5B07D394DDA> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x91223000 - 0x91235ff7 com.apple.MultitouchSupport.framework 204.9 (204.9) <B639F02B-33CC-150C-AE8C-1007EA7648F9> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x91236000 - 0x91239ff7 libCGXType.A.dylib ??? (???) <483FCF1C-066B-D210-7355-ABC48CA9DB2F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x9123a000 - 0x9123aff7 liblangid.dylib ??? (???) <B99607FC-5646-32C8-2C16-AFB5EA9097C2> /usr/lib/liblangid.dylib
0x9123b000 - 0x9128bff7 com.apple.framework.familycontrols 2.0 (2.0) <E6CAB425-3E40-65A3-0C23-150C26E9CBBF> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0x912ab000 - 0x912e0ff7 libcups.2.dylib ??? (???) <BE4E095C-EECA-017E-11AA-C65F4D2B15C8> /usr/lib/libcups.2.dylib
0x9133a000 - 0x9133cff7 libRadiance.dylib ??? (???) <462903E2-2E77-FAE5-4ED6-829AAB1980A4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x913d8000 - 0x913dcff7 libGIF.dylib ??? (???) <83FB0DCC-355F-A930-E570-0BD95086CC59> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x913dd000 - 0x913e0ff7 libCoreVMClient.dylib ??? (???) <A89D7A78-8FB0-2BDF-30DB-A35E04A6186B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x91501000 - 0x91527fff com.apple.DictionaryServices 1.1.1 (1.1.1) <02709230-9B37-C743-6E27-3FCFD18211F8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x91599000 - 0x9168bff7 libcrypto.0.9.8.dylib ??? (???) <792B8722-3091-5E9F-E25F-67499CFE0599> /usr/lib/libcrypto.0.9.8.dylib
0x9173c000 - 0x9173cff7 com.apple.Cocoa 6.6 (???) <EA27B428-5904-B00B-397A-185588698BCC> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x9173d000 - 0x91786fe7 libTIFF.dylib ??? (???) <5864AE5B-EAEB-F8B6-18FB-3D27B7895A4C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x91836000 - 0x91856fe7 com.apple.opencl 12 (12) <2DB56F60-577B-6724-5708-7B082F62CC0F> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x91857000 - 0x918b1ff7 com.apple.framework.IOKit 2.0 (???) <1BE07087-27D5-0E62-F06B-007C2BED4073> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x91909000 - 0x9192dff7 libJPEG.dylib ??? (???) <649E1974-A527-AC0B-B3F4-B4DC30484070> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x9192e000 - 0x91acbfef com.apple.JavaScriptCore 6531.21 (6531.21.9) <FF236E3F-A016-2AEB-3E62-7108E76EF825> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x91c26000 - 0x91da8fe7 libicucore.A.dylib ??? (???) <2B0182F3-F459-B452-CC34-46FE73ADE348> /usr/lib/libicucore.A.dylib
0x92097000 - 0x92253fef com.apple.ImageIO.framework 3.0.1 (3.0.1) <598CF4F9-7542-E1A7-26D2-584933497A2E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x92296000 - 0x922a0fe7 com.apple.audio.SoundManager 3.9.3 (3.9.3) <5F494955-7290-2D91-DA94-44B590191771> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x922e8000 - 0x922f6fe7 libz.1.dylib ??? (???) <7B7A02AB-DA99-6180-880E-D28E4F9AA8EB> /usr/lib/libz.1.dylib
0x922f7000 - 0x92393fe7 com.apple.ApplicationServices.ATS 4.1 (???) <EA26375D-8276-9671-645D-D28CAEC95292> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x926b9000 - 0x926f6ff7 com.apple.SystemConfiguration 1.10.1 (1.10.1) <BA676C76-6AAD-F630-626D-B9248535294D> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x92708000 - 0x9270dff7 com.apple.OpenDirectory 10.6 (10.6) <92582807-E8F3-3DD9-EB42-4195CFB754A1> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x9270e000 - 0x92723fff com.apple.ImageCapture 6.0 (6.0) <3F31833A-38A9-444E-02B7-17619CA6F2A0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x928a7000 - 0x92955ff3 com.apple.ink.framework 1.3.1 (105) <CA3FBDC3-4BBA-7BD9-0777-A7B0751292CD> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x92956000 - 0x92972fe3 com.apple.openscripting 1.3.1 (???) <DA16DE48-59F4-C94B-EBE3-7FAF772211A2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x92973000 - 0x929b6ff7 com.apple.NavigationServices 3.5.3 (181) <28CDD978-030E-7D4A-5334-874A8EBE6C29> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x929b7000 - 0x92a26ff7 libvMisc.dylib ??? (???) <59243A8C-2B98-3E71-8032-884D4853E79F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x92a29000 - 0x92a35ff7 libkxld.dylib ??? (???) <3D2C5BA3-6A8D-C861-B346-0E19942D9AF1> /usr/lib/system/libkxld.dylib
0x92a36000 - 0x92a6cfff libtidy.A.dylib ??? (???) <DDFAB560-3883-A6A2-7BDD-D91730982B48> /usr/lib/libtidy.A.dylib
0x92a6d000 - 0x92abdfe7 libGLU.dylib ??? (???) <659ADCA2-10EC-59BD-1B0A-4928A965F1D1> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x92b3a000 - 0x92b8bff7 com.apple.HIServices 1.8.0 (???) <B8EC13DB-A81A-91BF-8C82-66E840C64C91> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x92b8c000 - 0x92b8cff7 com.apple.Carbon 150 (152) <608A04AB-F35D-D2EB-6629-16B88FB32074> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x92b8d000 - 0x92b8dff7 com.apple.Accelerate 1.5 (Accelerate 1.5) <F642E7A0-3720-FA19-0190-E6DBD9EF2D9B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x92b8e000 - 0x92b8fff7 com.apple.TrustEvaluationAgent 1.1 (1) <6C04C4C5-667E-2EBE-EB96-5B67BD4B2185> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x92bc3000 - 0x92bc9ff7 libCGXCoreImage.A.dylib ??? (???) <5233872A-EAC6-1D42-3959-6CE6C5DEB931> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
0x92bd2000 - 0x92c6ffe3 com.apple.LaunchServices 362 (362) <8BE1C1A1-BF71-CE07-F3FB-6057D47AF461> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x92ca8000 - 0x92f0aff7 com.apple.security 6.0 (36910) <32B8FA26-CD73-4C45-C15A-EF8406D51FCC> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x92f0b000 - 0x92f51ff7 libauto.dylib ??? (???) <85670A64-3B67-8162-D441-D8E0BE15CA94> /usr/lib/libauto.dylib
0x92f5a000 - 0x93088fe7 com.apple.CoreData 102.1 (250) <F33FF4A1-D7F9-4F6D-3153-E5F2588479EB> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x93089000 - 0x93109feb com.apple.SearchKit 1.3.0 (1.3.0) <9E18AEA5-F4B4-8BE5-EEA9-818FC4F46FD9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x940d2000 - 0x940d6ff7 IOSurface ??? (???) <C11D3FF3-EB51-A07D-EF24-9C2004115724> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x940d7000 - 0x94901fe7 com.apple.WebCore 6531.21 (6531.21.8) <A1527339-942C-164F-03CB-0949EEA144C4> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x94942000 - 0x94942ff7 com.apple.ApplicationServices 38 (38) <8012B504-3D83-BFBB-DA65-065E061CFE03> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x9499e000 - 0x949d3ff7 libGLImage.dylib ??? (???) <A6007BF7-BF3C-96DC-C435-849C6B88C58A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x949db000 - 0x949fbfe7 libresolv.9.dylib ??? (???) <A48921CB-3FA7-3071-AF9C-2D86FB493A3A> /usr/lib/libresolv.9.dylib
0x949fc000 - 0x94ad9ff7 com.apple.vImage 4.0 (4.0) <64597E4B-F144-DBB3-F428-0EC3D9A1219E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x94add000 - 0x94c81feb libSystem.B.dylib ??? (???) <D45B91B2-2B4C-AAC0-8096-1FC48B7E9672> /usr/lib/libSystem.B.dylib
0x94cf7000 - 0x94e6efef com.apple.CoreFoundation 6.6.1 (550.13) <AE9FC6F7-F0B2-DE58-759E-7DB89C021A46> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x94e6f000 - 0x94e87ff7 com.apple.CFOpenDirectory 10.6 (10.6) <1537FB4F-C112-5D12-1E5D-3B1002A4038F> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x94e93000 - 0x94f2bfe7 edu.mit.Kerberos 6.5.9 (6.5.9) <73EC847F-FF44-D542-2AD5-97F6C8D48F0B> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x94f2c000 - 0x94f5dff3 libTrueTypeScaler.dylib ??? (???) <6C8916A2-8F85-98E0-AAD5-0020C39C0FC9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x9548e000 - 0x954eefe7 com.apple.CoreText 3.1.0 (???) <79FD1B5C-2F93-4C5D-B07B-4DD9088E67DE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x954ef000 - 0x95529ffb libFontRegistry.dylib ??? (???) <72342297-E8D6-B071-A752-014134129282> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x9552a000 - 0x9552dfe7 libmathCommon.A.dylib ??? (???) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
0x9554e000 - 0x95592fe7 com.apple.Metadata 10.6.2 (507.4) <DBCBAE7D-7B34-7806-C0B9-1E6E6D45562F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x95a42000 - 0x95a45ffb com.apple.help 1.3.1 (41) <67F1F424-3983-7A2A-EC21-867BE838E90B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x95a46000 - 0x95a53ff7 com.apple.opengl 1.6.5 (1.6.5) <0AE8B897-8A80-2C14-D6FC-DC21AC423234> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x95ac9000 - 0x95badff7 com.apple.WebKit 6531.21 (6531.21.8) <E2506911-46B5-0CFE-0C49-77EA8F216E8C> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x95bae000 - 0x95ecdfe7 com.apple.CoreServices.CarbonCore 861.2 (861.2) <A9077470-3786-09F2-E0C7-F082B7F97838> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x95ece000 - 0x95eceff7 com.apple.CoreServices 44 (44) <AC35D112-5FB9-9C8C-6189-5F5945072375> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x95ed1000 - 0x95f3bfe7 libstdc++.6.dylib ??? (???) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
0x95f5e000 - 0x96052fe7 libiconv.2.dylib ??? (???) <0C578460-3929-29DD-585A-DB1E0C977425> /usr/lib/libiconv.2.dylib
0x96279000 - 0x962a3ff7 com.apple.shortcut 1.1 (1.1) <B0514FA9-7CAE-AD94-93CA-7B2A2C5F7B8A> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x96445000 - 0x9644cfff com.apple.print.framework.Print 6.0 (237) <7A06B15C-B835-096E-7D96-C2FE8F0D21E1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x9644d000 - 0x9648ffe7 libvDSP.dylib ??? (???) <8F8FFFB3-81E3-2969-5688-D5B0979182E6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x96490000 - 0x964c3ff7 com.apple.AE 496.1 (496.1) <1AC75AE2-AF94-2458-0B94-C3BB0115BA4B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x965bc000 - 0x96600ff3 com.apple.coreui 2 (113) <D0FA9B36-3708-D5BF-0CC3-6CC1909BC8E6> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x96601000 - 0x96615ffb com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <57DD5458-4F24-DA7D-0927-C3321A65D743> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x96616000 - 0x96742fe3 com.apple.audio.toolbox.AudioToolbox 1.6.1 (1.6.1) <C226DF5C-35B0-98B8-95ED-FE5FE24E62C8> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x96743000 - 0x9674dff7 libGL.dylib ??? (???) <76A207FE-889A-CF1B-AF9A-795EEE5A463E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x9674e000 - 0x967fbfe7 libobjc.A.dylib ??? (???) <DF8E4CFA-3719-3415-0BF1-E8C5E561C3B1> /usr/lib/libobjc.A.dylib
0x96913000 - 0x96d48ff7 libLAPACK.dylib ??? (???) <5E2D2283-57DE-9A49-1DB0-CD027FEFA6C2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x96d87000 - 0x96e36ff3 com.apple.ColorSync 4.6.2 (4.6.2) <F3F097AC-FDB7-3357-C64F-E28BECF4C15F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x96e6c000 - 0x96f62ff7 libGLProgrammability.dylib ??? (???) <82D03736-D30C-C013-BBB1-20ED9687D47F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x970a3000 - 0x970a9fff com.apple.CommonPanels 1.2.4 (91) <2438AF5D-067B-B9FD-1248-2C9987F360BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x970aa000 - 0x9788d4b7 com.apple.CoreGraphics 1.536.12 (???) <263EB5FC-DEAD-7C5B-C486-EC86C173F952> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x979db000 - 0x97ab5ff3 com.apple.DesktopServices 1.5.3 (1.5.3) <DA02AC94-7B0C-BD75-2305-C46A307A5FB0> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x97ac1000 - 0x97aceff7 com.apple.NetFS 3.2.1 (3.2.1) <5E61A00B-FA16-9D99-A064-47BDC5BC9A2B> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x97acf000 - 0x97aedff7 com.apple.CoreVideo 1.6.0 (43.1) <1FB01BE0-B013-AE86-A063-481BB547D2F5> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x97aee000 - 0x97b7ffe7 com.apple.print.framework.PrintCore 6.1 (312.3) <6D4322AF-703C-CC19-77B4-53E6D3BB18D4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x97b80000 - 0x97bfafef com.apple.audio.CoreAudio 3.2.2 (3.2.2) <1F97B48A-327B-89CC-7C01-3865179716E0> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x97bfb000 - 0x97bfcff7 com.apple.audio.units.AudioUnit 1.6.1 (1.6.1) <3A08510C-07F7-1A09-D6ED-1A488203ACCC> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x97cd0000 - 0x97cf2fef com.apple.DirectoryService.Framework 3.6 (621.1) <3ED4949F-9604-C109-6586-5CE5F421182B> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x97cf3000 - 0x97dacfe7 libsqlite3.dylib ??? (???) <16CEF8E8-8C9A-94CD-EF5D-05477844C005> /usr/lib/libsqlite3.dylib
0x97dad000 - 0x97db6ff7 com.apple.DiskArbitration 2.3 (2.3) <E9C40767-DA6A-6CCB-8B00-2D5706753000> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x97db7000 - 0x981cdff7 libBLAS.dylib ??? (???) <C4FB303A-DB4D-F9E8-181C-129585E59603> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x981f7000 - 0x9825bffb com.apple.htmlrendering 72 (1.1.4) <4D451A35-FAB6-1288-71F6-F24A4B6E2371> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x9839b000 - 0x98694ff3 com.apple.RawCamera.bundle 2.3.0 (505) <1C7CEA30-FFE2-B4DE-98CE-D6518DF1E54B> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x98a33000 - 0x98adafe7 com.apple.CFNetwork 454.5 (454.5) <A7E78E62-0C59-CE57-73D2-C4E60527781C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x98adb000 - 0x98ae5ff7 com.apple.HelpData 2.0.4 (34) <9128FFEB-0F6C-B273-FCF4-D87A20227345> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x98b9e000 - 0x98c51fff libFontParser.dylib ??? (???) <FAD5E96D-CF93-CC86-6B30-A6594B930772> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x98c52000 - 0x98c5cffb com.apple.speech.recognition.framework 3.11.1 (3.11.1) <EC0E69C8-A121-70E8-43CF-E6FC4C7779EC> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x98c5d000 - 0x98c5fff7 com.apple.securityhi 4.0 (36638) <962C66FB-5BE9-634E-0810-036CB340C059> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x98c60000 - 0x98cadfeb com.apple.DirectoryService.PasswordServerFramework 6.0 (6.0) <BF66BA5D-BBC8-78A5-DBE2-F9DE3DD1D775> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
0x98cae000 - 0x9958cff7 com.apple.AppKit 6.6.3 (1038.25) <72A9AA47-8DCB-DB07-64F5-F837E98C62D8> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x9958d000 - 0x9959eff7 com.apple.LangAnalysis 1.6.6 (1.6.6) <7A3862F7-3730-8F6E-A5DE-8E2CCEA979EF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x9959f000 - 0x995a3ff7 libGFXShared.dylib ??? (???) <79F4F60E-0A6D-CE9C-282E-FA85825449E3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x995a4000 - 0x995b8fe7 libbsm.0.dylib ??? (???) <14CB053A-7C47-96DA-E415-0906BA1B78C9> /usr/lib/libbsm.0.dylib
0xffff0000 - 0xffff1fff libSystem.B.dylib ??? (???) <D45B91B2-2B4C-AAC0-8096-1FC48B7E9672> /usr/lib/libSystem.B.dylib
Model: MacBook4,1, BootROM MB41.00C1.B00, 2 processors, Intel Core 2 Duo, 2.4 GHz, 4 GB, SMC 1.31f0
Graphics: Intel GMA X3100, GMA X3100, Built-In, 144 MB
Memory Module: global_name
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x88), Broadcom BCM43xx 1.0 (5.10.91.26)
Bluetooth: Version 2.2.4f3, 2 service, 1 devices, 1 incoming serial ports
Network Service: FireWire, FireWire, fw0
Network Service: AirPort, AirPort, en1
Serial ATA Device: ST9500325AS, 465.76 GB
Parallel ATA Device: MATSHITADVD-R UJ-867, 606.6 MB
USB Device: Built-in iSight, 0x05ac (Apple Inc.), 0x8501, 0xfd400000
USB Device: Apple Internal Keyboard / Trackpad, 0x05ac (Apple Inc.), 0x0229, 0x5d200000
USB Device: IR Receiver, 0x05ac (Apple Inc.), 0x8242, 0x5d100000
USB Device: Bluetooth USB Host Controller, 0x05ac (Apple Inc.), 0x8205, 0x1a100000
I tried the same with 11/29/2009 version of XLD and it worked fine.
thx for the hint. what is the process name for cdparanoia? is there a way to manually quit it via terminal/activity monitor?
would there be any way to have some sort or progress bar or status report of cdparanoia?
Yes, cdparanoia will hang the same way in MAX. The problem with XLD is the disappearing disk drive after quitting during a hung up rip.
I just tried again, and opening up Rip (http://sbooth.org/Rip/) (iTunes doesn't work) will allow you to eject the disk with it's eject button. Quite a bit more convenient than restarting the computer.
thx for the tip. at least rip gives me the following error message when trying to eject disl: " Operation could not be completed. (Mach error 49168 - (os/unix) mount device busy)"
any unix-ji-jutsu that would fix this without restart?!
Is that even after quitting XLD?
I get that message when XLD is open, but after quitting XLD, Rip will eject the disk for me without a restart. Reinsert the disk, and everything is back to normal.
You could have started Disk Utility (/Applications/Utilities/Disk Utility.app) instead.
yes! the xld icon will also stay in the task switcher bar.
disk utility will not start until I reboot the system.
I've been trying to get a secure rip of a couple of cds with XLD in OS X (10.5.8) and there seems to be a problem with this one disk.
It will recognise the disk and all, but when I eventually hit "encode" I get blank progress box, and then the app just hangs. iTunes recognises and rips the disk no problem, and it isn't scratched.
To figure out what the problem is, I installed and set up EAC on a windows PC, and ripped the album. It was the UK special edition of Queens of the Stone Age's Songs for the Deaf. Unbeknownst to me,
there is a hidden track on this album located in the pre-gap of track 1. The only way to hear this track on a regular CD player is to start track one playing, and then rewind. iTunes doesn't detect pregaps (?), so it doesn't have a problem. I checked "exclude pregap in output" in XLD, and low and behold, the track rips. However, it isn't possible to get a secure rip this way.
So, I'm thinking that since EAC has the ability to detect these kinds of tracks, and XLD doesn't (?), then this is probably what is causing the issue. The only thing to do is hope that the bug is fixed in later versions of XLD. For now, the only solution I have is to use EAC on a windows PC.
Below is the log from the rip of Track 1 that excluded the pregap:
XLD Version 20100117 (115.3)
Macbook 1.83Ghz Intel core2duo running OS X 10.5.8
Memory: 2 GB 667 Mhz DDR2 SDRAM
X Lossless Decoder version 20100117 (115.3)
XLD extraction logfile from 2010-01-22 16:07:22 +0000
Queens Of The Stone Age / Songs For The Deaf [UK]
Used drive : MATSHITA DVD-R UJ-857E (revision ZA0E)
Use cdparanoia mode : YES (CDParanoia III 10.2 engine)
Disable audio cache : OK for the drive with cache less than 2750KB
Make use of C2 pointers : NO
Max retry count : 100
TOC of the extracted CD
Track | Start | Length | Start sector | End sector
1 | 01:32:61 | 03:12:37 | 6961 | 21397
2 | 04:45:23 | 04:38:56 | 21398 | 42303
3 | 09:24:04 | 03:18:29 | 42304 | 57182
4 | 12:42:33 | 05:52:34 | 57183 | 83616
5 | 18:34:67 | 06:15:58 | 83617 | 111799
6 | 24:50:50 | 01:19:32 | 111800 | 117756
7 | 26:10:07 | 03:06:19 | 117757 | 131725
8 | 29:16:26 | 03:07:11 | 131726 | 145761
9 | 32:23:37 | 02:50:15 | 145762 | 158526
10 | 35:13:52 | 04:04:66 | 158527 | 176892
11 | 39:18:43 | 06:04:68 | 176893 | 204260
12 | 45:23:36 | 03:16:14 | 204261 | 218974
13 | 48:39:50 | 06:42:36 | 218975 | 249160
14 | 55:22:11 | 05:37:71 | 249161 | 274506
15 | 61:00:07 | 03:38:00 | 274507 | 290856
16 | 64:38:07 | 02:35:46 | 290857 | 302527
Track 01
Filename : /Users/David/Desktop/01 Queens Of The Stone Age - You Think I Ain't Worth A Dollar But I Feel Like A Millionaire.m4a
Pre-gap length : 01:34:61
CRC32 hash (test run) : E918529B
CRC32 hash : E918529B
CRC32 hash (skip zero) : 80E71ED3
Statistics
Read error : 0
Skipped (treated as error) : 0
Edge jitter error (maybe fixed) : 0
Atom jitter error (maybe fixed) : 0
Drift error (maybe fixed) : 0
Dropped bytes error (maybe fixed) : 0
Duplicated bytes error (maybe fixed) : 0
Inconsistency in error sectors : 0
No errors occurred
End of status report
I noticed there were three instances of problems with UJ-835E drives, which is what I have. Same problems over here, using offset of 0 just like every other instance I saw here. Using 102 (which all almost all Panasonic DVD drives use and certainly all UJ-8* series) everything works fine and dandy. Happy ripping!
I'm having a problem where XLD fails to rip the pregap for track one of a cd, regardless of whether I have "Include pre-gap for all tracks" or "Include pre-gap except for HTOA" set. The CD in question has a pre-gap of 00:02:00 for track one. XLD does not show this pregap on the main interface, it doesn't rip it, and it doesn't appear in the cue files. It does, however, appear correctly detected in the log file.
How do I make XLD rip the track one pregap and include it on the cue sheet properly? Is there a bug here or might I be doing something wrong?
I've attached the log, truncated after track one. You can compare the TOC given in the log to the TOC as reported by musicbrainz here: http://musicbrainz.org/show/cdtoc/?cdtocid=404037 (http://musicbrainz.org/show/cdtoc/?cdtocid=404037) . XLD seems to be just ignoring the 150 sectors of the pregap entirely and starting the numbering from _after_ that, even though later it shows that it knows there is pregap there.
X Lossless Decoder version 20100711 (120.5)
XLD extraction logfile from 2010-08-02 16:51:42 -0400
Big Little Dipper Dipper / Hockey Star
Used drive : MATSHITA DVD-R UJ-868 (revision KB19)
Gap status : Analyzed, Appended
1 | 00:00:00 | 03:32:71 | 0 | 15970
2 | 03:32:71 | 02:30:19 | 15971 | 27239
3 | 06:03:15 | 02:43:59 | 27240 | 39523
4 | 08:46:74 | 01:33:52 | 39524 | 46550
5 | 10:20:51 | 03:42:27 | 46551 | 63227
6 | 14:03:03 | 01:42:24 | 63228 | 70901
7 | 15:45:27 | 02:22:53 | 70902 | 81604
8 | 18:08:05 | 02:14:62 | 81605 | 91716
9 | 20:22:67 | 04:12:43 | 91717 | 110659
10 | 24:35:35 | 01:40:70 | 110660 | 118229
11 | 26:16:30 | 03:56:30 | 118230 | 135959
12 | 30:12:60 | 02:03:69 | 135960 | 145253
13 | 32:16:54 | 11:10:54 | 145254 | 195557
Track 01
Filename : 01 Big Little Dipper Dipper - Hockey Star.flac
Pre-gap length : 00:02:00
CRC32 hash (test run) : 36092D05
CRC32 hash : 36092D05
CRC32 hash (skip zero) : DE11151C
AccurateRip signature : 6D5821E8
->Track not present in AccurateRip database.
Statistics
Read error : 0
{snip}
No errors occurred
Any hidden track will begin after 150 frames, so there is nothing wrong; your disc does not contain a hidden track.
I have a problem with the "format of filename" when ripping a CD to FLAC (single file + cue).
When I transcode from FLAC to AAC I use %A/%y - %T/%n %t with no problems.
When I rip a CD I use %A/%y - %T/%A - %T and it doesn't work. The %y - %T creates a folder named "Unknown Year" - Album Title (this part works). I make sure the year tag is filled before I rip so there seems to be a problem.
Preference choice isn't saved until XLD is restarted.
I had the "Delete original files after successful conversion" checked and the "Warn before deleting" sub-option also checked. I turned off the "Warn before deleting" sub-option and closed the preference pane, but XLD still gave me file deletion warnings until I restarted XLD.
If this is normal functionality (and I don't think so - most Mac programs save preferences as soon as they're changed), then an Apply button needs to be added to make the preference changes permanent without having to restart XLD.
Bug (crash)
I selected 3 multi-part FLACs with the "Edit tags before convert" option checked. When I invoked XLD, I got the metadata dialog of the embedded tracks (I was hitting Next and Prev; all the embedded tracks seem to be there). When I hit OK, XLD crashed, deleting the first source FLAC (I had the delete option on). The deleted source file was nowhere to be found; not even in the trash.
The crash report:
Process: XLD [27955]
Path: /Volumes/iMac Clone 1/Applications/XLD.app/Contents/MacOS/XLD
Version: 20101128 (126.0)
Parent Process: launchd [266]
Date/Time: 2010-12-07 13:00:38.303 -0500
OS Version: Mac OS X 10.6.5 (10H574)
Report Version: 6
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000038
0 libSystem.B.dylib 0x97842acf flockfile + 22
1 libSystem.B.dylib 0x97842e6b fread + 64
2 jp.tmkk.XLDFlacDecoder 0x004f93c2 -[XLDFlacDecoder openFile:] + 107
3 jp.tmkk.XLD 0x00037203 -[XLDConverterTask beginConvert] + 307
4 jp.tmkk.XLD 0x00032d5a -[XLDQueue convertFinished:] + 554
5 com.apple.Foundation 0x902e4e80 __NSThreadPerformPerform + 705
6 com.apple.CoreFoundation 0x914874cb __CFRunLoopDoSources0 + 1563
7 com.apple.CoreFoundation 0x91484f8f __CFRunLoopRun + 1071
8 com.apple.CoreFoundation 0x91484464 CFRunLoopRunSpecific + 452
9 com.apple.CoreFoundation 0x91484291 CFRunLoopRunInMode + 97
10 com.apple.HIToolbox 0x96287f58 RunCurrentEventLoopInMode + 392
11 com.apple.HIToolbox 0x96287d0f ReceiveNextEventCommon + 354
12 com.apple.HIToolbox 0x96287b94 BlockUntilNextEventMatchingListInMode + 81
13 com.apple.AppKit 0x90a4178d _DPSNextEvent + 847
14 com.apple.AppKit 0x90a40fce -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 156
15 com.apple.AppKit 0x90a03247 -[NSApplication run] + 821
16 com.apple.AppKit 0x909fb2d9 NSApplicationMain + 574
17 jp.tmkk.XLD 0x00003036 _start + 216
18 jp.tmkk.XLD 0x00002f5d start + 41
0 libSystem.B.dylib 0x97834982 kevent + 10
1 libSystem.B.dylib 0x9783509c _dispatch_mgr_invoke + 215
2 libSystem.B.dylib 0x97834559 _dispatch_queue_invoke + 163
3 libSystem.B.dylib 0x978342fe _dispatch_worker_thread2 + 240
4 libSystem.B.dylib 0x97833d81 _pthread_wqthread + 390
5 libSystem.B.dylib 0x97833bc6 start_wqthread + 30
Thread 2:
0 libSystem.B.dylib 0x9780e442 close + 10
1 libSystem.B.dylib 0x97839031 fclose + 133
2 jp.tmkk.XLDAlacOutput 0x0072db68 -[XLDAlacOutputTask optimizeAtoms] + 4298
3 jp.tmkk.XLDAlacOutput 0x0072f0f6 -[XLDAlacOutputTask finalize] + 5375
4 jp.tmkk.XLD 0x000365f6 -[XLDConverterTask convert] + 4966
5 com.apple.Foundation 0x902cebf0 -[NSThread main] + 45
6 com.apple.Foundation 0x902ceba0 __NSThread__main__ + 1499
7 libSystem.B.dylib 0x9783b85d _pthread_start + 345
8 libSystem.B.dylib 0x9783b6e2 thread_start + 34
Thread 3:
0 jp.tmkk.XLDAlacOutput 0x0072ca0d -[XLDAlacOutputTask writeBuffer:frames:] + 129
1 jp.tmkk.XLD 0x00035512 -[XLDConverterTask convert] + 642
2 com.apple.Foundation 0x902cebf0 -[NSThread main] + 45
3 com.apple.Foundation 0x902ceba0 __NSThread__main__ + 1499
4 libSystem.B.dylib 0x9783b85d _pthread_start + 345
5 libSystem.B.dylib 0x9783b6e2 thread_start + 34
Thread 4:
0 libSystem.B.dylib 0x9786c3aa pwrite$UNIX2003 + 10
1 ....audio.toolbox.AudioToolbox 0x94f69090 UnixFile_DataSource::WriteBytes(unsigned short, long long, unsigned long, void const*, unsigned long*) + 176
2 ....audio.toolbox.AudioToolbox 0x94f695ae Cached_DataSource::WriteBytes(unsigned short, long long, unsigned long, void const*, unsigned long*) + 450
3 ....audio.toolbox.AudioToolbox 0x94fbabcc MP4AudioFile::WritePackets(unsigned char, unsigned long, AudioStreamPacketDescription const*, long long, unsigned long*, void const*) + 620
4 ....audio.toolbox.AudioToolbox 0x94f65c94 AudioFileWritePackets + 187
5 ....audio.toolbox.AudioToolbox 0x94f76167 ExtAudioFile::WritePacketsFromCallback(long (*)(OpaqueAudioConverter*, unsigned long*, AudioBufferList*, AudioStreamPacketDescription**, void*), void*) + 297
6 ....audio.toolbox.AudioToolbox 0x94f76f2d ExtAudioFile::Write(unsigned long, AudioBufferList const*) + 225
7 ....audio.toolbox.AudioToolbox 0x94f6f3c5 ExtAudioFileWrite + 71
8 jp.tmkk.XLDAlacOutput 0x0072ca92 -[XLDAlacOutputTask writeBuffer:frames:] + 262
9 jp.tmkk.XLD 0x00035512 -[XLDConverterTask convert] + 642
10 com.apple.Foundation 0x902cebf0 -[NSThread main] + 45
11 com.apple.Foundation 0x902ceba0 __NSThread__main__ + 1499
12 libSystem.B.dylib 0x9783b85d _pthread_start + 345
13 libSystem.B.dylib 0x9783b6e2 thread_start + 34
Thread 5:
Thread 6:
0 libSystem.B.dylib 0x9783c0a6 __semwait_signal + 10
1 libSystem.B.dylib 0x97867ee5 nanosleep$UNIX2003 + 188
2 libSystem.B.dylib 0x97867e23 usleep$UNIX2003 + 61
3 com.apple.AppKit 0x90baafe1 -[NSUIHeartBeat _heartBeatThread:] + 2039
4 com.apple.Foundation 0x902cebf0 -[NSThread main] + 45
5 com.apple.Foundation 0x902ceba0 __NSThread__main__ + 1499
6 libSystem.B.dylib 0x9783b85d _pthread_start + 345
7 libSystem.B.dylib 0x9783b6e2 thread_start + 34
Thread 7:
0 libSystem.B.dylib 0x97833ba8 start_wqthread + 0
Thread 8:
0 libSystem.B.dylib 0x97833a12 __workq_kernreturn + 10
1 libSystem.B.dylib 0x97833fa8 _pthread_wqthread + 941
2 libSystem.B.dylib 0x97833bc6 start_wqthread + 30
Thread 9:
eax: 0xa0a66540 ebx: 0xa0a66540 ecx: 0x97814482 edx: 0xa0a5c50c
edi: 0x00000001 esi: 0x00000000 ebp: 0xbfffe478 esp: 0xbfffe460
ss: 0x0000001f efl: 0x00210286 eip: 0x97842acf cs: 0x00000017
cr2: 0x00000038
Binary Images:
0x1000 - 0x6dfe3 +jp.tmkk.XLD 20101128 (126.0) <6E24A7EA-FE2C-2C79-1A1E-8092C133A29A> /Volumes/iMac Clone 1/Applications/XLD.app/Contents/MacOS/XLD
0x8f000 - 0x9afff +CDDB ??? (???) /Volumes/iMac Clone 1/Applications/XLD.app/Contents/Frameworks/CDDB.framework/Versions/A/CDDB
0xa2000 - 0x103fcf +Musicbrainz ??? (???) /Volumes/iMac Clone 1/Applications/XLD.app/Contents/Frameworks/Musicbrainz.framework/Versions/A/Musicbrainz
0x161000 - 0x1bdfe7 +Sndfile ??? (???) <4F69600F-C387-4869-89C8-FAA1A7616FB8> /Volumes/iMac Clone 1/Applications/XLD.app/Contents/Frameworks/Sndfile.framework/Versions/A/Sndfile
0x1d3000 - 0x288fe7 libcrypto.0.9.7.dylib 0.9.7 (compatibility 0.9.7) <AACC86C0-86B4-B1A7-003F-2A0AF68973A2> /usr/lib/libcrypto.0.9.7.dylib
0x42a000 - 0x436ff7 +com.rogueamoeba.audio_hijack_server.hermes 2.2.6 (2.2.6) <E99CDC13-114A-DADD-658C-809B8BB59757> /usr/local/hermes/modules/Instant Hijack Server.hermesmodule/Contents/MacOS/Instant Hijack Server
0x4a4000 - 0x4aeff7 +com.unsanity.smartcrashreports Smart Crash Reports version 1.5 (1.5) /Library/InputManagers/Smart Crash Reports/Smart Crash Reports.bundle/Contents/MacOS/Smart Crash Reports
0x4bc000 - 0x4befff +net.culater.SIMBL 0.8.2 (8) /Library/InputManagers/SIMBL/SIMBL.bundle/Contents/MacOS/SIMBL
0x4c4000 - 0x4c5ffd +com.1passwd.InputManager 2.7.1 (7144) <7B962658-403D-9E08-21F7-EC4DD292E780> /Library/InputManagers/1PasswdIM/1PasswdIM.bundle/Contents/MacOS/1PasswdIM
0x4f6000 - 0x4f9ff7 +jp.tmkk.XLDFlacDecoder ??? (1.0) <5FCE7C45-3C14-4345-B339-A27F8F3A8F67> /Volumes/iMac Clone 1/Applications/XLD.app/Contents/PlugIns/XLDFlacDecoder.bundle/Contents/MacOS/XLDFlacDecoder
0x700000 - 0x707ff7 +jp.tmkk.XLDAacOutput ??? (1.0) <6468D5F6-2AB6-FF35-C559-174BDAC361B8> /Volumes/iMac Clone 1/Applications/XLD.app/Contents/PlugIns/XLDAacOutput.bundle/Contents/MacOS/XLDAacOutput
0x70d000 - 0x719ff7 +jp.tmkk.XLDAacOutput2 ??? (1.0) <59982F6D-1F3D-DD46-7BDF-718415CCC402> /Volumes/iMac Clone 1/Applications/XLD.app/Contents/PlugIns/XLDAacOutput2.bundle/Contents/MacOS/XLDAacOutput2
0x71f000 - 0x724ff7 +jp.tmkk.XLDAlacDecoder ??? (1.0) <FA1EBE57-8264-1DE8-83EC-ABD5FD6BD064> /Volumes/iMac Clone 1/Applications/XLD.app/Contents/PlugIns/XLDAlacDecoder.bundle/Contents/MacOS/XLDAlacDecoder
0x72a000 - 0x733ff7 +jp.tmkk.XLDAlacOutput ??? (1.0) <7C436CAD-08CF-9FC8-D56E-1A1C7C9AE674> /Volumes/iMac Clone 1/Applications/XLD.app/Contents/PlugIns/XLDAlacOutput.bundle/Contents/MacOS/XLDAlacOutput
0x739000 - 0x75bffa +jp.tmkk.XLDApeDecoder ??? (1.0) /Volumes/iMac Clone 1/Applications/XLD.app/Contents/PlugIns/XLDApeDecoder.bundle/Contents/MacOS/XLDApeDecoder
0x76c000 - 0x7b3fd7 +FLAC ??? (???) /Volumes/iMac Clone 1/Applications/XLD.app/Contents/Frameworks/FLAC.framework/Versions/A/FLAC
0x7c4000 - 0x7c6ff7 +Ogg ??? (???) <AC76D238-F8FC-CC14-8FBF-CC36626850D2> /Volumes/iMac Clone 1/Applications/XLD.app/Contents/Frameworks/Ogg.framework/Versions/A/Ogg
0x7c9000 - 0x7cdff7 +jp.tmkk.XLDFlacOutput ??? (1.0) <BF79E52E-7C4A-C6A5-8F96-9E61837BBC8A> /Volumes/iMac Clone 1/Applications/XLD.app/Contents/PlugIns/XLDFlacOutput.bundle/Contents/MacOS/XLDFlacOutput
0x7d3000 - 0x7d8ff7 +jp.tmkk.XLDHEAACOutput ??? (1.0) <7DAAEB64-13F1-1988-2434-947ABABACDF0> /Volumes/iMac Clone 1/Applications/XLD.app/Contents/PlugIns/XLDHEAACOutput.bundle/Contents/MacOS/XLDHEAACOutput
0x7de000 - 0x7dfffb +jp.tmkk.XLDLibsndfileDecoder ??? (1.0) <D0584CB5-71CB-4F56-BCE5-EA78569BA91D> /Volumes/iMac Clone 1/Applications/XLD.app/Contents/PlugIns/XLDLibsndfileDecoder.bundle/Contents/MacOS/XLDLibsndfileDecoder
0x7e4000 - 0x7e5ff7 +jp.tmkk.XLDMP3Decoder ??? (1.0) <AB512F41-0982-4B4A-9050-87DCD4EF9AF7> /Volumes/iMac Clone 1/Applications/XLD.app/Contents/PlugIns/XLDMP3Decoder.bundle/Contents/MacOS/XLDMP3Decoder
0x7ea000 - 0x7f1fef +jp.tmkk.XLDShortenDecoder ??? (1.0) /Volumes/iMac Clone 1/Applications/XLD.app/Contents/PlugIns/XLDShortenDecoder.bundle/Contents/MacOS/XLDShortenDecoder
0x7f9000 - 0x7f9ff7 +jp.tmkk.XLDSparkleUpdater ??? (1.0) <A5BB9D62-1F1D-46FA-8C5F-28FA538A8967> /Volumes/iMac Clone 1/Applications/XLD.app/Contents/PlugIns/XLDSparkleUpdater.bundle/Contents/MacOS/XLDSparkleUpdater
0x13083000 - 0x130bdfff +jp.tmkk.XLDLameOutput ??? (1.0) /Volumes/iMac Clone 1/Applications/XLD.app/Contents/PlugIns/XLDLameOutput.bundle/Contents/MacOS/XLDLameOutput
0x130da000 - 0x130edfff +org.andymatuschak.Sparkle 1.5 Beta (bzr) (1.5) <C1C2F3B9-7EC8-116D-B7C6-4900BAAF3197> /Volumes/iMac Clone 1/Applications/XLD.app/Contents/PlugIns/XLDSparkleUpdater.bundle/Contents/Frameworks/Sparkle.framework/Versions/A/Sparkle
0x130fb000 - 0x130fdfff +jp.tmkk.XLDTakDecoder ??? (1.0) /Volumes/iMac Clone 1/Applications/XLD.app/Contents/PlugIns/XLDTakDecoder.bundle/Contents/MacOS/XLDTakDecoder
0x13102000 - 0x13105ff3 +jp.tmkk.XLDTtaDecoder ??? (1.0) /Volumes/iMac Clone 1/Applications/XLD.app/Contents/PlugIns/XLDTtaDecoder.bundle/Contents/MacOS/XLDTtaDecoder
0x1310a000 - 0x1310dff7 +jp.tmkk.XLDVorbisOutput ??? (1.0) <551B8822-EA7A-84CF-E819-95FDBC48343C> /Volumes/iMac Clone 1/Applications/XLD.app/Contents/PlugIns/XLDVorbisOutput.bundle/Contents/MacOS/XLDVorbisOutput
0x13113000 - 0x13137ff7 +Vorbis ??? (???) <EA3859B9-05F9-20AD-6A02-A43E1E1827DA> /Volumes/iMac Clone 1/Applications/XLD.app/Contents/Frameworks/Vorbis.framework/Versions/A/Vorbis
0x13265000 - 0x13267ff3 +jp.tmkk.XLDWavpackDecoder ??? (1.0) <3FCE2546-9E80-4919-8A24-24D45C5E81B4> /Volumes/iMac Clone 1/Applications/XLD.app/Contents/PlugIns/XLDWavpackDecoder.bundle/Contents/MacOS/XLDWavpackDecoder
0x1326c000 - 0x13295fe3 +WavPack ??? (???) <E660876F-9079-45BD-B12D-4391A2294158> /Volumes/iMac Clone 1/Applications/XLD.app/Contents/Frameworks/WavPack.framework/Versions/A/WavPack
0x1329d000 - 0x132a0ff7 +jp.tmkk.XLDWavpackOutput ??? (1.0) <975A7869-AE94-DDB4-E478-1DA35B51D390> /Volumes/iMac Clone 1/Applications/XLD.app/Contents/PlugIns/XLDWavpackOutput.bundle/Contents/MacOS/XLDWavpackOutput
0x14b9f000 - 0x14ba3ff3 +com.stclairsoft.DefaultFolderX.osax Default Folder X Addition version 1.0 (4.3.10) <AE13AC3A-2A5F-DE8A-DAA4-D4B5AA82F3F0> /Users/michaelferrari/Library/ScriptingAdditions/Default Folder X Addition.osax/Contents/MacOS/Default Folder X Addition
0x14ba8000 - 0x14bc9fef +com.stclairsoft.DefaultFolderX.CarbonPatcher kBundleVersion (kBundleVersion) <E15B9B22-664E-6D25-CD6A-99786FBDDF79> /Library/PreferencePanes/Default Folder X.prefPane/Contents/Resources/Default Folder X.bundle/Contents/Resources/Carbon Patcher.bundle/Contents/MacOS/Carbon Patcher
0x14bd4000 - 0x14bf4fff +Cocoa Patcher ??? (???) <FBEBB8D4-4961-2AB7-D021-FF7072717B5D> /Library/PreferencePanes/Default Folder X.prefPane/Contents/Resources/Default Folder X.bundle/Contents/Resources/Cocoa Patcher.bundle/Contents/MacOS/Cocoa Patcher
0x14c87000 - 0x14c89ff3 com.apple.LiveType.component 2.1.4 (2.1.4) <D60E2537-3B47-EA99-0077-6CE394378D07> /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
0x14c8f000 - 0x14cf3fe2 com.apple.LiveType.framework 2.1.4 (2.1.4) <7AABA687-4323-E5B9-BA04-8F61C217E6FD> /Library/Application Support/ProApps/SharedA/Frameworks/LiveType.framework/Versions/A/LiveType
0x14d13000 - 0x14d59ffb com.apple.motion.component 1.0 (729) <494487C6-EA30-43DD-39E4-BED23C5A5B1C> /Library/QuickTime/Motion.component/Contents/MacOS/Motion
0x14d5f000 - 0x14d61ff7 Motion 729.0.0 (compatibility 1.0.0) <051B60E9-B39F-EBB2-5B96-F088D147E78C> /Library/Frameworks/Motion.framework/Versions/A/Motion
0x14d67000 - 0x14e04ff8 com.apple.procore.framework 4.0.2 (757) <D3146F1E-F86D-F2A2-509B-E3F9640CBE40> /Library/Application Support/ProApps/SharedA/Frameworks/ProCore.framework/Versions/A/ProCore
0x14e44000 - 0x15038ff7 +com.elgato.mpegsupport EyeTV MPEG Support 1.2 (build 50) (1.2) <0A9DC100-CA59-9826-49DB-14FFD9245C97> /Library/QuickTime/EyeTV MPEG Support.component/Contents/MacOS/EyeTV MPEG Support
0x15a2b000 - 0x15c09ff3 com.apple.audio.codecs.Components 2.0.2 (2.0.2) <8B43D24A-277D-5F42-8741-FC8736C44162> /System/Library/Components/AudioCodecs.component/Contents/MacOS/AudioCodecs
0x8fe00000 - 0x8fe4162b dyld 132.1 (???) <39AC3185-E633-68AA-7CD6-1230E7F1CEF4> /usr/lib/dyld
0x90042000 - 0x9007bff7 libcups.2.dylib 2.8.0 (compatibility 2.0.0) <D6F24434-8217-DF72-2126-1953080680D7> /usr/lib/libcups.2.dylib
0x9007c000 - 0x90157feb com.apple.DesktopServices 1.5.9 (1.5.9) <CED00AC1-924B-0E45-7D5E-1CEA8929F5BE> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x90158000 - 0x9024cff7 libiconv.2.dylib 7.0.0 (compatibility 7.0.0) <061ABF36-8BA9-79C1-6CE7-EC69A4998F51> /usr/lib/libiconv.2.dylib
0x90286000 - 0x90291ff7 libCSync.A.dylib 545.0.0 (compatibility 64.0.0) <CB2510BD-A5B3-9D90-5917-C73F6ECAC913> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x902b8000 - 0x9052bfe7 com.apple.Foundation 6.6.4 (751.42) <ACC0BAEB-C590-7052-3AB2-86C207C3D6D4> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x9052c000 - 0x905e2ff7 libFontParser.dylib ??? (???) <33F62EE1-E457-C6FD-369E-E86745B94A4B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x905e3000 - 0x90903ff3 com.apple.CoreServices.CarbonCore 861.23 (861.23) <B08756E4-32C5-CC33-0268-7C00A5ED7537> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x90905000 - 0x909cffef com.apple.CoreServices.OSServices 357 (357) <3A26F553-722D-3536-EEDE-FB41FCDAA7FD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x909d0000 - 0x909f8ff7 libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <769EF4B2-C1AD-73D5-AAAD-1564DAEA77AF> /usr/lib/libxslt.1.dylib
0x909f9000 - 0x912d9ff7 com.apple.AppKit 6.6.7 (1038.35) <ABC7783C-E4D5-B848-BED6-99451D94D120> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x912da000 - 0x9138aff3 com.apple.ColorSync 4.6.3 (4.6.3) <0354B408-665F-8B3F-87FF-64E6322276F0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x9138b000 - 0x913e8ff7 com.apple.framework.IOKit 2.0 (???) <A769737F-E0D6-FB06-29B4-915CF4F43420> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x91448000 - 0x915c3fe7 com.apple.CoreFoundation 6.6.4 (550.42) <C78D5079-663E-9734-7AFA-6CE79A0539F1> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x91604000 - 0x91623ff7 com.apple.CoreVideo 1.6.2 (45.6) <EB53CAA4-5EE2-C356-A954-5775F7DDD493> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x91660000 - 0x91a76ff7 libBLAS.dylib 219.0.0 (compatibility 1.0.0) <C4FB303A-DB4D-F9E8-181C-129585E59603> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x91a77000 - 0x91b1fffb com.apple.QD 3.36 (???) <FA2785A4-BB69-DCB4-3BA3-7C89A82CAB41> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x91b20000 - 0x91b23ff7 libCGXType.A.dylib 545.0.0 (compatibility 64.0.0) <B624AACE-991B-0FFA-2482-E69970576CE1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x91c1b000 - 0x91c41ffb com.apple.DictionaryServices 1.1.2 (1.1.2) <43E1D565-6E01-3681-F2E5-72AE4C3A097A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x91c42000 - 0x91c43ff7 com.apple.audio.units.AudioUnit 1.6.5 (1.6.5) <BE4C2495-B758-AD22-DCC0-56A6791E948E> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x91c44000 - 0x91dfdfeb com.apple.ImageIO.framework 3.0.4 (3.0.4) <C145139E-24C4-5A3D-B17C-809D528354B2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x91dfe000 - 0x91e68fe7 libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
0x91e69000 - 0x91e69ff7 liblangid.dylib ??? (???) <B99607FC-5646-32C8-2C16-AFB5EA9097C2> /usr/lib/liblangid.dylib
0x91e6a000 - 0x921d5ff7 com.apple.QuartzCore 1.6.3 (227.34) <CC1C1631-D8D1-D416-171E-A1683274E479> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x921d6000 - 0x92284ff3 com.apple.ink.framework 1.3.3 (107) <233A981E-A2F9-56FB-8BDE-C2DEC3F20784> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x92285000 - 0x92289ff7 IOSurface ??? (???) <D849E1A5-6B0C-2A05-2765-850EC39BA2FF> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x922aa000 - 0x926dfff7 libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <5E2D2283-57DE-9A49-1DB0-CD027FEFA6C2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x926e0000 - 0x926e6fff com.apple.CommonPanels 1.2.4 (91) <2438AF5D-067B-B9FD-1248-2C9987F360BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x92722000 - 0x92786ffb com.apple.htmlrendering 72 (1.1.4) <4D451A35-FAB6-1288-71F6-F24A4B6E2371> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x92787000 - 0x927baff7 com.apple.AE 496.4 (496.4) <C73D124C-C722-41D8-3465-4CE0D0BA9307> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x927bb000 - 0x927c6ff7 libGL.dylib ??? (???) <48405993-0AE9-292B-6705-C3525528682A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x929d8000 - 0x92dbeffb com.apple.RawCamera.bundle 3.4.1 (546) <557C094F-BF8D-B298-E502-C4EE78914C55> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x92dbf000 - 0x92e02ff7 libGLU.dylib ??? (???) <F8580594-0B38-F3ED-A715-CB3776B747A0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x92e03000 - 0x92e95fe7 com.apple.print.framework.PrintCore 6.3 (312.7) <7410D1B2-655D-68DA-D4B9-2C65747B6817> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x92ede000 - 0x92eefff7 com.apple.LangAnalysis 1.6.6 (1.6.6) <3036AD83-4F1D-1028-54EE-54165E562650> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x93008000 - 0x9302afef com.apple.DirectoryService.Framework 3.6 (621.9) <F2EEE9D7-D4FB-14F3-E647-ABD32754F557> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x9302b000 - 0x930e4fe7 libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <52438E77-55D1-C231-1936-76F1369518E4> /usr/lib/libsqlite3.dylib
0x930e5000 - 0x93267fe7 libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <35DB7644-0780-D2AB-F6A9-45F28D2D434A> /usr/lib/libicucore.A.dylib
0x93268000 - 0x93cb3ff7 com.apple.WebCore 6533.19 (6533.19.4) <DFCF1BC1-8BF3-E13E-F11B-C98CB36560FD> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x93d5e000 - 0x93d5eff7 com.apple.ApplicationServices 38 (38) <8012B504-3D83-BFBB-DA65-065E061CFE03> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x93e7f000 - 0x93eeeff7 libvMisc.dylib 268.0.1 (compatibility 1.0.0) <595A5539-9F54-63E6-7AAC-C04E1574B050> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x93f0b000 - 0x93fb5fe7 com.apple.CFNetwork 454.11.5 (454.11.5) <D8963574-285A-3BD6-6B25-07D39C6F67A4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x93fb6000 - 0x93ffffe7 libTIFF.dylib ??? (???) <AC1FC806-F7F4-174B-375F-FE5D6008666C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x94000000 - 0x94009ff7 com.apple.DiskArbitration 2.3 (2.3) <E9C40767-DA6A-6CCB-8B00-2D5706753000> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x9404b000 - 0x94063ff7 com.apple.CFOpenDirectory 10.6 (10.6) <F9AFC571-3539-6B46-ABF9-46DA2B608819> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x94295000 - 0x942d6ff7 libRIP.A.dylib 545.0.0 (compatibility 64.0.0) <16DAE1A5-937A-1CA2-D98F-2AF958B62993> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x942d7000 - 0x94359ffb SecurityFoundation ??? (???) <A8D248DE-8670-970D-39E3-A9738CFDBEE1> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x94437000 - 0x94444ff7 com.apple.NetFS 3.2.1 (3.2.1) <94A52A6D-F071-09D7-E80F-F633F17233FE> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x94445000 - 0x94477fe3 libTrueTypeScaler.dylib ??? (???) <6E9D1A50-330E-F1F4-F93D-9ECC8A61B21A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x94478000 - 0x94478ff7 com.apple.vecLib 3.6 (vecLib 3.6) <FF4DC8B6-0AB0-DEE8-ADA8-7B57645A1F36> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x94479000 - 0x944b4feb libFontRegistry.dylib ??? (???) <4FB144ED-8AF9-27CF-B315-DCE5575D5231> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x944d4000 - 0x94525ff7 com.apple.HIServices 1.8.1 (???) <51BDD848-32A5-2425-BE07-BD037A89630A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x9456f000 - 0x94570ff7 com.apple.TrustEvaluationAgent 1.1 (1) <2D970A9B-77E8-EDC0-BEC6-7580D78B2843> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x94571000 - 0x94573ff7 com.apple.securityhi 4.0 (36638) <E7D83480-77BB-72F9-72F3-AEE198CE589F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x94630000 - 0x9470dff7 com.apple.vImage 4.0 (4.0) <64597E4B-F144-DBB3-F428-0EC3D9A1219E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x9476d000 - 0x947bdff7 com.apple.framework.familycontrols 2.0.1 (2010) <41DD36DE-1A3C-7D2E-CF02-520091C2B71A> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0x947be000 - 0x947caff7 libkxld.dylib ??? (???) <F0E915AD-6B32-0D5E-D24B-B188447FDD23> /usr/lib/system/libkxld.dylib
0x9493b000 - 0x94978ff7 com.apple.SystemConfiguration 1.10.5 (1.10.2) <362DF639-6E5F-9371-9B99-81C581A8EE41> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x94e33000 - 0x94e79ff7 libauto.dylib ??? (???) <29422A70-87CF-10E2-CE59-FEE1234CFAAE> /usr/lib/libauto.dylib
0x94f10000 - 0x9503ffe3 com.apple.audio.toolbox.AudioToolbox 1.6.5 (1.6.5) <0A0F68E5-4806-DB51-764B-D97554B801AD> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x9508b000 - 0x950cdff7 libvDSP.dylib 268.0.1 (compatibility 1.0.0) <8A4721DE-25C4-C8AA-EA90-9DA7812E3EBA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x950ce000 - 0x950e3fff com.apple.ImageCapture 6.0.1 (6.0.1) <E7ED2AC1-834C-A44E-531E-EC05F0496DBF> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x950e4000 - 0x951f3fe7 com.apple.WebKit 6533.19 (6533.19.4) <A942073C-83DF-33ED-3D01-A24DE8AEAB3D> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x951ff000 - 0x951ffff7 com.apple.Accelerate 1.6 (Accelerate 1.6) <3891A689-4F38-FACD-38B2-4BF937DE30CF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x95200000 - 0x95304fe7 libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <BDEFA030-5E75-7C47-2904-85AB16937F45> /usr/lib/libcrypto.0.9.8.dylib
0x95401000 - 0x95415ffb com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <57DD5458-4F24-DA7D-0927-C3321A65D743> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x95416000 - 0x9541aff7 libGIF.dylib ??? (???) <DA5758A4-71B0-DD6E-7402-B7FB15387569> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x9555f000 - 0x95562ffb com.apple.help 1.3.1 (41) <67F1F424-3983-7A2A-EC21-867BE838E90B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x95563000 - 0x955a7ff3 com.apple.coreui 2 (114) <2234855E-3BED-717F-0BFA-D1A289ECDBDA> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x95665000 - 0x95689ff7 libJPEG.dylib ??? (???) <46AF3A0F-2B8D-87B9-62D4-0905678A64DA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x9568a000 - 0x958edfef com.apple.security 6.1.1 (37594) <1949216A-7583-B73A-6112-4D55CA5852E3> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x9594d000 - 0x95961fe7 libbsm.0.dylib ??? (???) <14CB053A-7C47-96DA-E415-0906BA1B78C9> /usr/lib/libbsm.0.dylib
0x95c7e000 - 0x95c88fe7 com.apple.audio.SoundManager 3.9.3 (3.9.3) <5F494955-7290-2D91-DA94-44B590191771> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x95c89000 - 0x95c90ff7 com.apple.agl 3.0.12 (AGL-3.0.12) <C43D8F35-D0DB-37F3-5058-A8308A377303> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x95c91000 - 0x95d3efe7 libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <C8925910-B927-968B-4B71-D83A4CEF8646> /usr/lib/libobjc.A.dylib
0x95d3f000 - 0x95db9fff com.apple.audio.CoreAudio 3.2.6 (3.2.6) <F7C9B01D-45AD-948B-2D26-9736524C1A33> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x95f87000 - 0x960b5fe7 com.apple.CoreData 102.1 (251) <87FE6861-F2D6-773D-ED45-345272E56463> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x960c6000 - 0x960cdff3 com.apple.print.framework.Print 6.1 (237.1) <F5AAE53D-5530-9004-A9E3-2C1690C5328E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x960e1000 - 0x960ebffb com.apple.speech.recognition.framework 3.11.1 (3.11.1) <7486003F-8FDB-BD6C-CB34-DE45315BD82C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x96236000 - 0x96252fe3 com.apple.openscripting 1.3.1 (???) <2A748037-D1C0-6D47-2C4A-0562AF799AC9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x96253000 - 0x96577fef com.apple.HIToolbox 1.6.3 (???) <169FA4B8-0847-D42E-8240-ECC52C0B8DD6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x96578000 - 0x974cafef com.apple.QuickTimeComponents.component 7.6.6 (1756) /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
0x974cb000 - 0x97563fe7 edu.mit.Kerberos 6.5.10 (6.5.10) <DC19F49B-184E-FD0F-13F8-3A31924A3B66> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x97567000 - 0x97577ff7 libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <C8744EA3-0AB7-CD03-E639-C4F2B910BE5D> /usr/lib/libsasl2.2.dylib
0x97578000 - 0x97578ff7 com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <ABF97DA4-3BDF-6FFD-6239-B023CA1F7974> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x97579000 - 0x97616fe3 com.apple.LaunchServices 362.1 (362.1) <997D57B9-F04E-344E-924D-16D184A21662> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x97636000 - 0x97636ff7 com.apple.CoreServices 44 (44) <51CFA89A-33DB-90ED-26A8-67D461718A4A> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x97637000 - 0x97637ff7 com.apple.Carbon 150 (152) <2539A94A-34D9-45CB-8F3E-AD53149E0BD5> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x9773b000 - 0x97788feb com.apple.DirectoryService.PasswordServerFramework 6.0 (6.0) <BF66BA5D-BBC8-78A5-DBE2-F9DE3DD1D775> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
0x97789000 - 0x9778bff7 libRadiance.dylib ??? (???) <10048B4A-2AE8-A4E2-21B8-C6E7A8C5B76F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x9778c000 - 0x9780cfeb com.apple.SearchKit 1.3.0 (1.3.0) <9E18AEA5-F4B4-8BE5-EEA9-818FC4F46FD9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x9780d000 - 0x979b4ff7 libSystem.B.dylib 125.2.1 (compatibility 1.0.0) <62291026-D016-705D-DC1E-FC2B09D47DE5> /usr/lib/libSystem.B.dylib
0x979b5000 - 0x97caefef com.apple.QuickTime 7.6.6 (1756) <F08B13B6-31D7-BD18-DA87-A0CDFCF13B8F> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x97caf000 - 0x97de6ff7 com.apple.CoreAUC 6.04.04 (6.04.04) <050D9D16-AAE7-3460-4318-8449574F26C7> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x97df5000 - 0x97df5ff7 com.apple.Cocoa 6.6 (???) <EA27B428-5904-B00B-397A-185588698BCC> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x97ea5000 - 0x98694557 com.apple.CoreGraphics 1.545.0 (???) <1AB39678-00D5-FB88-3B41-93D78348E0DE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x98695000 - 0x9869aff7 com.apple.OpenDirectory 10.6 (10.6) <C1B46982-7D3B-3CC4-3BC2-3E4B595F0231> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x98878000 - 0x988a9ff7 libGLImage.dylib ??? (???) <78F59EAB-BBD4-7366-CA84-970547501978> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x988ed000 - 0x989f9ff7 libGLProgrammability.dylib ??? (???) <8B308FAE-843F-EE76-0254-3374CBFFA7B3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x98a15000 - 0x98a36fe7 com.apple.opencl 12.3 (12.3) <DEA600BF-4F54-66B5-DB2F-DC57FD518543> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x98a55000 - 0x98a98ff7 com.apple.NavigationServices 3.5.4 (182) <8DC6FD4A-6C74-9C23-A4C3-715B44A8D28C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x98ab1000 - 0x98ad1fe7 libresolv.9.dylib 41.0.0 (compatibility 1.0.0) <BF7FF2F6-5FD3-D78F-77BC-9E2CB2A5E309> /usr/lib/libresolv.9.dylib
0x98ad2000 - 0x98b6dff7 com.apple.ApplicationServices.ATS 4.4 (???) <ECB16606-4DF8-4AFB-C91D-F7947C26040F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x98ba3000 - 0x98bb5ff7 com.apple.MultitouchSupport.framework 207.10 (207.10) <E1A6F663-570B-CE54-0F8A-BBCCDECE3B42> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x98c78000 - 0x98e75ff7 com.apple.JavaScriptCore 6533.19 (6533.19.1) <85A6BFDD-CBB6-7490-748D-8EA8B9B7FDD8> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x98fd9000 - 0x98fe7fe7 libz.1.dylib 1.2.3 (compatibility 1.0.0) <33C1B260-ED05-945D-FC33-EF56EC791E2E> /usr/lib/libz.1.dylib
0x9902f000 - 0x99032ff7 libCoreVMClient.dylib ??? (???) <1F738E81-BB71-32C5-F1E9-C1302F71021C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x99279000 - 0x99294ff7 libPng.dylib ??? (???) <E14178E0-B92D-94EA-DACB-04F346D7534C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x992cf000 - 0x99330fe7 com.apple.CoreText 3.5.0 (???) <BB50C045-25F5-65B8-B1DB-8CDAEF45EB46> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x9950d000 - 0x9960efe7 libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <ED8E45C6-B078-15E8-938D-99D8FD1EAE64> /usr/lib/libxml2.2.dylib
0x99707000 - 0x9970afe7 libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
0x9974e000 - 0x9975cff7 com.apple.opengl 1.6.11 (1.6.11) <286D1BC4-4CD8-3CD4-F723-5C196FE15FE0> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x99940000 - 0x99984fe7 com.apple.Metadata 10.6.3 (507.12) <8632684D-ED4C-4CE1-4C53-015DFF10D873> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x99985000 - 0x99989ff7 libGFXShared.dylib ??? (???) <C3A805C4-C0E5-B300-430A-7E811395CB8E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0xffff0000 - 0xffff1fff libSystem.B.dylib ??? (???) <62291026-D016-705D-DC1E-FC2B09D47DE5> /usr/lib/libSystem.B.dylib
Another crash bug:
I was trying to extract a multipart ape using it's cue file. I double-clicked on the cue, and XLD brought up the correct information for the embedded tracks. I hit GO, and after a couple of minutes, XLD crashed. I tried it on this ape/cue file several times, and each time XLD crashes. I think it might have something to do with the length of the output file name, but I'm not sure.
Crash report:
Process: XLD [30185]
Path: /Applications/XLD.app/Contents/MacOS/XLD
Identifier: jp.tmkk.XLD
Code Type: X86 (Native)
Date/Time: 2010-12-07 15:07:03.414 -0500
Report Version: 6
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x00000000151f9000
Crashed Thread: 4
Thread 0: Dispatch queue: com.apple.main-thread
0 libSystem.B.dylib 0x9780e0fa mach_msg_trap + 10
1 libSystem.B.dylib 0x9780e867 mach_msg + 68
2 com.apple.CoreFoundation 0x9148537f __CFRunLoopRun + 2079
3 com.apple.CoreFoundation 0x91484464 CFRunLoopRunSpecific + 452
4 com.apple.CoreFoundation 0x91484291 CFRunLoopRunInMode + 97
5 com.apple.HIToolbox 0x96287f58 RunCurrentEventLoopInMode + 392
6 com.apple.HIToolbox 0x96287d0f ReceiveNextEventCommon + 354
7 com.apple.HIToolbox 0x96287b94 BlockUntilNextEventMatchingListInMode + 81
8 com.apple.AppKit 0x90a4178d _DPSNextEvent + 847
9 com.apple.AppKit 0x90a40fce -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 156
10 com.apple.AppKit 0x90a03247 -[NSApplication run] + 821
11 com.apple.AppKit 0x909fb2d9 NSApplicationMain + 574
12 jp.tmkk.XLD 0x00003036 _start + 216
13 jp.tmkk.XLD 0x00002f5d start + 41
Thread 1: Dispatch queue: com.apple.libdispatch-manager
Thread 2:
5 com.apple.Foundation 0x903077d0 +[NSURLConnection(NSURLConnectionReallyInternal) _resourceLoadLoop:] + 329
6 com.apple.Foundation 0x902cebf0 -[NSThread main] + 45
7 com.apple.Foundation 0x902ceba0 __NSThread__main__ + 1499
8 libSystem.B.dylib 0x9783b85d _pthread_start + 345
9 libSystem.B.dylib 0x9783b6e2 thread_start + 34
Thread 3: com.apple.CFSocket.private
0 libSystem.B.dylib 0x9782d0c6 select$DARWIN_EXTSN + 10
1 com.apple.CoreFoundation 0x914c4c83 __CFSocketManager + 1091
Thread 4 Crashed:
0 libSystem.B.dylib 0xffff08a0 __memcpy + 256
1 libSystem.B.dylib 0x97842f69 fread + 318
2 jp.tmkk.XLDAlacOutput 0x0072eb37 -[XLDAlacOutputTask finalize] + 3904
3 jp.tmkk.XLD 0x000365f6 -[XLDConverterTask convert] + 4966
Thread 5:
0 libSystem.B.dylib 0x9782128e write + 10
1 libSystem.B.dylib 0x978211ed _swrite + 124
2 libSystem.B.dylib 0x9781fc80 __sfvwrite + 455
3 libSystem.B.dylib 0x978cd21c fwrite + 112
4 jp.tmkk.XLDAlacOutput 0x0072eb76 -[XLDAlacOutputTask finalize] + 3967
5 jp.tmkk.XLD 0x000365f6 -[XLDConverterTask convert] + 4966
Thread 6:
2 libSystem.B.dylib 0x9782001d __sflush + 65
3 libSystem.B.dylib 0x9781fc5a __sfvwrite + 417
4 libSystem.B.dylib 0x978cd21c fwrite + 112
5 jp.tmkk.XLDAlacOutput 0x0072e30b -[XLDAlacOutputTask finalize] + 1812
6 jp.tmkk.XLD 0x000365f6 -[XLDConverterTask convert] + 4966
7 com.apple.Foundation 0x902cebf0 -[NSThread main] + 45
8 com.apple.Foundation 0x902ceba0 __NSThread__main__ + 1499
9 libSystem.B.dylib 0x9783b85d _pthread_start + 345
10 libSystem.B.dylib 0x9783b6e2 thread_start + 34
Thread 7:
2 com.apple.CoreGraphics 0x97eccb6a _CGSSynchronizeWindowBackingStore + 139
3 com.apple.CoreGraphics 0x97ec5ce0 _CGSLockWindow + 5001
4 com.apple.CoreGraphics 0x97ecc70a CGSDeviceLock + 493
5 libRIP.A.dylib 0x9429d593 ripd_Lock + 62
6 libRIP.A.dylib 0x942a87cd ripl_BltImage + 429
7 libRIP.A.dylib 0x942a8393 ripc_RenderImage + 269
8 libRIP.A.dylib 0x942add30 ripc_EndLayer + 904
9 com.apple.CoreGraphics 0x97f44efd CGContextEndTransparencyLayer + 103
10 com.apple.AppKit 0x90baba52 -[NSProgressIndicator heartBeat:] + 2178
11 com.apple.AppKit 0x90baae23 -[NSUIHeartBeat _heartBeatThread:] + 1593
12 com.apple.Foundation 0x902cebf0 -[NSThread main] + 45
13 com.apple.Foundation 0x902ceba0 __NSThread__main__ + 1499
14 libSystem.B.dylib 0x9783b85d _pthread_start + 345
15 libSystem.B.dylib 0x9783b6e2 thread_start + 34
Thread 8:
Thread 9:
0 jp.tmkk.XLDApeDecoder 0x00749484 CPrepare::Unprepare(int, int, tWAVEFORMATEX const*, unsigned char*, unsigned int*) + 52
1 jp.tmkk.XLDApeDecoder 0x007406d9 CAPEDecompress::DecodeBlocksToFrameBuffer(int) + 1065
2 jp.tmkk.XLDApeDecoder 0x0074088d CAPEDecompress::FillFrameBuffer() + 93
3 jp.tmkk.XLDApeDecoder 0x00741c7b CAPEDecompress::GetData(char*, int, int*) + 123
4 jp.tmkk.XLDApeDecoder 0x0073aa31 -[XLDApeDecoder decodeToBuffer:frames:] + 115
5 jp.tmkk.XLD 0x000354c6 -[XLDConverterTask convert] + 566
Thread 10:
4 jp.tmkk.XLDAlacOutput 0x0072f0b7 -[XLDAlacOutputTask finalize] + 5312
Thread 4 crashed with X86 Thread State (32-bit):
eax: 0xffff0893 ebx: 0x97842e39 ecx: 0x0000000f edx: 0xfffff980
edi: 0x00a41e80 esi: 0x151f9680 ebp: 0xb02209b8 esp: 0xb02209b0
ss: 0x0000001f efl: 0x00010216 eip: 0xffff08a0 cs: 0x00000017
ds: 0x0000001f es: 0x0000001f fs: 0x0000001f gs: 0x00000037
cr2: 0x151f9000
Binary Images:
0x1000 - 0x6dfe3 +jp.tmkk.XLD 20101128 (126.0) <6E24A7EA-FE2C-2C79-1A1E-8092C133A29A> /Applications/XLD.app/Contents/MacOS/XLD
0x8f000 - 0x9afff +CDDB ??? (???) /Applications/XLD.app/Contents/Frameworks/CDDB.framework/Versions/A/CDDB
0xa2000 - 0x103fcf +Musicbrainz ??? (???) /Applications/XLD.app/Contents/Frameworks/Musicbrainz.framework/Versions/A/Musicbrainz
0x161000 - 0x1bdfe7 +Sndfile ??? (???) <4F69600F-C387-4869-89C8-FAA1A7616FB8> /Applications/XLD.app/Contents/Frameworks/Sndfile.framework/Versions/A/Sndfile
0x4f6000 - 0x4f9ff7 +jp.tmkk.XLDFlacDecoder ??? (1.0) <5FCE7C45-3C14-4345-B339-A27F8F3A8F67> /Applications/XLD.app/Contents/PlugIns/XLDFlacDecoder.bundle/Contents/MacOS/XLDFlacDecoder
0x700000 - 0x707ff7 +jp.tmkk.XLDAacOutput ??? (1.0) <6468D5F6-2AB6-FF35-C559-174BDAC361B8> /Applications/XLD.app/Contents/PlugIns/XLDAacOutput.bundle/Contents/MacOS/XLDAacOutput
0x70d000 - 0x719ff7 +jp.tmkk.XLDAacOutput2 ??? (1.0) <59982F6D-1F3D-DD46-7BDF-718415CCC402> /Applications/XLD.app/Contents/PlugIns/XLDAacOutput2.bundle/Contents/MacOS/XLDAacOutput2
0x71f000 - 0x724ff7 +jp.tmkk.XLDAlacDecoder ??? (1.0) <FA1EBE57-8264-1DE8-83EC-ABD5FD6BD064> /Applications/XLD.app/Contents/PlugIns/XLDAlacDecoder.bundle/Contents/MacOS/XLDAlacDecoder
0x72a000 - 0x733ff7 +jp.tmkk.XLDAlacOutput ??? (1.0) <7C436CAD-08CF-9FC8-D56E-1A1C7C9AE674> /Applications/XLD.app/Contents/PlugIns/XLDAlacOutput.bundle/Contents/MacOS/XLDAlacOutput
0x739000 - 0x75bffa +jp.tmkk.XLDApeDecoder ??? (1.0) /Applications/XLD.app/Contents/PlugIns/XLDApeDecoder.bundle/Contents/MacOS/XLDApeDecoder
0x76c000 - 0x7b3fd7 +FLAC ??? (???) /Applications/XLD.app/Contents/Frameworks/FLAC.framework/Versions/A/FLAC
0x7c4000 - 0x7c6ff7 +Ogg ??? (???) <AC76D238-F8FC-CC14-8FBF-CC36626850D2> /Applications/XLD.app/Contents/Frameworks/Ogg.framework/Versions/A/Ogg
0x7c9000 - 0x7cdff7 +jp.tmkk.XLDFlacOutput ??? (1.0) <BF79E52E-7C4A-C6A5-8F96-9E61837BBC8A> /Applications/XLD.app/Contents/PlugIns/XLDFlacOutput.bundle/Contents/MacOS/XLDFlacOutput
0x7d3000 - 0x7d8ff7 +jp.tmkk.XLDHEAACOutput ??? (1.0) <7DAAEB64-13F1-1988-2434-947ABABACDF0> /Applications/XLD.app/Contents/PlugIns/XLDHEAACOutput.bundle/Contents/MacOS/XLDHEAACOutput
0x7de000 - 0x7dfffb +jp.tmkk.XLDLibsndfileDecoder ??? (1.0) <D0584CB5-71CB-4F56-BCE5-EA78569BA91D> /Applications/XLD.app/Contents/PlugIns/XLDLibsndfileDecoder.bundle/Contents/MacOS/XLDLibsndfileDecoder
0x7e4000 - 0x7e5ff7 +jp.tmkk.XLDMP3Decoder ??? (1.0) <AB512F41-0982-4B4A-9050-87DCD4EF9AF7> /Applications/XLD.app/Contents/PlugIns/XLDMP3Decoder.bundle/Contents/MacOS/XLDMP3Decoder
0x7ea000 - 0x7f1fef +jp.tmkk.XLDShortenDecoder ??? (1.0) /Applications/XLD.app/Contents/PlugIns/XLDShortenDecoder.bundle/Contents/MacOS/XLDShortenDecoder
0x7f9000 - 0x7f9ff7 +jp.tmkk.XLDSparkleUpdater ??? (1.0) <A5BB9D62-1F1D-46FA-8C5F-28FA538A8967> /Applications/XLD.app/Contents/PlugIns/XLDSparkleUpdater.bundle/Contents/MacOS/XLDSparkleUpdater
0x1d5a000 - 0x1d94fff +jp.tmkk.XLDLameOutput ??? (1.0) /Applications/XLD.app/Contents/PlugIns/XLDLameOutput.bundle/Contents/MacOS/XLDLameOutput
0x1db1000 - 0x1dc4fff +org.andymatuschak.Sparkle 1.5 Beta (bzr) (1.5) <C1C2F3B9-7EC8-116D-B7C6-4900BAAF3197> /Applications/XLD.app/Contents/PlugIns/XLDSparkleUpdater.bundle/Contents/Frameworks/Sparkle.framework/Versions/A/Sparkle
0x1dd2000 - 0x1dd4fff +jp.tmkk.XLDTakDecoder ??? (1.0) /Applications/XLD.app/Contents/PlugIns/XLDTakDecoder.bundle/Contents/MacOS/XLDTakDecoder
0x1dd9000 - 0x1ddcff3 +jp.tmkk.XLDTtaDecoder ??? (1.0) /Applications/XLD.app/Contents/PlugIns/XLDTtaDecoder.bundle/Contents/MacOS/XLDTtaDecoder
0x1de1000 - 0x1de4ff7 +jp.tmkk.XLDVorbisOutput ??? (1.0) <551B8822-EA7A-84CF-E819-95FDBC48343C> /Applications/XLD.app/Contents/PlugIns/XLDVorbisOutput.bundle/Contents/MacOS/XLDVorbisOutput
0x1dea000 - 0x1decff3 +jp.tmkk.XLDWavpackDecoder ??? (1.0) <3FCE2546-9E80-4919-8A24-24D45C5E81B4> /Applications/XLD.app/Contents/PlugIns/XLDWavpackDecoder.bundle/Contents/MacOS/XLDWavpackDecoder
0x1df1000 - 0x1df4ff7 +jp.tmkk.XLDWavpackOutput ??? (1.0) <975A7869-AE94-DDB4-E478-1DA35B51D390> /Applications/XLD.app/Contents/PlugIns/XLDWavpackOutput.bundle/Contents/MacOS/XLDWavpackOutput
0x13129000 - 0x1314dff7 +Vorbis ??? (???) <EA3859B9-05F9-20AD-6A02-A43E1E1827DA> /Applications/XLD.app/Contents/Frameworks/Vorbis.framework/Versions/A/Vorbis
0x1327b000 - 0x132a4fe3 +WavPack ??? (???) <E660876F-9079-45BD-B12D-4391A2294158> /Applications/XLD.app/Contents/Frameworks/WavPack.framework/Versions/A/WavPack
0x13406000 - 0x1340aff3 +com.stclairsoft.DefaultFolderX.osax Default Folder X Addition version 1.0 (4.3.10) <AE13AC3A-2A5F-DE8A-DAA4-D4B5AA82F3F0> /Users/michaelferrari/Library/ScriptingAdditions/Default Folder X Addition.osax/Contents/MacOS/Default Folder X Addition
0x14bc9000 - 0x14beafef +com.stclairsoft.DefaultFolderX.CarbonPatcher kBundleVersion (kBundleVersion) <E15B9B22-664E-6D25-CD6A-99786FBDDF79> /Library/PreferencePanes/Default Folder X.prefPane/Contents/Resources/Default Folder X.bundle/Contents/Resources/Carbon Patcher.bundle/Contents/MacOS/Carbon Patcher
0x14bf5000 - 0x14c15fff +Cocoa Patcher ??? (???) <FBEBB8D4-4961-2AB7-D021-FF7072717B5D> /Library/PreferencePanes/Default Folder X.prefPane/Contents/Resources/Default Folder X.bundle/Contents/Resources/Cocoa Patcher.bundle/Contents/MacOS/Cocoa Patcher
0x14c8b000 - 0x14c8dff3 com.apple.LiveType.component 2.1.4 (2.1.4) <D60E2537-3B47-EA99-0077-6CE394378D07> /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
0x14c93000 - 0x14cf7fe2 com.apple.LiveType.framework 2.1.4 (2.1.4) <7AABA687-4323-E5B9-BA04-8F61C217E6FD> /Library/Application Support/ProApps/SharedA/Frameworks/LiveType.framework/Versions/A/LiveType
0x14d17000 - 0x14d5dffb com.apple.motion.component 1.0 (729) <494487C6-EA30-43DD-39E4-BED23C5A5B1C> /Library/QuickTime/Motion.component/Contents/MacOS/Motion
0x14d63000 - 0x14d65ff7 Motion 729.0.0 (compatibility 1.0.0) <051B60E9-B39F-EBB2-5B96-F088D147E78C> /Library/Frameworks/Motion.framework/Versions/A/Motion
0x14d6b000 - 0x14e08ff8 com.apple.procore.framework 4.0.2 (757) <D3146F1E-F86D-F2A2-509B-E3F9640CBE40> /Library/Application Support/ProApps/SharedA/Frameworks/ProCore.framework/Versions/A/ProCore
0x14e48000 - 0x1503cff7 +com.elgato.mpegsupport EyeTV MPEG Support 1.2 (build 50) (1.2) <0A9DC100-CA59-9826-49DB-14FFD9245C97> /Library/QuickTime/EyeTV MPEG Support.component/Contents/MacOS/EyeTV MPEG Support
0x16fa0000 - 0x1717eff3 com.apple.audio.codecs.Components 2.0.2 (2.0.2) <8B43D24A-277D-5F42-8741-FC8736C44162> /System/Library/Components/AudioCodecs.component/Contents/MacOS/AudioCodecs
0x99331000 - 0x9950cff3 libType1Scaler.dylib ??? (???) <A7AB841A-3F40-E0B8-ADDD-44014C7287C9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libType1Scaler.dylib
i tried to test my cd drive with DAEQualitiy from exactaudiocopy. I prepared the test cd and tried to read out this cd with XLD in Burst mode as described in the tutorial. I can reproducible get XLD crashing. It always happens at position about 62%. I tried it with the internal and an external cd drive. It also happens when using XLD Secure Ripping instead of Burst.
Process: XLD [465]
Version: 20101212 (126.2)
OS Version: Mac OS X 10.6.6 (10J567)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000032603fb2
Crashed Thread: 4
Thread 4 Crashed:
0 jp.tmkk.XLD 0x000446d0 -[XLDCDDARipper decodeToBuffer:frames:] + 384
1 jp.tmkk.XLD 0x00035636 -[XLDConverterTask convert] + 566
2 com.apple.Foundation 0x92a05bf0 -[NSThread main] + 45
3 com.apple.Foundation 0x92a05ba0 __NSThread__main__ + 1499
4 libSystem.B.dylib 0x95ff585d _pthread_start + 345
5 libSystem.B.dylib 0x95ff56e2 thread_start + 34
Can someone help me?
jerry
Hello,
I have exactly the same problem:
XLD does not import any id3 metadata from mp3s.
Therefore, it is currently actually useless for converting from mp3 data.
Secondly, it seems unable to import mp4 AAC at all, while some people mention this should have worked in some older releases.
Does anybody know more on these two topics?
I would really like to build a mobile version of my music library using XLD but since I currently cannot convert mp3 nor AAC data it is unfortunately impossible....
I'm using XLD 20110212 (127.0).
When ripping from CD to FLAC image and cue, some symbols are not transferred correctly from the given metadata to the cue sheet. Here is an example from a CD I just ripped:
TRACK 03 AUDIO
TITLE "You Won’t See Me"
INDEX 00 04:34:23
INDEX 01 04:36:10
There are quite a few other symbols that cause problems including "é" and "ñ".
I'm running OS X 10.6.7 on a 2006 MacBook Pro with 2GB ram.
I'm running XLD Version 20110502 (132.0).
I believe after the 2011/4/17 update I started have lots of issues with the progress window. Sometimes it will appear very small and cannot be moved or minimized and will remain on top of all other applications. Other times I will only be able to see the actual progress if it the window is made quite large (it is blank at normal size), but otherwise it functions normally (can be moved, etc.).
Besides the progress window, the functionality of the program does not seem to be otherwise impaired.
This problem occurs regardless of if I am ripping or converting files and with any combination of settings I've tried.
Thanks for the wonderful program and hope this minor bug is easy to fix.
I can only get XLD's audio player to play through the internal speakers. Can anyone else confirm that this is a software issue?
I wasn't even aware that XLD had the ability to play audio - do you mean from a CD prior to ripping? I can't see any options anywhere for playback.
Also, do you mean it will play through headphones but not through the Mac's speakers, or that it won't play through an external USB/Firewire audio interface?
Open XLD, Window-->Show Player
XLD seems to play only files loaded from a cue sheet—just open a cue and double-click on any song. It doesn't seem to work with CDs or individual files without a cue sheet (without it you get a different interface and can't click on the songs).
I restarted XLD and now I'm getting sound from the line-out. I switch the speakers between two systems and when I switch back to the Mac I have to select "line-out" in the sound preferences. XLD doesn't recognize that change until it is restarted.
Ah, there it is, and yeah, it only plays from CUEs for me, too (very latest version - today! - 20110508 (133.0)).
Regarding audio output, the player correctly tracks changes in output devices on my system: plug in headphones and it plays through the headphones, unplug them and it will play through the internal speaker, no relaunch required (Mac mini C2D, OS X 10.6.7).
Has anyone tried the burn option in the latest 20110508 (133.0) version ?
It took me 3 coasters to find the write-offset, but now it seems to work very well here.
I'm very happy with the burn option, especially since the developer tmkk had no intention to implement it when I asked him 2 years ago.
Problem using MusicBrainz data - when I insert a cd to rip, and look up the data, I get an entry from both MB and Freedb, but if I select the MB entry and try to use it, it does not actually apply the tags to the tracklist, just disappears without making any changes to it.
Expected result: update track list with correct metadata.
XLD version 20110508
Mac OS 10.6.7
Macbook pro i7 2.66Ghz, 8Gb ram
I just burned a CD (from flac+cue) then ripped it and compared the log to the original—all CRC's match.
I´m new at this forum and I have right now a question of manage the correct filename after I have done one of the last updates. So if I try to rip a compilation the metadatas show me the correct compilation flag behind every titel. But xld ignores this flag and creates a separate folder for every song and artist on this compilation. Shouldn´t XLD creates a single folder "various" for the hole CD?
Thanks and greetings,
seger
One way to do what you want is to create a new profile titled "compilations" and change the beginning of your filename format from %a/ (song artist in this case) to %A/ (album artist) or %T/ (album title). When you are going to rip or transcode a compilation, just change profiles.
27" iMac 2011, 64-bit OS X 10.6.7, with 8GB Ram here. Latest version of the XLD (2011/6/11) installed.
Embedding cuesheets to FLAC and Wavpack when ripping to single file does not work. I have tested both formats with embedding option enabled and disabled in the encoder settings but no effect. XLD in all cases saves CUE as a separate file.
Apart of this small bug, awesome software. Thanks.
Are you sure the cuesheet isn't embedded as well ? You can easily verify that by opening the flac image and see if XLD asks you to use the embedded cuesheet.
Works fine for me (old 10.4.11 though, but latest XLD).
Good point. I tested this with XLD and it did not ask about cuesheet when opening FLAC or WavPack image. I tested also with Foobar 2000 and it shows only a single image file without tracklist.
NOTE:
lpacheco reports of the same issue in post #51 (http://www.hydrogenaudio.org/forums/index.php?showtopic=66076&view=findpost&p=659993).
