New version rev015 anyway, so new readme translation.
Graphical Browser
● What this component does:
Album cover browser for the active playlist.
● Caution
Settings are per panel so if you delete a panel, the settings for that panel
also disappear.
● Sort
Blank → Whatever works.
* → Sorted by grouped strings.
If you want to arrange in the same order as the playlist → $num(%gb_playlist_number%,10)
● Popup
Transparent mode
You can apply different level of transparence to every pixel. (e.g.: transparent background
with full opacity image and text.)
I think that GDI can't be used, please use GDI+ only.
Even with GDI+, text rendering without using $gp_set_text_rendering_hint(aa) doesn't look
good enough.
Per track
Draw order:
Popup → Per track(0) → Per track(1) → ...
Rendering settings (e.g.: pen, brush, font, ...) can't be set again midway.
● Image cache methods
Old
rev011 and older way. Cache images of all items.
Image cache is purged when switching playlist.
Default
Cache images to the set size.
Image cache is not purged when switching playlist.
If the image cache reach the limit, it will be purged.
● Variables
%gb_group%
[Item], [Popup], [Per track(Popup)]
Return the group string. E.g.: If you used $if2(%album%,@skip) to group,
it will return %album%.
%gb_width%
[Item]
Item width
Popup width
%gb_height%
[Item]
Item height
Popup height
%gb_focused%
Check whether focus is on the item or not
%gb_mouse_over%
[Item]
Check whether mouse cursor is on the item or not
Probably always true
%gb_item_index%
Return item index
%gb_item_count%
Return item count
%gb_track_count%
[Sort], [Item], [Popup], [Per track(Popup)]
Return number of songs in an item
Return position of song in playlist for the first song in an item
[Per track(Popup)]
%gb_col%
Return item column number
%gb_row%
Return item row number
%gb_col_count%
Return number of columns
%gb_row_count%
Return number of rows
%gb_isplaying%
[Item], [Popup]
Return true if a song in the item is playing
[Per track (Popup)]
Return true if it is playing
%gb_track_index%
[Per track (Popup)]
Position of track in item (O based)
%gb_length%
Total length of item/track
%gb_length_seconds%
Total length in seconds of item/track
%gb_calc_x%
%gb_calc_y%
%gb_calc_width%
%gb_calc_height%
Dimension calculations
Values change with functions below
$calc_text
$gp_calc_string
$gp_calc_string_path
$draw_image
● About functions:
Functions are divided into GDI and GDI+. They are different in pens, brushes and points.
For GDI, to set color with "r-g-b", use a base 10 number for each color component;
otherwise use base 16 number with "rrggbb". For GDI+, to set color with "a-r-g-b",
use a base 10 number for each color component and alpha channel; otherwise use
base 16 number with "aarrggbb". If you want to draw some thing with transparency
or effects like anti-aliasing, use GDI+. Some fonts (probably OpenType fonts with
PostScript outline) can't be used in GDI+ mode. Full-width hyphen can't be
displayed right in GDI+ mode.
● GDI function
$set_font(name,size,style)
Set font
name - font name
size - font size
style - style
Set multiple styles by combining options
"b" - bold
"i" - italic
"u" - underline
"s" - strikethrough
$set_font_color(color)
Set font color
color - color
$draw_text(str,x,y)
Draw text
str - string
x - start point x coordinate
y - start point y coordinate
$draw_text(str,x,y,width,height,[option1],[option2],...)
Draw text within the set limit
str - string
width - drawing width
height - drawing height
option - other option
"bottom" - draw at bottom, needs singleline
"center" - center aligned
"end_ellipsis" - if out of limit, append "...."
"left" - left aligned
"noclip" - no clip, same as no settings for width and height
"path_ellipsis" – like end_ellipsis but used for file path
"right" – right aligned
"singleline" - display with 1 line
"top" - draw at top
"vcenter" - vertical center aligned, needs singleline
"wordbreak" - display with multiple lines
"word_ellipsis" - truncates any word that does not fit in the
rectangle and adds ellipsis.
Details at [url=http://msdn2.microsoft.com/en-us/library/ms533909.aspx]http://msdn2.microsoft.com/en-us/library/ms533909.aspx[/url]
$draw_text_blur(str,x,y,strength,[deep])
$draw_text_blur(str,x,y,width,height,strength,[deep],[option1],[option2],...)
○ Overview
Draw blurred text.
○ Arguments
str - string
strength - Blur strength (1..20)
deep - enable [1]
option - see $draw_text
$calc_text(str)
$calc_text(str,width,height,[option1],[option2],...)
Calculate size of str when drawn.
Arguments are the same as $draw_text except x and y.
Use %gb_calc_*% to obtain values after this function.
$set_pen(color)
$set_pen(color,width)
$set_pen(color,width,style)
Pen settings
color - color
width - width[1], only effective when using "solid" style
style - style["solid"]
"solid" - solid line
"dash" - dashed line
"dot" - dotted line
"dashdot" - line with alternating dashes and dots
"dashdotdot" - line with alternating dashes and double dots
Details at [url=http://msdn2.microsoft.com/en-us/library/ms535467(VS.85).aspx]http://msdn2.microsoft.com/en-us/library/m...467(VS.85).aspx[/url]
$set_brush(color)
$set_brush(color,style)
Brush settings
color - color
style - style: if it is not set, then brush is solid
"bdiagonal" - A 45-degree upward, left-to-right line pattern
"cross" - Horizontal and vertical cross pattern
"diagcross" - 45-degree cross pattern
"fdiagonal" - A 45-degree downward, left-to-right line pattern
"horizontal" - Horizontal line pattern
"vertical" - Vertical line pattern
$draw_rect(x,y,width,height)
Draw rectangle using pen
width - width
height - height
$fill_rect(x,y,width,height)
Fill rectangle using brush
width - width
height - height
$fill_draw_rect(x,y,width,height)
Draw rectangle using pen and brush
width - width
height - height
$round_rect(x,y,width,height,ellipse_width,ellipse_height)
Draw round corner rectangle with pen and brush
width - width
height - height
ellipse_width - ellipse width
ellipse_height - ellipse height
$draw_line(x1,y1,x2,y2)
Draw line using pen, end point is not drawn.
x1 - start point x coordinate
y1 - start point y coordinate
x2 - end point x coordinate
y2 - end point y coordinate
● GDI+ function
Because pen, brush, font do not have default values, please set them up with
$gp_set_* before using.
$gp_set_pen(argb,width)
$gp_set_pen(argb,width,style,line_join)
○ Overview:
Pen settings
○ Arguments:
argb - color
width - width
style - style ["solid"]
"dot" - dotted line
line_join - stroke corner style ["miter"]
"miter"
"bevel"
"round"
$gp_set_brush(argb)
○ Overview:
Monocolor brush setting
○ Arguments:
argb - color
$gp_set_brush(style,argb1,argb2)
○ Overview:
Hatch brush settings
○ Argument:
style - Style
Use number in range 0 ~ 53.
Details at http://msdn2.microsoft.com/en-us/library/ms534127.aspx
argb1 - Foreground color.
argb2 - Background color.
$gp_set_brush(argb1,x1,y1,argb2,x2,y2)
○ Overview:
Set brush with linear gradual effect
○ Arguments:
argb1 - color 1
x1 - color 1 x coordinate
y1 - color 1 y coordinate
argb2 - color 2
x2 - color 2 x coordinate
y2 - color 2 y coordinate
$gp_set_font(name,size)
$gp_set_font(name,size,style_1,style_2...)
○ Overview:
Font settings
○ Arguments:
name - font name
size - font size
style - style
"b" - bold
"i" - italic
"bi" - bold and italic
"u" - underline
"s" - strikethrough
$gp_set_string_format(alignment,line_alignment,[trimming])
○ Overview:
Text drawing method settings
○ Arguments:
alignment - horizontal alignment
"near" - left
"center" - center
"far" - right
line_alignment - vertical alignment
"near" - top
"center" - center
"far" - bottom
trimming - Trimming.
"character"
"word"
"ellipsis_character"
"ellipsis_word"
"ellipsis_path"
$gp_set_smoothing_mode(antialias)
○ Overview:
Shape anti-alias setting
○ Arguments:
antialias - anti-alias
0 - disable
1 - enable
$gp_set_text_rendering_hint(mode)
○ Overview:
Text rendering method setting
○ Arguments:
mode - method
"default" - default
"sb+" - single bit per pixel grid fit
"sb" - single bit per pixel
"aa+" - anti alias grid fit
"aa" - anti alias
"ct" - clear type
$gp_draw_arc(x,y,width,height,start_angle,sweep_angle)
○ Overview:
Draw arc using pen
○ Arguments:
x - top left x coordinate
y - top left y coordinate
width - width
height - height
start_angle - start angle (degree)
sweep_angle - end angle (degree)
○ Settings:
$gp_set_pen
$gp_draw_ellipse(x,y,width,height)
○ Overview:
Draw ellipse using pen
○ Arguments:
width - width
height - height
○ Settings:
$gp_set_pen
$gp_draw_line(x1,y1,x2,y2)
○ Overview:
Draw line using pen
○ Arguments:
○ Settings:
$gp_set_pen
$gp_draw_pie(x,y,width,height,start_angle,sweep_angle)
○ Overview:
Draw pie (fan shape) using pen
○ Arguments:
width - width
height - height
○ Settings:
$gp_set_pen
$gp_draw_rectangle(x,y,width,height)
○ Overview:
○ Arguments:
width - width
height - height
○ Settings:
$gp_set_pen
$gp_draw_string(str,x,y)
$gp_draw_string(str,x,y,width,height)
○ Overview:
Draw string using brush
○ Arguments:
str - string
width - width
height - height
○ Settings:
$gp_set_font
$gp_set_brush
$gp_calc_string(str)
$gp_calc_string(str,width,height)
○ Overview
$gp_fill_ellipse(x,y,width,height)
○ Overview:
Fill ellipse using brush
○ Arguments:
width - width
height - height
○ Settings:
$gp_set_brush
$gp_fill_pie(x,y,width,height,start_angle,sweep_angle)
○ Overview:
Fill pie using brush
○ Arguments:
width - width
height - height
○ Settings:
$gp_set_brush
$gp_fill_rectangle(x,y,width,height)
○ Overview:
○ Arguments:
width - width
height - height
○ Settings:
$gp_set_brush
$gp_draw_string_path(str,size,mode,x,y)
$gp_draw_string_path(str,size,mode,x,y,width,height)
○ Overview:
Draw string with border.
○ Arguments:
str - string
size - character size, px unit (different from current font size)
mode - draw mode
"" - fill and border
"stroke" - only border
"fill" - only fill
width - width
height - height
○ Settings:
$gp_set_pen
$gp_set_brush
$gp_set_font
○ Examples:
$gp_set_font(Tahoma,9,b)
$gp_set_pen(ff1500ff,2,,round)
$gp_set_brush(ffddeeff)
$gp_set_string_format(center,center)
$gp_set_smoothing_mode(1)
$gp_draw_string_path(%gb_group%,16,,0,0,%gb_width%,%gb_height%)
$gp_calc_string_path(str,size,mode)
$gp_calc_string_path(str,size,mode,width,height)
○ Overview
Calculate size of str with border when drawn
● Draw image function
$draw_image(x,y,width,height,path)
$draw_image(x,y,width,height,path,alpha)
$draw_image(x,y,width,height,path,alpha,option)
$draw_image(x,y,width,height,path,alpha,option,rotate_flip)
○ Overview:
Draw image
○ Arguments:
x - starting point x coordinate
y - starting point y coordinate
width - width
height - height
path - absolute path to image, wild cards are accepted.
alpha - degree of opacity[255]
option - other options[""]
"nokeepaspect" - don't keep picture aspect ratio
"top" - draw at the top
"topright" - draw on the top right
"right" - draw from the right
"bottomright" - draw on the bottom right
"bottom" - draw at the bottom
"bottomleft" - draw on the bottom left
"left" - draw from the left
"topleft" - draw on the top left
rotate_flip - Rotation and flip [0]
0 - No rotation = Rotate right 180 degrees,
flip vertically then horizontally
1 - Rotate right 90 degrees = Rotate right 270 degrees,
2 - Rotate right 180 degrees = Flip vertically then
horizontally
3 - Rotate right 270 degrees = Rotate right 90 degrees,
4 - Flip horizontally = Rotate right 180 degrees,
flip vertically
5 - Rotate right 90 degrees, flip horizontally = Rotate
right 270 degrees, flip vertically
6 - Rotate right 180 degrees, flip horizontally = Flip
vertically
7 - Rotate right 270 degrees, flip horizontally = Rotate
right 90 degrees, flip vertically
○ Reference
After executing this function, you can use
%gb_calc_*% to obtain the real dimensions used.
● Other functions
$set_size(width,height)
○ Overview
Modify popup size, please use it only when drawing the popup.
Popup size is the upper limits, you can only set to smaller sizes.
%gb_width%,%gb_height% values are changed accordingly.
When width or height is 0 or less, popup won't be drawn.
○ Arguments:
width - width
height - height
$set_org(x,y)
○ Overview
Starting point setting
○ Arguments:
$set_clip_rect()
$set_clip_rect(x,y,width,height)
○ Overview
Only draw GDI, GDI+, and pictures inside the designated area.
Cancel this function effect by calling it with no argument.
$sum(tf)
○ Overview
Calculate sum of values designated by TitleFormat.
○ Arguments:
tf - TitleFormat
○ Example: Total number played
$sum('%play_count%')
$eval(expression)
Evaluate the expression and calculate
expression - expression
E.g.: $eval(5+3)
E.g.: $eval({%gp_width%-10}/2)
※ Divide by zero expression returns 0.
Can be used with sort
● Change logs:
2008/04/20 rev015
Added - $draw_text_blur function
Added - $set_clip_rect function
Added - "(show track menu)" action
2008/03/16 rev014
Added - $set_size function
Added - %gb_calc_x% variable
Added - %gb_calc_y% variable
Added - %gb_calc_width% variable
Added - %gb_calc_height% variable
Added - $calc_text function
Added - $gp_calc_string function
Added - $gp_calc_string_path function
Fixed - $draw_image function
Fixed - $gp_set_string_format function(trimming argument) (however, they can always be used before,
just forgot to write here…
Fixed - Several bugs fixed
2008/03/12 rev013
Fixed - Fixed the slip happens sometimes when using keyboard to jump from item to item
Fixed - When drawing in GDI mode, fixed a drawing background bug
2008/03/11 rev012
Fixed - Fatal resource leak
Added - Image cache options
2008/03/10 rev011
Added - Ability to move focus to an item when pressing the first character of %gb_group%
using keyboard
Added - Ability to add to specified playlist instead of replacing it
Fixed - Fixed a bug that prevents you to scroll in Windows 2000 (probably...)
(TL's note: not sure about the last one, the meaning is a little vague and I don't have
Windows 2000 to test)
2008/03/09 rev010
Fixed - For some reason, I changed the variable name %gb_subitem_count% to %gb_track_count%
(the one before can still be used)
Added - Function $gp_set_brush(style,argb1,argb2)
Added - Function $set_org(x,y)
Added - Popup display transparent mode
Added - Popup delay setting
Added - Function $sum(tf)
Added - Variable %gb_isplaying%
Added - Variable %gb_track_index%
Added - Variable %gb_length%
Added - Variable %gb_length_seconds%
2008/03/02 rev009
Fixed - Fixed the bug that causes rotateflip does nothing
Fixed - Fixed behavior when there's no scroll bar
Added - Added mouse over popup.
2008/03/02 rev008
Fixed - Fixed bug that prevent the use of wild cards in $draw_image function
2008/03/02 rev007
Added - Ability to [always show|if necessary show|hide] scroll bar
Fixed - $set_font function (style)
Fixed - $draw_image function (rotate_flip)
Added - Middle mouse button action
Added - Ability to send to specified playlist
Older change logs omitted.
● Copyright
TitleFormatting Editor
Copyright 1998-2003 by Neil Hodgson <neilh@scintilla.org> All Rights Reserved
[url=http://scintilla.sourceforge.net/]http://scintilla.sourceforge.net/[/url]
