discussion/bug reports here (http://www.hydrogenaud.io/forums/index.php?showtopic=108040&st=0#entry886574)
Version 3.0.5
- new split algorithm with 80-bit floating point optimization
- sample rate independent FFT window option – up to 384 kHz support
- “Quality” option added for control overlap percentage
- default gain set to -6dB to prevent clipping
- output mode “[C][L+R]” removed
Version 3.0.8 released.
Failed to load DLL: foo_dsp_TripleStereo.dll
Final version 3.1.1
