Topic: LAME fastest encoding(-q 9) gives better quality than the slowest encoding(-q 0) (Read 11173 times) previous topic - next topic
Re: LAME fastest encoding(-q 9) gives better quality than the slowest encoding(-q 0)
Reply #50
So, The patched -q3 with noise amp=0 should be same as -q4 (also noise amp=0) in normal versions if i m correct ?
Yeah, I think so. -q3 sets noise_shaping_stop to 1, -q4 sets noise_shaping_stop to 0 - however, that config variable appears to be unused and the other settings are identical.
Reply #52
@maikmerten I prefer patched versions, but I think there is no difference between patched q0 and q9.
Reply #53
Did anybody have a listen to the samples I posted at https://hydrogenaud.io/index.php/topic,126120.msg1047065.html#msg1047065 ? It would be useful to know if ABR has the same problem or if I'm imagining things.
I will soon check these.  In my experience abr has similar problem.
Reply #54
MP3 is just so patched, that it:
First: is not MP3 anymore
Second: do not works uniformely and simply anymore
Reply #55
What on earth are you talking about?
Reply #56
@Klymins Thanks for testing. q0 and q9 should still make a (tiny) difference (they're not the same settings, e.g., for searching the best Huffman codes), but these may not be very evident.
@shadowking Looking forward to your findings!
@a.ok.in I cannot follow, can you elaborate?
Reply #57
By the way, I prefer a FhG MP3Enc encoded CBR 32kbps MP3 over both of these ABR 32kbps examples.
Reply #58
Okay, The winners for me are patched versions.
Reply #59
@shadowking Thanks for your feedback!
@Klymins  I guess FhG MP3Enc chooses other sample rate and lowpass settings. Can you provide information on what FhG chooses?
Reply #60
@maikmerten
ABR mode is definitely better on patched version. No need to ABX. It is obvious. :)
Reply #61
@maikmerten I prefer 22050Hz. FhG-encoded CBR 32kbps MP3 is lowpassed by roughly 8kHz in this speed. I always use the lowest quality.
Reply #62
@Klimins It appears you like lowpassed audio.
With 32 kbps mono, FhG appears to choose 22050 Hz sampling rate with a lowpass of ~7800 Hz.
With 32 kbps stereo, FhG appears to choose 16000 Hz sampling rate with a lowpass of ~4900 Hz.
Transferring these settings to LAME, overall results are somewhat comparable, as far as I can tell.
OP's techno/rave sample:
lame --resample 16000 --lowpass 4900 -q0 -b 32 rave16.wav rave-lame-patch.mp3
The Moby Dick TTS sample:
lame --resample 22500 --lowpass 7800 -q0 -b 32 google-mobydick-male.wav moby-lame-patched.mp3
(LAME encodes with the trivial patch applied)
They still sound *different* IMO, but I guess preferring one over the other is now a matter of personal preference.
Reply #63
@maikmerten Looks like you was not used the lowest quality setting on FhG. Try it, it's cutoff point is a little bit higher at almost 8kHz. Also, I prefer 11025Hz for 32kbps stereo MP3. As my MP3Enc does not encode above 30 seconds and Adobe Flash CS6 does not encode 32kbps stereo, I have to use Fastencc for 32kbps stereo, and it works very well at this sample rate at this bitrate at stereo.
Reply #64
Great... now fastenc... the encoder famous for its pirated copy for Windows ACM codec that had several annoying sound bugs.
Reply #65
I didn't experience any sound bugs.
Reply #66
Browsing through LAME's version history, I determined that the quality regressions (q0 sounding worse than, e.g., q4) were introduced with this change:
https://sourceforge.net/p/lame/svn/6147/
Reply #67
There are certain times where the 'Extreme' preset (-V 0 -q 0 --vbr new) gave me artifacts with tracks that have cymbal decays or certain TR-808 sounds. The issues are usually solved by using -f -V 0 --vbr new instead
LAME: -f -V 0 -Y
 Xing: -V150 -X2 -U2 -HF-1 -TX0
Reply #68
Although I claim no great wisdom in this matter, my LAME encoder of choice has long been halb27s tuned lame-3.99.5o-Fast-CRC, which you will find at RareWares.
Reply #69
finally after 15 years or so people are talking about this, this has been a critical bug for donkeys years
q4 has sounded better since LAME 3.97 (for 320kbps anyway)
even tested this on a function 1 sound system and quality difference was night and day
