Topic: JPEG 2000 plugin (Read 2916 times) previous topic - next topic
JPEG 2000 plugin
Hello, I'm a 100% newbie when it comes to fb2k API.
I'm considering converting my artwork from png to JPEG 2000 and lack of support from foobar is a major setback. So I decided that it may be worthwhile to write a plugin that decodes them. But here comes the question: is it even possible?
I mean: is it possible to make a plugin that decodes images in some format, so that other plugins can use it w/out any modifications?
JPEG 2000 plugin
The Default UI module uses the GDI+ library to read images, while Columns UI uses the relevant image libraries directly. So far as I know, neither support extending their format support with external components.
JPEG 2000 plugin
Thank you for the answer.
