Topic: Foobar 2000 latest Update (Read 1627 times) previous topic - next topic
Good morning all,
After my last Foobar 2000 UPDATE,The sound I am getting has got too much BASS, and no matter what I do with Its Equalizer It is the
same thing or very LITTLE change. I have Uninstalled and Installed it again, But The SAME Thing!
Would You Please Help me??  Thank You
Sincerely,
Looks61
Re: Foobar 2000 latest Update
Remove all DSP effects from foobar2000 playback chain. Does your OS and/or sound card have a control panel that includes EQ? Do your speakers have tone control? Make sure all cables are firmly connected.
Thanks so much for replying Apesbrain... I am using Cambridge Audio DAC Magic 100 that has taken over a computer's sound card,
and The Speakers are Martin Logan with no control. The whole thing started with The Foobar2000 update!
I really appreciate your help with this.
If you're convinced foobar2000 is the cause, you might try writing over your current install with an older version:
https://www.foobar2000.org/old
Good morning,
I will try that again and see what happens. I appreciate your help very much.
Thank You!
