Topic: titleformat - directly calling common functions on params (Read 1369 times) previous topic - next topic
Is there any way to do something like this?
bool titleformat_hook_impl_multiformat::process_function(titleformat_text_out * p_out, const char * p_name, t_size p_name_length, titleformat_hook_function_params * p_params, bool & p_found_flag)
    if (0 == pfc::strcmp_ex(p_name, p_name_length, "do_left", pfc::infinite_size)) {
        static_api_ptr_t<titleformat_common_methods> default_api;
        default_api->process_function(m_file_info, m_location, p_out, "left", 4, p_params, p_found_flag);
        return true;
    p_found_flag = false;
    return false;
Basically, I'm trying to invoke built-in titleformat functions on my own titleformat_hook_function_params object. But the above code doesn't seem to work (always returns false / not found). This is the only thing I came up with after scouring titleformat.h. Maybe it's not possible....
The titleformat_common_methods service only provides fields and functions to access track metadata. The built-in functions like $left are not accessible this way. You would have to create and execute a script using the desired function and parameters. You could either provide the parameters as constants. Then you would have to escape special characters inside them. You could also provide them via a hook and use something like %1%, %2% (or $arg(1), $arg(2)) in the generated script.
Thanks foosion!
That would be quite a lot of overhead. I guess re-implementing the built-in functions myself is the simplest solution.
Note that you would need to use different names for your re-implemented functions. As far as I remember a hook cannot override any of the built-in functions.
That is correct. :-)
