Topic: Toughest sample for wavpack and dualstream (Read 3044 times) previous topic - next topic
The Badvilbel sample:
http://www.ff123.net/samples/badvilbel.flac
The hybrids are also affected during the silent parts. Again no 'artifacts' as we expect  , but a boost in background hiss. The original is also hissing.
Wavpack 4.2:
5.2-6.5 secs
-hb256 : very easy to hear and abx 8/8
-hb320 : Better but obvious 8/8
-hb450 : Threshold: I have to raise to raise the volume above normal and then it there **must be carefull of the noisey parts !!**  8/8
-hb500: Seems to resolve, I am risking equipment damage and have no motivation to try abx again at this bitrate..
Using -hx makes it better, though a slight hiss is still there up to around 450k.
Listening to this sample naturaly I can't hear anything wrong at 400k +, but only when I abx the difference is heard. I only stumbled on it through abxing out of boredom.
Optimfrog Dualstream:
Quality 0 (260k): Easy 8/8 but sounds more subdued than wavpack
Quality 3 (360k): Sounds quite good, but there is a subtle hiss  7/8.  Dualstream seems to inflate bitrate more than WV possibly due to its quality mode ?
Quality 4 & 5: (400-460k) Can't abx it even with extreme volume levels!
10.6 seconds is also abxed up to quality 3 or 4 (worse than wavpack !?). At quality 5 I gave up on 5/5. I am not sure if I hear anything worthwhile even on really high volume and I am scared of equipment damage.
I searched for other potential similar samples (quite bits) but I cannot find anything even close to this signal. It seems to have a really weird loud freq spike that pushes background fuzz upwards and the hybrids cannot mask the noise as they normaly do ?  This must be a worse case scenario for hybrids, but it reality I would have never heard a thing during normal listening.
Thanks for providing this sample; I'll add it to my collection...
The problem here (as you guessed) is the high-level noise over 15 kHz. The "high" and "extra" modes help somewhat because there's a pretty significant peak just over 18 kHz that can be decorrelated out, but the rest is fairly broadband.
The only real solution for samples like this will come when I implement the psychoacoustic-based "quality" mode (which will simply crank up the bitrate in those sections). Fortunately artificial samples like this are rare.
And, yes, I wouldn't play this loud on real speakers because it could easily fry tweeters!
