It's for using directly a Squeezebox with Foobar . Gapless . Enjoy
;============================== Start of FooSQ AutoIt script ==================================
; Author Marae; May 2008 - FooSQ
; FooSQ grab infos from Foobar windows title with an AutoIT script, then send "cli" command to SqueezeCenter.
; It is not necessary to wait for any rescan inside SqueezeCenter.
; Just add a folder/playlist inside Foobar (no tags needed), then press play (gapless).
; The time needed with my settings for adding a song in Now Playing then bufferize it is 10 sec.
; If we guess the next song, and we enqueue it 10 sec. before the end of the current one, it's gapless.
; Then FooSQ determine normal transition (remaining time pass by 0) or skip.
; AMIP guess the next song
; This is a first release, so you may see some Autoit error messages or desynchro sometime.
; To install:
; 1.- Install autoit and compile this script( [url=http://www.autoitscript.com/autoit3/downloads.shtml]http://www.autoitscript.com/autoit3/downloads.shtml[/url] )
; 2.- Put %path%/%playback_time_remaining_seconds%/%ispaused%/ in Foobar pref. Display - Title Formating - Main windows title
; 3.- Install AMIP ( [url=http://amip.tools-for.net/ds/dl.php?f=/files/amip_foobar_09.zip]http://amip.tools-for.net/ds/dl.php?f=/fil...p_foobar_09.zip[/url] ), then restart Foobar.
; in Foobar Pref, Tools, Amip, Enable Amip, enable File C:\nextsong.txt and put $next(%fn) in "Play" Field
; 4.- Start Foobar, play a song, verify you have "Full path file name/Remaining sec./?/" in windows title, and C:\nextsong.txt is the next song. Stop Foobar
; 5.- Start this compiled script
; Seekbar move, repeat song, click on a playing song, more then one squeezebox not implemented
; Cli ref : file:///C:/Program%20Files/SqueezeCenter/server/HTML/EN/html/docs/cli-api.html
; Tested with Autoit v3.2.10.0 - Foobar 0.9.4.4 - AMIP 2.63
; - Freeware - ( Use / Modify at your own risk. No support: Sources provided )
; --------------------------------------- Code Start ---------------------------------------
; AMIP file
$m_amip = "C:\nextsong.txt"
;slimserver ip & port
$m_ip = "127.0.0.1"
$m_port = 9090
; Start The TCP Services
TCPStartUp()
;Attempt to connect to SC
$m_tcp = TCPConnect($m_ip,$m_port)
If @error Then
MsgBox(0, "FooSQ", "SqueezeCenter not responding")
Exit
EndIf
; Match windows title substring
Opt("WinTitleMatchMode", 2)
; Title somewhere in title bar
$m_foo = "foobar2000"
; length of title while foobar is stopped
$m_lts = 19
; Status variables:
;File name played
$m_f = ""
;Remaining time
$m_r = "0"
; Status: 0 -> stop; 1 -> playing; 2 -> paused
$m_s = "0"
; Is paused: ? -> playing; 1 -> paused
$m_p = "?"
; Transition: 0 -> normal (not skipped)
$m_t = ""
; Length of windows title
$m_l = "0"
; Next file name for gapless
$m_n = ""
; Next file name already enqueued -> 1
$m_ne = ""
; in foobar preference : 1 -> yes, put loop idle
$m_pref = ""
; New status variable after song transition
; new file name
$m_fn = ""
; windows title new lenght
$m_ln = "0"
; loop timer . reduce if shuffled songs start too early
$m_lt=229
; get foobar windows title
$m_title = WinGetTitle($m_foo, "")
If $m_title = "0" Then
MsgBox(0, "FooSQ", "Please start Foobar")
Exit
EndIf
; clear playing now
TCPSend($m_tcp,"playlist clear" & @CRLF)
While 1
If StringRegExp ( $m_title, $m_foo ) <> 1 Then
; no foobar anymore ?
Exit
EndIf
If StringRegExp ( $m_title, "Preferences" ) Then
; we are in foobar pref, put the loop idle
if $m_pref = "" Then
MsgBox(0, "FooSQ", "Staying in Foobar Preferences a while may desynchronize FooSQ. Do a Foobar Stop/Play when finished")
Endif
$m_pref = "1"
Else
$m_pref = ""
EndIf
If $m_pref = "" Then
$m_ln = StringLen($m_title)
if $m_ln <> $m_lts Then
; find new infos after transition
$a_tn = StringSplit($m_title, "/")
$m_fn = $a_tn[1]
$m_r = $a_tn[2]
$m_p = $a_tn[3]
EndIf
Select
; go to stop and clear now playing
Case $m_ln = $m_lts AND $m_s <> "0"
$m_s = "0"
TCPSend($m_tcp,"stop" & @CRLF & "playlist clear" & @CRLF)
; from stop to start
Case $m_ln <> $m_lts AND $m_s = "0"
$m_s = "1"
$m_f = $m_fn
; SC needs / and %20 for space
$m_sq = StringReplace(StringReplace($m_fn, "\", "/"), " ", "%20")
TCPSend($m_tcp, "playlist play " & $m_sq & @CRLF)
; song change / pause while playing
Case $m_ln <> $m_lts AND $m_s = "1"
; goto pause
if $m_p = "1" Then
$m_s = "2"
TCPSend($m_tcp,"pause 1" & @CRLF)
Else
if $m_f <> $m_fn Then
if $m_t = "0" Then
if $m_fn <> $m_n Then
; normal transition, not next song
TCPSend($m_tcp,"playlist play " & $m_sq & @CRLF)
Endif
Else
; next song after skip, random button or click on another song
Endif
$m_t = ""
$m_ne = ""
Else
if $m_r = "11" OR $m_r = "10" Then
; enqueue next song ( when remain 11 or 10 sec if title is late)
if $m_ne = "" Then
$m_amips = FileOpen($m_amip, 0)
If $m_amips = -1 Then
MsgBox(0, "FooSQ", "AMIP next song file not found")
Exit
EndIf
$m_n = FileReadLine($m_amip)
FileClose($m_amip)
$m_sq = StringReplace(StringReplace($m_n, "\", "/"), " ", "%20")
TCPSend($m_tcp,"playlist insert " & $m_sq & @CRLF)
$m_ne = "1"
Endif
Endif
if $m_r = "0" OR $m_r = "1" Then
;remaining time pass by 0 (or 1 if title is late)
$m_t = "0"
Endif
Endif
$m_f = $m_fn
EndIf
; continue after pause
Case $m_ln <> $m_lts AND $m_s = "2"
if $m_p = "?" Then
$m_s = "1"
TCPSend($m_tcp, "pause 0" & @CRLF)
EndIf
EndSelect
Endif
sleep($m_lt)
WEnd
Exit
; ============================================= End of script =====================================
Thanks a lot!
But... excuse my complete ignorance... I already (sometimes) use foobar with squeezebox just connecting to http://192.168....:port (http://192.168....:port) , so... what's different with this script?
Is it faster?... what are it's benefits compared to a normal connection?
Thanks a lot!
You are talking about MP3 streaming. FooSQ is lossless with lossless files.
Flac are decoded to wav inside the SBox, APE, ALAC etc. in SCenter.
Oh...thanks!
My bad...
... you were talking about squeezebox while I was thinking about squeezecenter
Now I understand it... Thanks
This script is fantastic - thank you!
Getting the right match of versions of the different software was quite tricky.
I'm running:
Windows 7 Ultimate
SqueezeCenter 7.3
Foobar 0.9.6.9
AMIP 2.65
Script compiled with AutoIt v3.3.6.0.
Everything works well, so you can completely bypass the SQ music library, so no need for constant "Look for new and changed music" rescans.
The script was unstable before but seems rock solid now compiled with AutoIt v3.3.6.0.
I have updated the script and it is now working successfully with Foobar2000 1.0.3 and AMIP 2.67.
; Revised by Alan Morse Davies - May 2010
; To install:
; Tested with Autoit v3.3.6.1 - Foobar 1.0.3 - AMIP 2.67
; AMIP file
$m_ip = "127.0.0.1"
$m_port = 9090
TCPStartUp()
If @error Then
Exit
EndIf
$m_lts = 17
; Status variables:
;File name played
$m_f = ""
;Remaining time
$m_r = "0"
$m_s = "0"
$m_p = "?"
$m_t = ""
$m_l = "0"
$m_n = ""
$m_ne = ""
$m_pref = ""
; new file name
$m_fn = ""
; windows title new length
$m_ln = "0"
$m_lt=229
Exit
EndIf
; clear playing now
While 1
If NOT StringInStr( $m_title, $m_foo ) Then
Exit
EndIf
If Stringinstr ( $m_title, "Preferences" ) Then
Endif
$m_pref = "1"
Else
$m_pref = ""
EndIf
$m_fn = $a_tn[1]
$m_r = $a_tn[2]
$m_p = $a_tn[3]
EndIf
Select
$m_s = "0"
$m_s = "1"
$m_f = $m_fn
; goto pause
if $m_p = "1" Then
$m_s = "2"
Else
if $m_t = "0" Then
Endif
Else
Endif
$m_t = ""
$m_ne = ""
Else
if $m_ne = "" Then
Exit
EndIf
FileClose($m_amip)
$m_ne = "1"
Endif
Endif
$m_t = "0"
Endif
Endif
$m_f = $m_fn
EndIf
if $m_p = "?" Then
$m_s = "1"
EndIf
EndSelect
Endif
sleep($m_lt)
WEnd
Exit
Here's a super-streamlined version which is a little more robust. You need to remember to start Foobar first, but this version doesn't have the limitation of going out of sync every time you go into Foobar preferences. I've removed most of the error messages with the exception of a failure to connect with SqueezeCenter.
For those that can't be bothered messing around with AutoIt, here's link to a compiled .exe file (it's been virus checked):
http://www.at-sea.com/work/FooSQ.exe (http://www.at-sea.com/work/FooSQ.exe)
You still need to follow the set-up instructions in the first message of this post.
A quick reminder about what this does....
This allows you to use Foobar2000 to playback through your SqueezeBox or Transporter boxes. Volume control and seekbar do not work.
$m_ip = "127.0.0.1"
$m_port = 9090
$m_class = "[CLASS:{97E27FAA-C0B3-4b8e-A693-ED7881E99FC1}]"
TCPStartUp()
If @error Then
MsgBox(48, "FooSQ", "SqueezeCenter not responding.")
Exit
EndIf
$m_lts = 17
$m_f = ""
$m_r = "0"
$m_s = "0"
$m_p = "?"
$m_t = ""
$m_l = "0"
$m_n = ""
$m_ne = ""
$m_fn = ""
$m_ln = "0"
$m_lt=229
$m_title = WinGetTitle($m_class, "")
While 1
Exit
EndIf
$m_fn = $a_tn[1]
$m_r = $a_tn[2]
$m_p = $a_tn[3]
EndIf
Select
$m_s = "0"
$m_s = "1"
$m_f = $m_fn
if $m_p = "1" Then
$m_s = "2"
Else
if $m_t = "0" Then
Endif
Else
Endif
$m_t = ""
$m_ne = ""
Else
if $m_ne = "" Then
FileClose($m_amip)
$m_ne = "1"
Endif
Endif
$m_t = "0"
Endif
Endif
$m_f = $m_fn
EndIf
if $m_p = "?" Then
$m_s = "1"
EndIf
EndSelect
sleep($m_lt)
WEnd
Exit
greatz lex_nasa
happy that somebody have an interest about my dirty code
I have developped the code (still dirty) if you are interrested:
for any IR remote control:
toggle shuffle/normal
play next
next /previous album if big playlists are organized x:\album\artist
put foosq in windows startup, wait for browser, kill it , start foobar
add album art windows where I like, (based on folder.jpg, as I don't like the wasted space with the standard lay out
I am going to holidays, see you next month
Cheers
Marae
Great, maybe we can share and merge code? I've added a function for a global volume control on the numeric keypad: + and - for higher/lower, * for mute.
$m_ip = "127.0.0.1"
$m_port = 9090
TCPStartUp()
If @error Then
Exit
EndIf
$m_lts = 17
$m_f = ""
$m_r = "0"
$m_s = "0"
$m_p = "?"
$m_t = ""
$m_l = "0"
$m_n = ""
$m_ne = ""
$m_fn = ""
$m_ln = "0"
$m_lt=229
HotKeySet("{NUMPADADD}" ,"Volume")
HotKeySet("{NUMPADSUB}" ,"Volume")
HotKeySet("{NUMPADMULT}" ,"Volume")
While 1
Exit
EndIf
$m_fn = $a_tn[1]
$m_r = $a_tn[2]
$m_p = $a_tn[3]
EndIf
Select
$m_s = "0"
$m_s = "1"
$m_f = $m_fn
if $m_p = "1" Then
$m_s = "2"
Else
if $m_t = "0" Then
Endif
Else
Endif
$m_t = ""
$m_ne = ""
Else
if $m_ne = "" Then
FileClose($m_amip)
$m_ne = "1"
Endif
Endif
$m_t = "0"
Endif
Endif
$m_f = $m_fn
EndIf
if $m_p = "?" Then
$m_s = "1"
EndIf
EndSelect
sleep($m_lt)
WEnd
Func Volume()
If StringInStr(@HotKeyPressed,"{NUMPADADD}") Then
TCPSend($m_tcp,"mixer volume +5" & @CRLF)
ElseIf StringInStr(@HotKeyPressed,"{NUMPADSUB}") Then
TCPSend($m_tcp,"mixer volume -5" & @CRLF)
ElseIf StringInStr(@HotKeyPressed,"{NUMPADMULT}") Then
TCPSend($m_tcp,"mixer volume 0" & @CRLF)
EndIf
EndFunc
Exit
Greetings lex_nasa
As there is at last ONE person interested by some code by itself, some updates after 2 years
Improved:
will work with more version of foobar (including 1.0.3) without code mods, just need to setup the location if not default
we can stay in Preferences or other confusing windows without hassle
New:
foosq must be started before foobar to remove some dependency about version
IR remote control, you need to learn code if remote control <> mac-mini
there is a fadout with a nice curve while playing with remote control: next, random and next/previous albums functions, then, volume 100%
pop up window cd cover on top where we like if needed, if folder.jpg in dirs
your nice volume code is not implemented, TBD
cheers
Marae
;============================== Start FooSQ AutoIt script V 2010.1.8p ==================================
; Author Marae ; May 2008 - July 2010
; !!!!!!! CAUTION !!!!!! The Squeeze Center volume is reverted to 100% for every song
; - Freeware - / Sources provided / Use / Modify / Transmit / And the usual statements about responsabilities (no ones)
; IF YOU TRANSMIT this code, add in your script: "; Idea by Marae" , Thank you
; Tested with Transporter Firmware: 62, SC 7.2, Ethernet cable with WinXP SP2 on Mac-Mini, Autoit v3.3.6.1 - Foobar 1.03 - AMIP 2.67
; FooSQ grab infos from Foobar window title, then send "cli" command to SqueezeCenter (SC).
; The time needed with my settings for adding a new song/bufferize in SC is 10 sec.
; Then FooSQ look for normal transition (remaining time pass by 0) or skip.
; To install:
; 0.- Install autoit ( [url=http://www.autoitscript.com/autoit3/downloads.shtml]http://www.autoitscript.com/autoit3/downloads.shtml[/url] )
; 1.- Check "custom variables" below and modify those if needed, compile this script using "Compile Script to .exe" in Autoit start menu
; 2.- Put %path%/%playback_time_remaining_seconds%/%ispaused%/ in Foobar pref. Default User Interface - Window title
; 3.- Install AMIP, then restart Foobar.
; in Foobar Pref, Tools, Amip, Enable Amip, enable "Write song info to file" then File: C:\nextsong.txt and $next(%fn) in "Play:" Field
; 4.- Start Foobar, play a song, verify you have "Full path file name/Remaining sec./?/ [foobar2000 ...]" in window title, and C:\nextsong.txt is the next song. Quit Foobar
; 5.- SC must be running, start FooSQ, foobar will start ... Press play on your favorite song, Enjoy
; Other Foobar settings:
; Enable "Playback follows cursor" on and also the opposite in Playback menu
; WARNING: "Resume playback after restarting ..." in Preference Playback is NOT possible without desynchro
; Seekbar move, Volume, and more then one squeezebox not implemented
;BUG:
; if you disable some IP connectivity (e.g wifi) and use for exemple "File open" in a previously remote enabled location,
; foobar will freeze, then foosq will stop
; with this code it's possible to use the mac-mini remote control = IR
; IR keys
; right -> next song
; left -> toggle default / shuffle tracks
; up -> skip up previous album in PL, play new album now
; down -> skip down next album in PL, play new album now
; Alt - up -> Same but wait for the end of the current song. All PL album up/down disabled before to play new song (difficult to guess cursor pos. , foobar cannot return cursor pos)
; Alt - down -> Same
; menu -> Alt code for 5 sec
; center -> random skip in PL
; to use another remote control, find the IR codes:
; Command Prompt: "telnet 127.0.0.1 9090" (default)
; "listen 1" + Return
; play with your remote control (do not use the slim device one !!), then replace in this script $m_ir_*
; for fade out on IR next etc, set SC options, Player, audio, Volume control adjust
; V 0.1 initial
; V 0.2 add IR
; V 2010.1.3 next / previous album skip with IR, fade out when some IR interruption
; V 2010.1.5 choice for next / previous album : play now or wait for the end of the current song
; V 2010.1.6 album cd cover art
; V 2010.1.8 remove dependency about foobar version:(works with foobar windows handle #), foobar is considered idle when foobar title begin with:
; "foobar2000", and end with a number. Now we can go to foobar preferences without hassle.
; WARNING: to be shure to get the correct handle #, foobar NEED be started with foosq (msgbox provided if foobar is running)
; In rare case, you may see some Autoit error messages or foosq stop, just restart foosq again, then press OK
#include
#include
#include
#include
#include
#include
#include
; ----------- MANDATORY custom variables to check -----------------
; foobar default command
$m_fooexe = "c:\program files\foobar2000\foobar2000.exe"
; AMIP file for gapless
;SC ip & port, if you change the default setting
$m_ip = "127.0.0.1"
$m_port = 9090
; ----------- Optional custom variables -----------------
; IR codes for remote control
$m_ir_alt = "77e1c0ce"
$m_ir_next = "77e160ce"
$m_ir_random = "77e1a0ce"
$m_ir_toggle = "77e190ce"
$m_ir_pl_down = "77e130ce"
$m_ir_pl_up = "77e150ce"
; M3U playlist files for playing next/previous album in a PL with remote control; work only with mac mini remote control if you don't change IR code
; Works well if songs in PLs are sorted like x:\Artist\Album AND one song exists only in one PL
; dir where you export all your PLS in M3U format(right click on a tab, Save all playlists...)
$m_plsd = "C:\audio\pls.m3u"
; CLEAN sometime inside dir if some PLs not used anymore
; to disable $m_plsd = ""
; check are made if dir exists and some PLs in also
; ALWAYS ON TOP: cover cd album art popup window size
; to disable:
; $m_size = 0
$m_size = 300
; horizontal pos, ok for screen 1360x768
$m_aah = 1033
; vertical
$m_aav = 396
; name of file containing the cover cd image in each directory
$m_jpg = "folder.jpg"
; ----------- End of custom variables -----------------
; Somewhere always in foobar title bar
TCPStartUp()
If @error Then
MsgBox(0, "FooSQ Warning", "SqueezeCenter not responding")
Exit
EndIf
; foobar running ?
$m_ok = WinActivate ($m_foo)
if $m_ok <> 0 Then
; quit it, so we are shure to get the correct handle #
$m_w = MsgBox(1,"FooSQ Warning","Not allowed, Start FooSQ first." & @CRLF & @CRLF & "Press OK and Foobar will restart after 5 sec." & @CRLF & @CRLF & "Press Cancel to quit FooSQ")
if $m_w = 2 Then
Exit
EndIf
Run($m_fooexe & " /quit")
sleep(5000)
Endif
; start it
Run($m_fooexe, "", @SW_MAXIMIZE)
WinWaitActive ( $m_foo )
WinSetState ( $m_foo, "", @SW_MAXIMIZE )
; foobar handle #
$m_fooh = WinGetHandle( $m_foo )
;vol has been to 0 during fade out
$m_dec = 0
;File name played
$m_f = ""
;Remaining time
$m_r = "0"
; Status: 0 -> stop ; 1 -> playing; 2 -> paused
$m_s = "0"
$m_p = "?"
$m_t = ""
$m_l = "0"
$m_n = ""
$m_ne = ""
; new file name
$m_fn = ""
;ir
$m_ir = ""
$m_irn = 0
;art
$m_ojpgf = ""
$m_handle = 0
$m_search = 0
; file to send to SB
$m_sq=""
; number of foobar cursor press for next/previous album
$m_out=1
; Alt key pressed on IR remote control
$m_alt=0
; time [ms] when timer start for Alt stuff
$m_stimer=0
; don't allow more then one Alt up/down in PL before play, as I don't know where is the cursor
$m_noal = 0
; TUNING
; loop timer in ms
$m_lt= 90
; fill an array with PLs file names
if $m_plsd <> "" Then
Dim $a_plf
$a_plf=_FileListToArray($m_plsd,"*.m3u", 1)
If @Error Then
; no PLs saved
$m_plsd = ""
Else
; size then fill an array which will contain the number of PL, then the full PL paths
Dim $a_pln[$a_plf[0]+1]
$a_pln[0]=$a_plf[0]
for $i = 1 to $a_plf[0]
$a_pln[$i] = $m_plsd & "\" & $a_plf[$i]
next
; read the content of the first PL file in array a_pl
Dim $a_pl
$m_pln=1
_FileReadToArray($a_pln[$m_pln],$a_pl)
Endif
Endif
; receive notification
TCPSend($m_tcp,"listen 1" & @CRLF)
; main loop
While 1
; get title
$m_title = WinGetTitle($m_fooh)
if $m_title = "0" Then
Exit
EndIf
; check if foobar have stopped so there are $m_foo in the beginning of foobar title and a number to the end
If StringRegExp ( $m_title, "^" & $m_foo & ".*[0-9]$" ) Then
$m_idle = 1
Else
$m_idle = 0
Endif
If $m_idle = 0 Then
$m_fn = $a_tn[1]
$m_r = $a_tn[2]
$m_p = $a_tn[3]
Endif
Select
Case $m_idle = 1 AND $m_s <> "0"
$m_s = "0"
Case $m_idle = 0 AND $m_s = "0"
$m_s = "1"
$m_f = $m_fn
if $m_dec = 1 Then
$m_dec = 0
TCPSend($m_tcp,"mixer volume " & "100" & @CRLF)
EndIf
f_art()
$m_noal = 0
; song change or pause while playing
Case $m_idle = 0 AND $m_s = "1"
; goto pause
if $m_p = "1" Then
$m_s = "2"
Else
if $m_t = "0" Then
if $m_dec = 1 Then
$m_dec = 0
EndIf
f_art()
$m_noal = 0
Else
f_art()
Endif
Else
if $m_dec = 1 Then
$m_dec = 0
EndIf
f_art()
$m_noal = 0
Endif
$m_t = ""
$m_ne = ""
Else
if $m_ne = "" Then
MsgBox(0, "FooSQ Warning", "AMIP next song file not found, read intro")
Exit
EndIf
FileClose($m_amip)
$m_ne = "1"
Endif
Endif
$m_t = "0"
Endif
Endif
$m_f = $m_fn
EndIf
Case $m_idle = 0 AND $m_s = "2"
if $m_p = "?" Then
$m_s = "1"
EndIf
EndSelect
; check if Alt IR timer play for more then 5 sec
if $m_alt = 1 Then
if TimerDiff($m_stimer) >= 5000 Then
$m_alt = 0
Endif
Endif
; receive IR code
$m_data = TCPRecv ( $m_tcp, 2048 )
$m_search= StringInStr ( $m_data, "unknownir",2)
Select
Case $m_search > 0 AND $m_irn = 0
; first IR code received, need to disable the next one.
$m_ir = StringMid($m_data, $m_search +10 , 8)
Select
Case $m_ir = $m_ir_alt
; Alt key pressed
$m_alt = 1
; start timer
$m_stimer = TimerInit()
$m_irn = 1
Case $m_ir = $m_ir_next
;next
f_vol_dec()
Run($m_fooexe & " /next")
$m_irn = 1
Case $m_ir = $m_ir_random
;random
f_vol_dec()
Run($m_fooexe & " /rand")
$m_irn = 1
Case $m_ir = $m_ir_toggle
;toggle shuffle - normal
$m_sh = ControlGetText($m_fooh, "", "ComboBox1")
if $m_sh = "Default" Then
Run($m_fooexe & ' /"command:Shuffle (tracks)"')
$m_irn = 1
Endif
if $m_sh = "Shuffle (tracks)" Then
Run($m_fooexe & " /command:Default")
$m_irn = 1
Endif
Case $m_ir = $m_ir_pl_down AND $m_noal = 0 AND $m_plsd <> ""
; next album down in pl
; search current pos
$m_pos = _ArraySearch($a_pl, $m_f, 0, 0, 1, 0)
If @error Then
$a_pl = 0
For $i = 1 to $a_pln[0]
_FileReadToArray($a_pln[$i],$a_pl)
if @error = 0 Then
ExitLoop
Endif
Next
Endif
;find path
Dim $szDrive, $szDir, $szFName, $szExt
$a_path = _PathSplit($m_f, $szDrive, $szDir, $szFName, $szExt)
$m_path0 = $a_path[2]
For $i = $m_pos + 1 to $a_pl[0]
$a_path = _PathSplit($a_pl[$i], $szDrive, $szDir, $szFName, $szExt)
if $a_path[2] <> $m_path0 Then
$m_out = $i - $m_pos
ExitLoop
Endif
Next
WinActivate ( $m_fooh )
WinWaitActive ( $m_fooh )
For $i = 1 to $m_out
Send("{DOWN}")
Next
if $m_alt = 0 Then
f_vol_dec()
Send("{ENTER}")
Else
$m_alt = 0
$m_noal = 1
Endif
$m_irn = 1
Case $m_ir = $m_ir_pl_up AND $m_noal = 0 AND $m_plsd <> ""
;next album up in pl
If @error Then
$a_pl = 0
if @error = 0 Then
ExitLoop
Endif
Next
Endif
;find path
$m_reach = 0
For $i = $m_pos to 1 step -1
if $m_reach = 0 Then
$m_reach = 1
$m_path0=$a_path[2]
Else
ExitLoop
Endif
Endif
Next
$m_out = $m_pos -$i -1
Send("{UP}")
Next
if $m_alt = 0 Then
f_vol_dec()
Send("{ENTER}")
Else
$m_alt = 0
$m_noal = 1
Endif
$m_irn = 1
EndSelect
Case $m_search > 0 AND $m_irn = 1
$m_irn = 0
Case $m_search = 0 AND $m_irn = 1
$m_irn = 0
EndSelect
sleep($m_lt)
WEnd
Exit
Func f_vol_dec()
$a_fo = StringSplit("99.4,98.8,98.3,97.8,97.1,96,95,93.8,92,90,87,83,78,72,65,57,48,38,27,15,0", ",")
For $i = 1 to $a_fo[0]
TCPSend($m_tcp,"mixer volume " & $a_fo[$i] & @CRLF)
; fade out speed
sleep(170)
Next
$m_dec = 1
EndFunc
; Func create cd album cover art
Func f_art()
if $m_size <> 0 Then
; get path and find jpg
$a_path = _PathSplit($m_fn, $szDrive, $szDir, $szFName, $szExt)
$m_path = $a_path[2]
$m_drive = $a_path[1]
$m_jpgf = $m_drive & $m_path & $m_jpg
$m_search = FileFindFirstFile($m_jpgf)
FileClose($m_search)
If $m_search = -1 Then
; no art anymore
if $m_handle <> 0 Then
; previous art ?
GUIDelete($m_handle)
$m_handle = 0
EndIf
Else
; do it only for different art
if $m_ojpgf <> $m_jpgf Then
;get current active windows
$m_ahandle=_WinAPI_GetForegroundWindow()
; kill previous art
EndIf
$m_handle=GUICreate("AA", $m_size, $m_size, $m_aah, $m_aav, BitOR($WS_POPUP, $WS_SIZEBOX),$WS_EX_TOOLWINDOW)
GUICtrlSetColor(-1,0xFFFFFD)
WinSetOnTop("AA", "", 1)
GUICtrlCreatePic($m_jpgf, 0, 0, $m_size, $m_size)
GUISetState ()
;restore previous active window
WinActivate ($m_ahandle)
WinWaitActive ($m_ahandle)
EndIf
EndIf
;remember the current art
$m_ojpgf = $m_jpgf
Endif
EndFunc
oups cut and past problem ...
will see, sorry
Perhaps you could use some external storage for the scripts rather than pasting them here inside the posts? It would guarantee no characters (including even whitespace) are lost due to forum formatting, converted to emoticons or whatever. And for example pastebin.com (http://pastebin.com) allows you to show differences between subsequent revisions, which might be handy too.
Thanks for the guidance
I have posted the script in the squeezebox forum, because attachments are possible. Now indentation is preserved
http://forums.slimdevices.com/showthread.p...9193#post559193 (http://forums.slimdevices.com/showthread.php?p=559193#post559193)
Mmmm... can't get this to compile properly or run in Win 7. You prefer to get the handle from the Windows API rather than using the Win CLASSID to identify the correct app? I'm guessing that my method doesn't work reliably if you're running FB2K on a Mac Mini? I admire all the work you've done on the IR stuff BTW.
Unfortunately, I don't have windows 7
I have developed all the code with foobar 0.9.4 and the class id is different, so the idea was to find an universal solution for all F2k version (it's work on win xp)
All the code was really solid on foobar 0.9.4 , now I am facing bugs with 1.03 with IR codes (especially up/down in PLs) , I will try to solve it
About your volume code, I think that it is not a good idea to do digital volume on 16 bits sources (distortion) , but I will try to adapt my fade out lines
After, I think I will be finished from my side, all I need is there
I am just curious, do you have had feedback elsewhere then hydro/slim device forums about all the super documentation you have made on your site or successful use ?
Cheers
I have posted a new version in slim device forum, see release notes
If you are still unable to compile/use with windows 7, try to comment _WinAPI_GetForegroundWindow() (and disable cover art: $m_size = 0 )
give me the error messages
cheers
cheers
Hi! This works OK so far - nice job!
cheers
I've revised the code without the IR and album art components, this also makes it more stable on Win 7 and doesn't try to start Foobar2000 from within the script so you still need to start Foobar2000 first.
$m_ip = "127.0.0.1"
$m_port = 9090
$m_fooh = "[CLASS:{97E27FAA-C0B3-4b8e-A693-ED7881E99FC1}]"
$m_size = 0
$m_f = ""
$m_r = "0"
$m_s = "0"
$m_p = "?"
$m_t = ""
$m_l = "0"
$m_n = ""
$m_ne = ""
$m_fn = ""
$m_sq = ""
$m_lt = 50
$m_title = ""
$m_idle = 0
TCPStartup()
$m_tcp = TCPConnect($m_ip, $m_port)
If @error Then
MsgBox(48, "FooSQ Warning", "Squeezebox Server not responding")
Exit
EndIf
HotKeySet("{NUMPADADD}", "f_vol")
HotKeySet("{NUMPADSUB}", "f_vol")
HotKeySet("{NUMPADMULT}", "f_vol")
TCPSend($m_tcp, "listen 1" & @CRLF)
While 1
Sleep($m_lt)
Sleep($m_lt)
TCPSend($m_tcp, "stop" & @CRLF & "playlist clear" & @CRLF)
Exit
EndIf
EndIf
EndIf
If StringRegExp($m_title, "^" & $m_foo & ".*[0-9]$") Then
$m_idle = 1
Else
$m_idle = 0
EndIf
If $m_idle = 0 And $m_title <> "" Then
$m_fn = $a_tn[1]
$m_r = $a_tn[2]
$m_p = $a_tn[3]
EndIf
Select
Case $m_idle = 1 And $m_s <> "0"
$m_s = "0"
Case $m_idle = 0 And $m_s = "0"
$m_s = "1"
$m_f = $m_fn
Case $m_idle = 0 And $m_s = "1"
If $m_p = "1" Then
$m_s = "2"
TCPSend($m_tcp, "pause 1" & @CRLF)
Else
If $m_f <> $m_fn Then
If $m_t = "0" Then
If $m_fn <> $m_n Then
EndIf
Else
EndIf
$m_t = ""
$m_ne = ""
Else
If $m_r = "11" Or $m_r = "10" Then
If $m_ne = "" Then
Exit
EndIf
FileClose($m_amip)
TCPSend($m_tcp, "playlist insert " & $m_sq & @CRLF)
$m_ne = "1"
EndIf
EndIf
If $m_r = "0" Or $m_r = "1" Then
$m_t = "0"
EndIf
EndIf
$m_f = $m_fn
EndIf
Case $m_idle = 0 And $m_s = "2"
If $m_p = "?" Then
$m_s = "1"
EndIf
EndSelect
Sleep($m_lt)
WEnd
Func f_vol()
Select
Case StringInStr(@HotKeyPressed, "{NUMPADADD}")
TCPSend($m_tcp, "mixer volume +5" & @CRLF)
Case StringInStr(@HotKeyPressed, "{NUMPADSUB}")
TCPSend($m_tcp, "mixer volume -5" & @CRLF)
Case StringInStr(@HotKeyPressed, "{NUMPADMULT}")
TCPSend($m_tcp, "mixer volume 0" & @CRLF)
EndSelect
EndFunc ;==>f_vol
Exit
Many thanks to lex_nasa for the brilliant idea to use CLASS id for controlling the windows
Before to say bye bye for a while, I do a poll
- I am using only the lex_nasa version, don't need other function
- I am using IR
- I am using CD cover art pop up
- I like the fade out
- I am using skip album in playlists
- I am interested with seekbar move
- I don't use, I don't know how to do it
- I don't use, it's not working or too much bugged
Cheers
I got no feedback atall from SlimDevices forum, even after setting up the web page and hosting the compiled binary - I guess not enough people are interested. Oh well... thanks Marae again for your effort.
You too ! and, thanks a lot for your ideas
I will come back in October, I am just curious to see if more people have some interest and will answer to the poll.
Good bye
last comments,
remove Send($m_tcp, "listen 1" & @CRLF)
it's only used when you retrieve info from SC
in your site "this should now work with ANY version of Foobar2000 " false : classid change with older version ...
new code: (not posted before some interrest)
random cd cover if not available, to show my other albums to my friends
seekbar move
as it was buggy resynch: after 30sec, look for remaining time in SC, if desynchro , adjust. also for very long foosq sessions
cheers
seekbar move
I'm interested, particularly in seekbar move... have amended my my version of the script, will do web site soon. Thanks!
About seekbar move the idea is simple, if the difference of time during one loop is greater then lets say 3 sec, you take this new time and send it to SC
BUT
the next song (queued) start in SC sometime 20 sec later then expected. This a random bug from SC (I have 7.2 and don't want to change) .
So the choice is to disable gapless (no next song enqueued) as soon as seekbar is moved. After of course you enable gapless again
I will publish the code lets say in one month, it's need to be tested a little more and I am busy.
Great, I look forward to it... thanks again for your effort!
I'm getting some positive feedback on the Slimdevices forum now to say it's working and is great - hurrah! My latest streamlined code is here with a few more bug fixes:
$m_ip = "127.0.0.1"
$m_port = 9090
$m_lt = 50
$m_f = ""
$m_r = "0"
$m_s = "0"
$m_p = "?"
$m_t = ""
$m_n = ""
$m_ne = ""
$m_fn = ""
$m_sq = ""
$m_title = ""
$m_idle = 0
TCPStartup()
If @error Then
MsgBox(48, "FooSQ Warning", "Squeezebox Server not responding.")
Exit
EndIf
While 1
Sleep($m_lt)
Sleep($m_lt)
Exit
EndIf
EndIf
EndIf
If StringRegExp($m_title, "^" & "foobar2000" & ".*[0-9]$") Then
$m_idle = 1
Else
$m_idle = 0
EndIf
$m_fn = $a_tn[1]
$m_r = $a_tn[2]
$m_p = $a_tn[3]
EndIf
Select
$m_s = "0"
$m_s = "1"
$m_f = $m_fn
If $m_p = "1" Then
$m_s = "2"
Else
If $m_t = "0" Then
EndIf
EndIf
$m_t = ""
$m_ne = ""
Else
If $m_ne = "" Then
FileClose($m_amip)
$m_ne = "1"
EndIf
EndIf
$m_t = "0"
EndIf
EndIf
$m_f = $m_fn
EndIf
If $m_p = "?" Then
$m_s = "1"
EndIf
EndSelect
Sleep($m_lt)
WEnd
Func f_vol()
Select
EndSelect
EndFunc
Exit
Hi there
I have posted a new release with seekbar move here:
Read the release notes: Foobar Title config change !
Cheers
Oh dear, I can't get the seekbar to work, any move in the seekbar just restarts the song again. Thanks for your effort though!
is my original script working after you have changed foobar title by adding elapsed time ?
Ah, stupid me! Sorry, yes it works fine now!
Great stuff! You need to add a final stop and playlist clear before the last exit after the wend btw otherwise the song starts playing again, for me anyway.
Quit foobar first !
Quit foobar first !
Yes, I still need to add a stop & playlist clear before the final exit.
Strange,
in my version I do this and it's work.
- Do you have a very slow PC or very poor graphic card ?
- Can you add a msgbox below "if $m_title = "0" and quit foobar
; main loop
While 1
; get title
; no Foobar anymore ?
Exit
EndIf
- Can you add a msgbox below "if $m_title = "0" and quit foobar ?
Hi there, just to say that from my side, project is finished
Sure, me too, no plans to do any more work... thanks for all you've done.
I've made a new version for people with more than one squeeezebox. It allows you to send the playerid via the commandline in a windows shortcut.
Details here:
http://forums.slimdevices.com/showthread.p...9575&page=4 (http://forums.slimdevices.com/showthread.php?t=79575&page=4)
I've updated the script again to run smoother in Win7.
I've replaced the "if $m_title = 0" check (to see if FB2K is still running) with a WinExists function.
I've also added a couple of additional retries as sometimes WinGetTitle returns 0 when it shouldn't.
$m_ip = "127.0.0.1"
$m_port = 9090
$m_lt = 50
$m_fooexe = "C:\Program Files\foobar2000\foobar2000.exe"
$m_f = ""
$m_r = "0"
$m_s = "0"
$m_p = "?"
$m_t = ""
$m_n = ""
$m_ne = ""
$m_fn = ""
$m_sq = ""
$m_title = ""
$m_idle = 0
$m_ro = "0"
$m_seek = 0
$m_elt = ""
$m_seekt = 8
$m_0gap = 0
$m_0seek = 0
WinWait($m_fooh, "", 20)
TCPStartup()
If @error Then
Exit
EndIf
While 1
If Not WinExists($m_fooh) Then
Exit
EndIf
Sleep(300)
Sleep(300)
EndIf
EndIf
$m_idle = 1
Else
$m_idle = 0
EndIf
$m_fn = $a_tn[1]
$m_r = $a_tn[2]
$m_p = $a_tn[3]
$m_elt = $a_tn[4]
if number($m_seekt) > 0 AND $m_0seek = 0 Then
$m_seekv = number($m_r) - number($m_ro)
if abs($m_seekv) > $m_seekt AND $m_ro <> "0" AND $m_f = $m_fn Then
$m_seek = 1
Endif
Endif
$m_ro = $m_r
if $m_0seek > 0 then
$m_0seek = $m_0seek -1
endif
Else
$m_0gap = 1
$m_0seek = 50
EndIf
Select
$m_s = "0"
$m_s = "1"
$m_f = $m_fn
Case $m_idle = 0 AND $m_s = "1" AND $m_seek = 0
if $m_p = "1" Then
$m_s = "2"
Else
if $m_t = "0" Then
Endif
endif
$m_t = ""
$m_ne = ""
$m_f = $m_fn
Else
if number($m_r) < 12 AND number($m_r) > 1 AND $m_0gap = 0 Then
if $m_ne = "" Then
FileClose($m_amip)
$m_ne = "1"
Endif
Endif
if Number($m_r) < 2 Then
$m_t = "0"
$m_0gap = 0
Endif
Endif
EndIf
If $m_p = "?" Then
$m_s = "1"
EndIf
Case $m_idle = 0 AND $m_s = "1" AND $m_seek = 1
$m_seek = 0
$m_ne = ""
TCPSend($m_tcp,"playlist play " & StringReplace(StringReplace($m_fn, "\", "/"), " ", "%20") & @CRLF)
sleep(50)
TCPSend($m_tcp, "time " & $m_elt & @CRLF)
Sleep(50)
TCPSend($m_tcp,"pause 0" & @CRLF)
EndSelect
Sleep(50)
WEnd
Func f_vol()
Select
EndSelect
EndFunc
Hi, I've updated the code. This time I'm using WinGetHandle first, this stops WinGetTitle returning a false null result.
Also, user parameters are now configurable with an .ini file called FooSQ.ini with this data:
[parameters]
SqueezeBoxServerIP="127.0.0.1"
SqueezeBoxServerCLIPort=9090
SqueezeBoxPlayerID="00:04:20:10:0f:d2"
Foobar2000Location="C:\Program Files\foobar2000\foobar2000.exe"
AMIPFile="C:\nextsong.txt"
You need to change the PlayerID to the MAC address of the player you want to stream to.
Code is here:
$m_ip = IniRead("FooSQ.ini","parameters","SqueezeBoxServerIP","")
$m_port = IniRead("FooSQ.ini","parameters","SqueezeBoxServerCLIPort","")
$m_playerid = IniRead("FooSQ.ini","parameters","SqueezeBoxPlayerID","")
$m_fooexe = IniRead("FooSQ.ini","parameters","Foobar2000Location","")
$m_amip = IniRead("FooSQ.ini","parameters","AMIPFile","")
$m_f = ""
$m_r = "0"
$m_s = "0"
$m_p = "?"
$m_t = ""
$m_n = ""
$m_ne = ""
$m_fn = ""
$m_sq = ""
$m_title = ""
$m_idle = 0
$m_ro = "0"
$m_seek = 0
$m_elt = ""
$m_seekt = 8
$m_0gap = 0
$m_0seek = 0
WinWait($m_fooh, "", 30)
$m_fooha = WinGetHandle($m_fooh)
TCPStartup()
If @error Then
Exit
EndIf
While 1
If Not WinExists($m_fooha) Then
TCPSend($m_tcp,$m_playerid & " stop" & @CRLF & $m_playerid & " playlist clear" & @CRLF)
Exit
EndIf
$m_title = WinGetTitle($m_fooha)
$m_idle = 1
Else
$m_idle = 0
EndIf
$m_fn = $a_tn[1]
$m_r = $a_tn[2]
$m_p = $a_tn[3]
$m_elt = $a_tn[4]
$m_seek = 1
Endif
Endif
$m_ro = $m_r
endif
Else
$m_0gap = 1
$m_0seek = 50
EndIf
Select
$m_s = "0"
$m_s = "1"
$m_f = $m_fn
TCPSend($m_tcp,$m_playerid & " playlist play " & $m_sq & @CRLF)
if $m_p = "1" Then
$m_s = "2"
TCPSend($m_tcp,$m_playerid & " pause 1" & @CRLF)
Else
if $m_t = "0" Then
Endif
endif
$m_t = ""
$m_ne = ""
$m_f = $m_fn
Else
if $m_ne = "" Then
FileClose($m_amip)
TCPSend($m_tcp,$m_playerid & " playlist insert " & $m_sq & @CRLF)
$m_ne = "1"
Endif
Endif
$m_t = "0"
$m_0gap = 0
Endif
Endif
EndIf
If $m_p = "?" Then
$m_s = "1"
TCPSend($m_tcp,$m_playerid & " pause 0" & @CRLF)
EndIf
$m_seek = 0
$m_ne = ""
TCPSend($m_tcp,$m_playerid & " playlist clear" & @CRLF)
TCPSend($m_tcp,$m_playerid & " playlist play " & StringReplace(StringReplace($m_fn, "\", "/"), " ", "%20") & @CRLF)
sleep(50)
TCPSend($m_tcp,$m_playerid & " time " & $m_elt & @CRLF)
Sleep(50)
EndSelect
Sleep(50)
WEnd
Func f_vol()
Select
TCPSend($m_tcp,$m_playerid & " mixer volume +5" & @CRLF)
TCPSend($m_tcp,$m_playerid & " mixer volume -5" & @CRLF)
TCPSend($m_tcp,$m_playerid & " mixer volume 0" & @CRLF)
EndSelect
EndFunc
I am not new to Foobar but am not up to speed on how to compile this script. Is there a link to a compiled version of FooSQ?
thanks
Kerkula
Installation/compilation is described in post #1, logically enough.
Following up on my first post, I have FooSQ running well with one exception: it doesn't play gaplessly. Could someone help me trouble shoot this?
many thanks,
Kerkula
many thanks,
Kerkula
I have this running on the latest squeezebox server/firmware with latest Foobar. HOWEVER, it won't play gapless. The key is the that there is a lag time when pressing play and the music starting. This is why there is a gap between tracks. If the music can be made to start right away, then the gapless issue will rectify itself.
Actually, upon further thought, I don't think that playback delay has anything to do with gapless not working.
The SBT sees everything as an individual file via FooSQ. There is no playlist sent to it. You'll notice when a track plays that the SKIP to next track arrow is not highlighted. That's because there is no "next track" recognized by SBT. Thus there will be no gapless play.
I did fix the seekbar. It was just a simple change of a digit. Now it seeks more precisely. ----> $m_seekt = 8 <---- Change the 8 to 1.
I can cut and paste the latest working code if anyone is interested.
