So, I think I am getting the hang of foobar, but there is still a lot to learn....
How can i change the color/theme of the volume slider/seekbar/etc?
Is there a component that with find album art, and put it in my musics' tags?
How can I remove the very bottom bar?
How do I theme the actual shell style (Scroll bars, and all gray)
Thanks so much!
You Cannot change color with default foobar2000. It is dependent on your windows theme.
Using WSH Panel (foo_uie_wsh_panel.dll), it can be done if you are familiar with scripting. Here's something (http://www.hydrogenaudio.org/forums/index.php?showtopic=67257) to get you started
Foobar2000 does not embed album art. But mp3tag (http://www.mp3tag.de/en/) can do it for you. To download albumart, you can use Album Art Downloader (http://www.hydrogenaudio.org/forums/index.php?showtopic=57392).
Status bar can be hidden by going to the Main Menu at the top and selecting View/Show Statusbar.
TIP: You can assign a keyboard shortcut to this action.
Scollbar color is dependent on Windows XP theme.
But for color change of playlist, etc., answer is variable. It depends on the User Interface you are using, Default UI or Columns UI.
Edit reason: spelling
