"WMA has a richer, warmer sound"
Reply #36 – 2003-09-04 12:36:34
OT: IMO is the discussion about science/scientific methods/etc. very interesting and deserves to take place. OTH for me one of the things i appreciate most about HA is the scientific way auido-related (especially quality-related) topics are (supposed to be) discussed here. A more subjective/"open-minded" point of view *in discussions* is of no use IMO. Example: 1. "sample A and sample B sound identical, noone was able to ABX successfully." 2. "sample A and sample B sound identical, noone was able to ABX successfully, but once when I had a massage while listening to sample A and was totally relaxed I noticed that it moved somtheing in me. I never had this feeling with sample B". I prefer 1 and I am thankful that the people who run this site spend their precious time on making people keep the rules. IMO it'd be a sign of thankfulness and appreciation for this place and their work just to accept the way things work here. We are all guests, noone is forced to participate. __________________________ Now back on topic (if this thread is not already hopefully offtopic )Looking at the data again, we can't say this. There's a much higher level at 30Hz in the original than there is at 22Hz. So, perhaps the wmp psy-model says that this will mask a 3dB increase at 22Hz, and perhaps that's even correct... We should be trying more samples/music styles before we conclude. Definitely. Now that I've set up Excel it's not much work to repeat with other samples. I guess next I'll try with some sine sweep or similar, afterwards with the test samples from rjamorim's 64kbps listening test. One more reason why I think it's important to do more tests is, that I don't know how exact CEP's frequeny analysis is (Blackman-Harris window, 8192 Samples used), especially for low frequencies.CEP as good as the reference decoder, using 24bit resolution? I don't know. WMA9 "Pro" encoded files are opened by CEP as 16bit here. Is the reference decoder you're talking about publicly available?
