Topic: foo_pod - Foobar2000 meets the iPod (Read 1309996 times) previous topic - next topic
Reply #2025
what the lastest version of foo_pod? and where may i get it again?  im sry, ben searching for a while and seem to find old links.  im running 9.1 and im not sure if theres a foo_pod for it or not, but just trying to make sure b4 i go use something like rockbox
Reply #2026
foo_pod isn't going to be ported to 0.9...  You'll have to use foo_dop.
Reply #2027
sounds like foo_pod will not be ported
Sorry to disappoint you, but I have no plans to update foo_pod to Foobar 0.9.  And as far as I know, Foobar 0.9 will incompatible with earlier components, so you will have to have Foobar 0.8.x in order to use foo_pod.
Fortunately, Foobar 0.8 already has an ALAC decoder and I believe you could use Otto's iTunesEncoder script to losslessly transcode from FLAC -> ALAC, so there is no reason to wait for Foobar 0.9 to do what you are looking to do.
BTW, in case anyone is wondering, I was temporarily banned from posting on the Hydrogen Audio forums apparently because of my questioning of the availability of the 0.9 SDK.  I say apparently, because no one ever contacted me about the suspension, and the only thing I can find that could possibly be the cause is this post.  Anyway, that combined with other factors pretty much killed any desire to upgrade to Foobar 0.9.  Note that I am not planning on stopping foo_pod development, but it likely won't be focused on the changes necessary to make it run on Foobar 0.9.
Well seeing as people are pretty angry with what I said, let me clarify.  Firstly, I respect Aero greatly, as he has done a lot for the community.  His plugin is fantastic, and is one of the many reasons use foobar2000.  I am not angry that foo_pod (seemingly) is not going to be ported to 0.9, but with the reasons for Aero's decision not to.
The ban has very little with my decision not to port foo_pod to Foobar 0.9.  I believe I alluded to the possibility of not porting foo_pod to 0.9 even before the ban.
Anyway, in order of priority, the reasons include:
1. Not having much time to work on foo_pod, in general.
2. No good reason (for me) to upgrade to Foobar 0.9.
3. The lack of a publically available SDK for 0.9.
4. Forum difficulties (i.e. the ban).
When Foobar 0.9 and SDK are released, if I find a good reason to upgrade and the 0.8->0.9 SDK changes are minimial, I might do the porting.  But like I said, I really don't see any good reason to upgrade to Foobar 0.9 at this point, and several good reasons not to.
Well I can see a very big reason why he should port foo_pod to 0.9; He will make thousands of people happy  I really need this ^^
FerdiV
Reply #2028
FerdiV
Don't count on it.  It's not going to happen.  Move along, foo_pod is done. MediaMonkey was a recommended replacement earlier in the thread.
Reply #2029
All right, guys. I just got a 30GB iPod and installed foo_pod (I'm severely allergic to iTunes  ). However, there's a problem copying the files to the iPod.
I use FLAC with 1 file per album, which foo_pod seems to be confused by. When I select more than one track in the file, then send them to the iPod, it returns with
WARNING (foo_pod) : Unsupported file 'E:\Music\MKA\Air - Moon Safari.mka' has already been transcoded and is on the iPod
I assume it tests for equality on the file name, even though the metadata for each track is different.
Is there any way to turn the "already on iPod" setting off, and just transcode anyway? Or will this overwrite the previously-transcoded track?
"We demand rigidly defined areas of doubt and uncertainty!" - Vroomfondel, H2G2
Reply #2030
Somebody correct me if I'm mistaken, but I don't think that foo_pod can read embedded cuesheets in FLAC files and cannot transcode them properly.
I use one FLAC file per album, and I have covert to m4a first (using FB2K) and then send those files to my iPod.
Surf's Up!
"Columnated Ruins Domino"
Reply #2031
Hm. You're right. No matter what track I choose, it transcodes the first track in the file (but it knows where to stop, so it must have some notion of sub-indexes). I guess I'll have to do the transcoding myself. Bummer.
Reply #2032
foo_pod dead, and foo_dop still very embryonic and moving slowly. Any other ipod loading tools I should know about ?
Reply #2035
MediaMonkey: http://www.mediamonkey.com/
That isn't built into foobar2000 though. That's a totally different media player altogether and a blatant iTunes rip-off just less bloated, so is YamiPod. May as well keep using iTunes until components in foobar 0.9 improve. I already have foobar2000, iTunes, WMP and Real Player. I don't need another media program to fill up my computer.
With all these new features that Apple has now added then it is going to be even more difficult for third-party developers to play catch-up.
Reply #2036
There is no other fb2k iPod components as far as I know.  The only problem I have with iTunes is the lack of transcoding support.  Once that's there, I'll stick with iTunes.  fb2k doesn't bring anything to the table that I absolutely need.
Reply #2037
OK, new 5.1 G video ipods load fine with foo_pod, they're definitely slower and less responsive units though.....
However if you, like me use foo_pod to load your music with custom tags, and then use itunes to load videos.... look out for this one....
iTunes 7 has introduced a gapless playback feature, that you CAN'T disable. As soon as you connect an ipod it wades in and starts rebuilding the database with gapless info (whatever that might be - many $50 players can do gapless without stored tags), and screws your custom tags. AAARRRGGHHH. man I hate this sh1t.
You can stop it calculating, but it kicks in again as soon as you restart the app. No preference to disable. Apple suck.
Reply #2038
foo_pod version 0.9.9o is now available
This version just fixes a problem I noticed with Play Counts support on 5G iPods (possibly only with the latest firmware update).
I recently obtained a 5G iPod for testing, and noticed that it writes out a slightly different format for the Play Counts file, and foo_pod needed to be updated to handle this.  Play Counts is written by the iPod and contains information about ratings set on the iPod, along with a few other things like bookmark time and last played time.  Without this update, you would lose this data when you used foo_pod with a newer iPod.
As you have probably noticed, foo_pod development has ground to a halt.  This is basically because foo_pod and Foobar 0.8 were nearly perfect (for me) with my 4G iPod.  Now that I have (temporarily) have a 5G iPod, I have a new interest in extending foo_pod to work with the new database format, including adding support for transferring video content.  I am actually doing some interesting non-foo_pod related iPod development as well, which might end up being applicable to a hybrid Foobar 0.9/COM Automation server/my thing project.
Reply #2039
Nice. Does this allow one to send playlists to the iPod? Does it transfer the ReplayGain settings?
The ability to transfer ReplayGain settings and to have a playlist to keep my songs in the order I want them is all I really want from an iPod utility. iTunes is perfect except it doesn't transfer the ReplayGain settings. foo_dop is perfect except it doesn't send the playlist.
Reply #2040
Hi Aero,
nice to see you back!
If you need beta testers, I'm sure you'll find many here.
Cheers.
Alessandro
Reply #2041
It's alive!!
It's good to see you again, and let us know if you need any help! (spare iPods, software testing, personal favors, whatever)
Reply #2042
Seriously, there are many people here (myself included) who are just jumping on this bandwagon and you COULD be our saviour.
Can anyone point me to some information on this plugin? i.e., what it can and cannot do?
?eace
Reply #2044
Thank you (nice website by the way)
but is there no foo_pod plugin for foobar2k v0.9.4?
?eace
Reply #2046
Good to see you back, Aero. Will look forward to new developments. Things over at foo_dop are moving so slowly; it will be along time before it's useable, if ever. I will being using foo_pod for the foreseeable future. I'm happy to stick on itunes 6.0.5 to load videos until there is an alternative. I will NEVER use itunes 7 until you can disable that gapless sh1t.
all the best
Niels
Reply #2047
Guess we're not 'back'...
Reply #2048
i don't know but i get this error
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 9CF4BF59h
Access violation, operation: read, address: 9CF4BF59h
Call path:
WinMain=>app_init
Stack (0012FBA4h):
0012FB84h:  0117EEB8 7C9D93C0 77E943DD 7C9D93C0
0012FB94h:  00000004 00000000 0117E3C4 00000000
0012FBA4h:  77E26725 77DBC218 0163F030 00000004
0012FBB4h:  0012FF0C 016020CF 001A63D4 00000004
0012FBC4h:  0163F030 77BFC21B 0142AA98 0012FEF8
0012FBD4h:  004442AC 01425718 77BFC21B 00000030
0012FBE4h:  0012FBF8 004012B8 004012C6 0012FEF8
0012FBF4h:  0012FC00 015FBD5C 01425718 0040129C
0012FC04h:  0043416A 0012FEF8 0000001E 0012FFB0
0012FC14h:  01620D68 FFFFFFFF 004118E9 0117E294
0012FC24h:  00152339 00000000 00890000 7C920732
0012FC34h:  00000003 00890718 00890000 00000000
0012FC44h:  0012FC34 0012FE78 0012FE78 7C91EE18
0012FC54h:  00000141 0012FE88 7C921538 7C921596
0012FC64h:  7C9206EB 0117E294 00000010 00000000
0012FC74h:  7C927CB7 7C927BF5 00890608 7C927BB0
0012FC84h:  00000000 00894B18 00000400 008903F0
0012FC94h:  00000000 00000000 7C9206EB 00890270
0012FCA4h:  00890640 00895590 00890358 00895598
0012FCB4h:  00000000 008901D8 00000000 00150640
Registers:
EAX: 77DBC218, EBX: 00000000, ECX: 77E268B4, EDX: 00000004
ESI: 774CFAC3, EDI: 004442AC, EBP: 0012FBB4, ESP: 0012FBA4
Unable to identify crash location
Loaded modules:
foobar2000                       loaded at 00400000h - 00452000h
ntdll                            loaded at 7C910000h - 7C9C6000h
kernel32                         loaded at 7C800000h - 7C8FF000h
USER32                           loaded at 77D10000h - 77DA0000h
GDI32                            loaded at 77E40000h - 77E87000h
ole32                            loaded at 774B0000h - 775ED000h
ADVAPI32                         loaded at 77F40000h - 77FEB000h
RPCRT4                           loaded at 77DA0000h - 77E31000h
msvcrt                           loaded at 77BE0000h - 77C38000h
COMCTL32                         loaded at 773A0000h - 774A3000h
SHLWAPI                          loaded at 77E90000h - 77F06000h
utf8api                          loaded at 10000000h - 1000D000h
comdlg32                         loaded at 76360000h - 763AA000h
SHELL32                          loaded at 7C9D0000h - 7D1EC000h
foo_abx                          loaded at 008D0000h - 008DC000h
foo_ac3                          loaded at 008E0000h - 008F3000h
foo_adpcm                        loaded at 00900000h - 00915000h
foo_albumlist                    loaded at 00920000h - 0092B000h
foo_ape                          loaded at 00930000h - 0094F000h
foo_apl                          loaded at 00950000h - 0095A000h
foo_audioscrobbler               loaded at 00960000h - 00980000h
LIBCURL                          loaded at 00980000h - 00999000h
WS2_32                           loaded at 71A30000h - 71A47000h
WS2HELP                          loaded at 71A20000h - 71A28000h
WINMM                            loaded at 76B00000h - 76B2E000h
foo_bitcompare                   loaded at 00A70000h - 00A79000h
foo_burninate                    loaded at 00A80000h - 00A8C000h
VERSION                          loaded at 77BD0000h - 77BD8000h
foo_cdda                         loaded at 00A90000h - 00A9E000h
foo_clienc                       loaded at 00AA0000h - 00AAB000h
foo_console                      loaded at 00AB0000h - 00AB7000h
foo_convolve                     loaded at 00AC0000h - 00B0F000h
foo_dbsearch                     loaded at 00B10000h - 00B2A000h
foo_dirwatch                     loaded at 00B30000h - 00B39000h
MSVCR70                          loaded at 7C000000h - 7C054000h
foo_diskwriter                   loaded at 00B50000h - 00B62000h
foo_dsp_crossfade                loaded at 00B70000h - 00B77000h
foo_dsp_crossfeed                loaded at 00B80000h - 00B98000h
foo_dsp_extra                    loaded at 00BB0000h - 00BC5000h
foo_dsp_nogaps                   loaded at 00BD0000h - 00BD7000h
foo_dsp_pause                    loaded at 00BE0000h - 00BE7000h
foo_dsp_skip_silence             loaded at 00BF0000h - 00BF7000h
foo_dsp_soundtouch               loaded at 00C00000h - 00C0D000h
MSVCP60                          loaded at 76030000h - 76095000h
foo_dts                          loaded at 00C10000h - 00C39000h
foo_dumb                         loaded at 00C40000h - 00C6C000h
foo_dynamics                     loaded at 00C70000h - 00C77000h
foo_faac                         loaded at 00C80000h - 00CB3000h
foo_flac                         loaded at 00CC0000h - 00CDF000h
foo_flaccer                      loaded at 00CE0000h - 00CFA000h
foo_freedb                       loaded at 00D00000h - 00D1D000h
foo_gep                          loaded at 00D20000h - 00D46000h
MSIMG32                          loaded at 76330000h - 76335000h
OLEAUT32                         loaded at 770F0000h - 7717C000h
foo_history                      loaded at 00D50000h - 00D65000h
foo_id3v2                        loaded at 00D70000h - 00DA1000h
foo_inet_radio                   loaded at 00DB0000h - 00DC6000h
foo_infobox                      loaded at 00DD0000h - 00DE3000h
foo_input_std                    loaded at 00DF0000h - 00E8D000h
MSACM32                          loaded at 77BB0000h - 77BC5000h
foo_lpac                         loaded at 00E90000h - 00E97000h
lpac_codec_api                   loaded at 00EA0000h - 00EAA000h
lpaccodec                        loaded at 00EB0000h - 00ED9000h
foo_lyricsdb                     loaded at 01100000h - 01111000h
WININET                          loaded at 77180000h - 77227000h
CRYPT32                          loaded at 77A50000h - 77AE5000h
MSASN1                           loaded at 77AF0000h - 77B02000h
MSVCP70                          loaded at 7C080000h - 7C0F7000h
foo_masstag                      loaded at 01120000h - 01134000h
foo_matroska                     loaded at 01140000h - 01182000h
foo_midi                         loaded at 011E0000h - 0126F000h
MFC42                            loaded at 73D40000h - 73E3E000h
MFC42LOC                         loaded at 61E00000h - 61E0E000h
foo_monkey                       loaded at 01190000h - 011AC000h
foo_mpeg4u                       loaded at 01270000h - 01299000h
foo_null                         loaded at 011B0000h - 011B7000h
foo_ofr                          loaded at 011C0000h - 011C6000h
OptimFROG                        loaded at 012A0000h - 012CC000h
foo_oggpreview                   loaded at 012E0000h - 013F5000h
foo_osd                          loaded at 01400000h - 0140E000h
gdiplus                          loaded at 4EBD0000h - 4ED73000h
foo_output_std                   loaded at 01520000h - 01529000h
foo_out_dsound_ex                loaded at 01530000h - 01539000h
DSOUND                           loaded at 73E80000h - 73EDC000h
foo_out_ks                       loaded at 01550000h - 0155B000h
SETUPAPI                         loaded at 778F0000h - 779E7000h
foo_playcount                    loaded at 01560000h - 0156B000h
MSVCR71                          loaded at 7C340000h - 7C396000h
foo_playlistgen_ex               loaded at 01580000h - 0158F000h
foo_playlist_tree                loaded at 01590000h - 015D1000h
foo_pod                          loaded at 015E0000h - 01675000h
MSVCP71                          loaded at 7C3A0000h - 7C41B000h
foo_pphsresample                 loaded at 01680000h - 01690000h
foo_preview                      loaded at 01690000h - 0169C000h
foo_psf                          loaded at 016A0000h - 0174C000h
foo_quicktag                     loaded at 01750000h - 01759000h
foo_read_http                    loaded at 01760000h - 01769000h
foo_rgscan                       loaded at 01770000h - 0177D000h
foo_scheduler                    loaded at 01780000h - 01795000h
foo_scroll                       loaded at 017A0000h - 017A6000h
foo_search_ex                    loaded at 017B0000h - 017B8000h
foo_shn                          loaded at 017C0000h - 017CF000h
foo_shuffle                      loaded at 017D0000h - 017DB000h
foo_sid                          loaded at 01820000h - 01868000h
foo_speex                        loaded at 017E0000h - 017F8000h
foo_syfm                         loaded at 01800000h - 0180A000h
foo_toaster                      loaded at 01870000h - 01891000h
foo_tta                          loaded at 018A0000h - 018A9000h
foo_tta_old                      loaded at 018B0000h - 018B9000h
foo_uie_albumart                 loaded at 018C0000h - 018D0000h
foo_uie_dbexplorer               loaded at 018D0000h - 018DB000h
foo_uie_lyrics                   loaded at 018E0000h - 0190C000h
foo_uie_tabs                     loaded at 01910000h - 0191A000h
foo_uie_trackinfo                loaded at 01920000h - 0192B000h
foo_ui_columns                   loaded at 01930000h - 01967000h
foo_ui_gfx                       loaded at 01970000h - 01998000h
foo_ui_std                       loaded at 019A0000h - 019B7000h
foo_unpack                       loaded at 019C0000h - 019F1000h
foo_utils                        loaded at 01A00000h - 01A11000h
foo_vis_bacon                    loaded at 01A20000h - 01A38000h
foo_vis_manager                  loaded at 01A40000h - 01A48000h
foo_vis_simple_spectrum          loaded at 01A50000h - 01A5C000h
foo_vorbisenc                    loaded at 01A60000h - 01B71000h
foo_wavpack                      loaded at 01B80000h - 01B94000h
foo_wma                          loaded at 01BA0000h - 01BB9000h
WMVCore                          loaded at 086C0000h - 08904000h
WMASF                            loaded at 070D0000h - 0710B000h
uxtheme                          loaded at 5B180000h - 5B1B8000h
MSCTF                            loaded at 746B0000h - 746FB000h
CAPTLIB                          loaded at 01C60000h - 01C80000h
OLEACC                           loaded at 74C10000h - 74C3C000h
dciman32                         loaded at 73B30000h - 73B36000h
Powrprof                         loaded at 74A60000h - 74A68000h
CLBCATQ                          loaded at 76F90000h - 7700F000h
COMRes                           loaded at 77010000h - 770E2000h
xpsp2res                         loaded at 20000000h - 202D5000h
msi                              loaded at 031A0000h - 03466000h
SXS                              loaded at 75E40000h - 75EF0000h
imagehlp                         loaded at 76C50000h - 76C78000h
DBGHELP                          loaded at 59E60000h - 59F01000h
Stack dump analysis:
Address: 77E26725h, location: "RPCRT4", loaded at 77DA0000h - 77E31000h
Symbol: "NdrStubForwardingFunction" (+00000017h)
Address: 77DBC218h, location: "RPCRT4", loaded at 77DA0000h - 77E31000h
Symbol: "CreateProxyFromTypeInfo" (+000000D7h)
Address: 0163F030h, location: "foo_pod", loaded at 015E0000h - 01675000h
Address: 016020CFh, location: "foo_pod", loaded at 015E0000h - 01675000h
Address: 77BFC21Bh, location: "msvcrt", loaded at 77BE0000h - 77C38000h
Symbol: "free" (+00000000h)
Address: 004012B8h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 004012C6h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 015FBD5Ch, location: "foo_pod", loaded at 015E0000h - 01675000h
Address: 0040129Ch, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 0043416Ah, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 01620D68h, location: "foo_pod", loaded at 015E0000h - 01675000h
Address: 004118E9h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 0117E294h, location: "foo_matroska", loaded at 01140000h - 01182000h
Address: 7C920732h, location: "ntdll", loaded at 7C910000h - 7C9C6000h
Symbol: "RtlAllocateHeap" (+0000015Eh)
Address: 7C91EE18h, location: "ntdll", loaded at 7C910000h - 7C9C6000h
Symbol: "strchr" (+00000117h)
Address: 7C921538h, location: "ntdll", loaded at 7C910000h - 7C9C6000h
Symbol: "wcsncpy" (+00000AA9h)
Address: 7C921596h, location: "ntdll", loaded at 7C910000h - 7C9C6000h
Symbol: "wcsncpy" (+00000B07h)
Address: 7C9206EBh, location: "ntdll", loaded at 7C910000h - 7C9C6000h
Symbol: "RtlAllocateHeap" (+00000117h)
Address: 7C927CB7h, location: "ntdll", loaded at 7C910000h - 7C9C6000h
Symbol: "RtlReAllocateHeap" (+000002BAh)
Address: 7C927BF5h, location: "ntdll", loaded at 7C910000h - 7C9C6000h
Symbol: "RtlReAllocateHeap" (+000001F8h)
Address: 7C927BB0h, location: "ntdll", loaded at 7C910000h - 7C9C6000h
Symbol: "RtlReAllocateHeap" (+000001B3h)
Address: 00446350h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 7C921B09h, location: "ntdll", loaded at 7C910000h - 7C9C6000h
Symbol: "RtlLogStackBackTrace" (+00000025h)
Address: 004465DCh, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 0043946Ch, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 77C09D60h, location: "msvcrt", loaded at 77BE0000h - 77C38000h
Symbol: "strerror" (+00002B66h)
Address: 7C92094Eh, location: "ntdll", loaded at 7C910000h - 7C9C6000h
Symbol: "RtlAcquirePebLock" (+00000031h)
Address: 0043A200h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 0043A1ECh, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 00410FD5h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 00438DB5h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 00400000h, location: "foobar2000", loaded at 00400000h - 00452000h
Version info:
foobar2000 v0.8.3
UNICODE
