HydrogenAudio
Lossy Audio Compression => MP3 => MP3 - General => Topic started by: stevekim on 2004-06-14 06:03:35
Title: Frontah problems with Genre tag?
Post by: stevekim on 2004-06-14 06:03:35
Hope someone here can help out...
I'm transcoding from flac to mp3 using Frontah. Frontah is correctly transferring the vorbis tag info to the id3v1.1 tags, but is not copying over the 'Genre' tag at all. If I enable id3v2, the 'genre' tag is copied over, though.
Can anyone tell me how to get Frontah to copy over the 'genre' tag using id3v1.1 tag format?
Thanks,
Steve
Post by: dreamliner77 on 2004-06-14 06:18:15
http://www.hydrogenaudio.org/forums/index....howtopic=22400& (http://www.hydrogenaudio.org/forums/index.php?showtopic=22400&)
No need to post twice.
Post by: madah on 2004-06-14 10:28:28
Your genre does no map exactly to one of the defined ID3v1-genres.
Frontah uses the same genre-list as Winamp, which is somewhat different from the "official" genre-list at id3.org (http://www.id3.org/id3v2.3.0.html#secA)
One example is "AlternRock", which could have several names: "Alt. Rock", "Alternative Rock", ...
