Topic: Need help (script of the ELPlaylist Settings) (Read 2114 times) previous topic - next topic
Hey !
I try to remove those albums art and annoying "reflects" from my playlist
Screenshot : http://puu.sh/jYtKB.png
Tracklist script :
$puts(config_name,'eigen')
$puts(foo_path,%FOOBAR_PATH%)
$puts(z,$get(foo_path)'images/'$get(config_name))
$puts(bg.color,%eigen_bg_color%)
$puts(text.color,$if(%el_isplaying%,%PLAY.TEXT.COLOR%,%TEXT.COLOR%))
$puts(track.text,%title%)
$font(%font.dafault%)
$puts(TR.width,%TRACKNR.WIDTH%)
$puts(RAT.width,%RATING.WIDTH%)
$puts(BIT.width,%BITRATE.WIDTH%)
$puts(BPM.width,%BPM%)
$puts(L.width,%LENGTH.WIDTH%)
$puts(text.right.margin,9)
$puts(text.right,$add($get(RAT.width),$get(BIT.width),$get(L.width),$get(text.right.margin)))
$puts(art.size,%__ART.SIZE__%)
$puts(text.top,0)
//------------Background
$drawrect(,,,,$get(bg.color),$get(bg.color),)
$if(%el_selected%
$drawroundrect($sub($get(text.left),5),$add($get(text.top),1),$sub(%el_width%,$get(text.left),-3),$sub(%el_height%,3),2,2,%SELECT.RECT.COLOR.B%,%SELECT.RECT.COLOR.A%,vertical)
//$ifequal($mod(%el_item_index%,2),0,
$drawroundrect($sub($get(text.left),5),$add($get(text.top),1),$sub(%el_width%,$get(text.left),-3),$sub(%el_height%,3),2,2,%BG.RECT.COLOR.B%,%BG.RECT.COLOR.A%,vertical)
//------------Track Info
$if($stricmp(%album artist%,%artist%),$puts(VA,0),$puts(VA,1))
$puts(rating,$if2(%rating%,0))
$if($not(%el_isplaying%)
    $drawtextex($get(track.text2),
            $get(text.left),$get(text.top),$get(TR.width),%el_height%,$get(text.color),vcenter end_ellipsis)
  $drawtextex($get(track.text)$ifgreater($get(VA),0, - %artist%,),
            $add($get(text.left),$get(TR.width)),$get(text.top),$sub(%el_width%,$get(text.left),$get(text.right),$get(TR.width),5),%el_height%,$get(text.color),vcenter end_ellipsis)
//    $drawtextex($repeat($char(8226),$get(rating)),
//            $sub(%el_width%,$get(text.right)),$add($get(text.top),1),$get(RAT.width),%el_height%,$get(text.color),top)
    $drawtextex(%bitrate% kbps,
            $sub(%el_width%,$get(BIT.width),$get(L.width),$get(text.right.margin)),$get(text.top),$get(BIT.width),%el_height%,$get(text.color),vcenter right)
    $drawtextex(%BPM% bpm,
            $sub(%el_width%,$get(BPM.width),$get(L.width),$get(L.width),$get(L.width),$get(text.right.margin)),$get(text.top),$get(BPM.width),%el_height%,$get(text.color),vcenter right)
    $drawtextex(%length%,
            $sub(%el_width%,$get(L.width),$get(text.right.margin)),$get(text.top),$get(L.width),%el_height%,$get(text.color),vcenter right)
//------------Rating
//------------ Cover Art + Background
$enabledraw(1)
$setworldtransform(2)
$puts(art.top,2)
$puts(art.left,%ART.MARGIN%)
$puts(e.cover,%__ART.COVER__%)
$drawrect(,$mul(%el_item_count%,%el_row_height%),,,$get(bg.color),$get(bg.color),),
$puts(e.cover',$get(z)'/cover/radio.png)
$if($strstr(%url%,radioparadise)
$puts(e.cover,$get(z)'/cover/radioparadise.png')
$if($strstr(%path%,fm4)
$puts(e.cover,$get(z)'/cover/fm4.png')
$if($strstr(%url%,fm4)
$if($findfile($get(e.cover)),
$puts(e.cover,$get(z)'/cover/nocover.png')
$puts(e.cover,$findfile($get(e.cover)))
  $imageabs($get(art.left),$get(art.top),$get(art.size),$get(art.size),%path%,artreader,nokeepaspect,)
  $imageabs($get(art.left),$get(art.top),$get(art.size),$get(art.size),$get(z)'\cover\case2.png',nokeepaspect,,)
  $imageabs($get(art.left),$get(art.top),$get(art.size),$get(art.size),$get(e.cover),,,,)
//------------Reflection
$puts(refl.color,$left($get(bg.color),11))
$ifequal(%ON.REFLECTION%,1
    $if($stricmp('FOO_LASTFM',$left(%path%,10))
    $imageabs($get(art.left),$add($get(art.top),$get(art.size)),$get(art.size),$el_scale(50,$get(art.size)),%path%,artreader nokeepaspect,6,)
    $imageabs($get(art.left),$add($get(art.top),$get(art.size)),$get(art.size),$el_scale(50,$get(art.size)),$get(z)'\cover\case2.png',top nokeepaspect,6)
    $gradientrect($get(art.left),$add($get(art.top),$get(art.size)),$get(art.size),$el_scale(50,$get(art.size)),$get(refl.color)-164,$get(refl.color)-255)
    $imageabs($get(art.left),$add($get(art.top),$get(art.size)),$get(art.size),$el_scale(50,$get(art.size)),$get(e.cover),top nokeepaspect,6)
Per second script :
$font(%font.play%)
$puts(text.right.margin,8)
$puts(art.size,-5)
$puts(text.top,0)
$puts(prog.top,2)
$puts(track.text,$if($strcmp($left(%path%,7),'http://'),%title% - %artist%,%title%))
//------------Progress Background
$puts(prog.width,$muldiv(%playback_time_seconds%,$sub(%el_width%,$get(text.left),2),%length_seconds%))
$gradientrect($sub($get(text.left),4),$get(prog.top),$sub(%el_width%,$get(text.left),-2),$sub(%el_height%,4),%PLAY.RECT.COLOR.B%,%PLAY.RECT.COLOR.A%,vertical)
$if(%length%
$gradientrect($sub($get(text.left),4),$get(prog.top),$get(prog.width),$sub(%el_height%,4),%PROG.RECT.COLOR.B%,%PROG.RECT.COLOR.A%,vertical)
//------------Track Text
    $drawtextex('- '%playback_time_remaining%,
//------------Now Playing
$font(Arial,11,)
$drawtextex($char(9658),$get(text.left),$get(text.top),$get(TR.width),%el_height%,$get(text.color),vcenter end_ellipsis)
I have tried to remove line after lines but I didn't found anything...
It will be great if you can help me =)
Thanks ! (Sorry for my english)
Those "reflects" are usually scripted in ELPlaylist Settings- Script- Group Header. Usually those reflects are just images drawn on top to give the shiny effect. One quick simple solution would be to find said image in the config folder and delete or rename it if you don't want to use it.
