i have Ogg Vorbis files ripped by
EAC 0.95b4, encoded with
Vorbis BS; Lancer(SSE3) [20061110] (based on aoTuV b5 [20061024]) - 320 kbps, they were tagged before with
MusicBrainz Picard 0.7.2 with no trouble, but now when i tagged them with the newer
Picard 0.9.0 tags were applied successfully, but the files are no longer readable by any player, i thought it was something wrong with the tags so i tried to clear them, and then tried using UTF-8/UTF-16 and even ISO charset with no avail, the files are unplayable and recognized as 0:00 length in Adobe Audition 2.0, Foobar2000 0.8.3 and Winamp 5.5, while they crash anything else, WMP10, GSpot 2.70a, SnackAmp 3.1.2, oggsplit 1.0.1..etc..
tagging tools shows that
OGGComment is written correctly (
TagTuner 1.9.0,
Picard 0.9.0 and
OOOGGCommentDump are giving the correct tag info)...
so i got to some tools for verification and that lead to the following:
Vorbis Comment 1.1.1:
vorbiscomment -l 01.ogg
Failed to open file as vorbis: Corrupt secondary header.
OggInfo 1.1.0:
Ogginfo 01.ogg
Warning: Could not decode vorbis header packet - invalid vorbis stream (1)
Vorbis stream 1:
Total data length: 0 bytes
Playback length: 0m:00.000s
Average bitrate: -1.#IND00 kb/s
Logical stream 1 ended
Warning: Hole in data found at approximate offset 2572787 bytes. Corrupted ogg.
Oggdec 1.9.3:
oggdec -p 01.ogg
OggDec v1.9.3 (libVorbis 1.1.2) Compiled on: Oct 25 2
Input 01.ogg does not appear to be an Ogg bitstream.
********** Done decoding all input files. **********
OOOggdump.exe:
C:\PROGRA~1\ILLIMI~1\OGGCOD~1>oooggdump.exe 01.ogg
Page Location : 0 to 58
Ver No : 0
Head Flags : bos
Granule Pos : 0
Serial No : 2757
Seq No : 0
Checksum : 1740153468
Num Segs : 1
Head Size : 28
Data Size : 30
Page Size : 58
Num Packets : 1
------ Packet 0 (30 bytes) -------
00000000: 01 76 6F 72 62 69 73 00 00 00 00 02 44 AC 00 00 .vorbis.....D...
00000016: 00 00 00 00 00 E2 04 00 00 00 00 00 B8 01 ..............
Page Location : 58 to 4052
Ver No : 0
Head Flags :
Granule Pos : 0
Serial No : 2757
Seq No : 1
Checksum : 1369679579
Num Segs : 16
Head Size : 43
Data Size : 3951
Page Size : 3994
Num Packets : 2
------ Packet 0 (636 bytes) -------
00000000: 03 76 6F 72 62 69 73 3A 00 00 00 42 53 3B 20 4C .vorbis:...BS; L
00000016: 61 6E 63 65 72 28 53 53 45 33 29 20 5B 32 30 30 ancer(SSE3) [200
00000032: 36 31 31 31 30 5D 20 28 62 61 73 65 64 20 6F 6E 61110] (based on
00000048: 20 61 6F 54 75 56 20 62 35 20 5B 32 30 30 36 31 aoTuV b5 [20061
00000064: 30 32 34 5D 29 11 00 00 00 0D 00 00 00 61 6C 62 024])........alb
00000080: 75 6D 3D 4D 79 73 74 69 63 61 0F 00 00 00 61 73 um=Mystica....as
00000096: 69 6E 3D 42 30 30 30 46 41 4F 41 49 53 1E 00 00 in=B000FAOAIS...
00000112: 00 61 6C 62 75 6D 61 72 74 69 73 74 73 6F 72 74 .albumartistsort
00000128: 3D 41 78 65 6C 20 52 75 64 69 20 50 65 6C 6C 39 =Axel Rudi Pell9
00000144: 00 00 00 6D 75 73 69 63 62 72 61 69 6E 7A 5F 61 ...musicbrainz_a
00000160: 72 74 69 73 74 69 64 3D 34 35 39 31 65 61 31 30 rtistid=4591ea10
00000176: 2D 65 36 35 34 2D 34 63 66 63 2D 39 36 31 35 2D -e654-4cfc-9615-
00000192: 35 36 39 38 37 63 35 62 63 62 66 65 23 00 00 00 56987c5bcbfe#...
00000208: 74 69 74 6C 65 3D 54 68 65 20 4D 79 73 74 65 72 title=The Myster
00000224: 69 6F 75 73 20 52 65 74 75 72 6E 20 28 69 6E 74 ious Return (int
00000240: 72 6F 29 15 00 00 00 61 72 74 69 73 74 3D 41 78 ro)....artist=Ax
00000256: 65 6C 20 52 75 64 69 20 50 65 6C 6C 11 00 00 00 el Rudi Pell....
00000272: 72 65 6C 65 61 73 65 74 79 70 65 3D 61 6C 62 75 releasetype=albu
00000288: 6D 11 00 00 00 72 65 6C 65 61 73 65 63 6F 75 6E m....releasecoun
00000304: 74 72 79 3D 44 45 38 00 00 00 6D 75 73 69 63 62 try=DE8...musicb
00000320: 72 61 69 6E 7A 5F 61 6C 62 75 6D 69 64 3D 30 33 rainz_albumid=03
00000336: 36 30 39 61 34 38 2D 61 33 39 32 2D 34 31 34 61 609a48-a392-414a
00000352: 2D 39 33 61 61 2D 65 31 35 63 38 65 64 36 37 66 -93aa-e15c8ed67f
00000368: 35 34 16 00 00 00 72 65 6C 65 61 73 65 73 74 61 54....releasesta
00000384: 74 75 73 3D 6F 66 66 69 63 69 61 6C 0E 00 00 00 tus=official....
00000400: 74 6F 74 61 6C 74 72 61 63 6B 73 3D 31 30 1A 00 totaltracks=10..
00000416: 00 00 61 6C 62 75 6D 61 72 74 69 73 74 3D 41 78 ..albumartist=Ax
00000432: 65 6C 20 52 75 64 69 20 50 65 6C 6C 3E 00 00 00 el Rudi Pell>...
00000448: 6D 75 73 69 63 62 72 61 69 6E 7A 5F 61 6C 62 75 musicbrainz_albu
00000464: 6D 61 72 74 69 73 74 69 64 3D 34 35 39 31 65 61 martistid=4591ea
00000480: 31 30 2D 65 36 35 34 2D 34 63 66 63 2D 39 36 31 10-e654-4cfc-961
00000496: 35 2D 35 36 39 38 37 63 35 62 63 62 66 65 0F 00 5-56987c5bcbfe..
00000512: 00 00 64 61 74 65 3D 32 30 30 36 2D 30 38 2D 32 ..date=2006-08-2
00000528: 35 0D 00 00 00 74 72 61 63 6B 6E 75 6D 62 65 72 5....tracknumber
00000544: 3D 31 19 00 00 00 61 72 74 69 73 74 73 6F 72 74 =1....artistsort
00000560: 3D 41 78 65 6C 20 52 75 64 69 20 50 65 6C 6C 38 =Axel Rudi Pell8
00000576: 00 00 00 6D 75 73 69 63 62 72 61 69 6E 7A 5F 74 ...musicbrainz_t
00000592: 72 61 63 6B 69 64 3D 63 38 37 63 32 62 35 36 2D rackid=c87c2b56-
00000608: 65 30 61 63 2D 34 65 31 32 2D 61 66 34 39 2D 64 e0ac-4e12-af49-d
00000624: 37 32 34 33 65 35 34 34 66 33 62 01 7243e544f3b.
------ Packet 1 (3315 bytes) ------- ** TRUNC **
00000000: 05 76 6F 72 62 69 73 2B 42 43 56 01 00 08 00 00 .vorbis+BCV.....
00000016: 00 31 4C 20 C5 80 D0 90 55 00 00 10 00 00 60 24 .1L ....U.....`$
00000032: 29 0E 93 66 49 29 A5 94 A1 28 79 98 94 48 49 29 )..fI)...(y..HI)
00000048: A5 94 C5 30 89 98 94 89 C5 18 63 8C 31 C6 18 63 ...0......c.1..c
00000064: 8C 31 C6 18 63 8C 20 34 64 15 00 00 04 00 80 28 .1..c. 4d......(
00000080: 09 8E A3 E6 49 6A CE 39 67 18 27 8E 72 A0 39 69 ....Ij.9g.'.r.9i
00000096: 4E 38 A7 20 07 8A 51 E0 39 09 C2 F5 26 63 6E A6 N8. ..Q.9...&cn.
00000112: B4 A6 6B 6E CE 29 25 08 0D 59 05 00 00 02 00 40 ..kn.)%..Y.....@
00000128: 48 21 85 14 52 48 21 85 14 62 88 21 86 18 62 88 H!..RH!..b.!..b.
00000144: 21 87 1C 72 C8 21 A7 9C 72 0A 2A A8 A0 82 0A 32 !..r.!..r.*....2
00000160: C8 20 83 4C 32 E9 A4 93 4E 3A E9 A8 A3 8E 3A EA . .L2...N:....:.
00000176: 28 B4 D0 42 0B 2D B4 D2 4A 4C 31 D5 56 63 AE BD (..B.-..JL1.Vc..
00000192: 06 5D 7C 73 CE 39 E7 9C 73 CE 39 E7 9C 73 CE 09 .]|s.9..s.9..s..
00000208: 42 43 56 01 00 20 00 00 04 42 06 19 64 10 42 08 BCV.. ...B..d.B.
00000224: 21 85 14 52 88 29 A6 98 72 0A 32 C8 80 D0 90 55 !..R.)..r.2....U
00000240: 00 00 20 00 80 00 00 00 00 47 91 14 49 B1 14 CB .. ......G..I...
00000256: B1 1C CD D1 24 4F F2 2C 51 13 35 D1 33 45 53 54 ....$O.,Q.5.3EST
00000272: 4D 55 55 55 55 75 5D 57 76 65 D7 76 75 D7 76 7D MUUUUu]Wve.vu.v}
00000288: 59 98 85 5B B8 7D 59 B8 85 5B D8 85 5D F7 85 61 Y..[.}Y..[..]..a
00000304: 18 86 61 18 86 61 18 86 61 F8 7D DF F7 7D DF F7 ..a..a..a.}..}..
00000320: 7D 20 34 64 15 00 20 01 00 A0 23 39 96 E3 29 A2 } 4d.. ...#9..).
00000336: 22 1A A2 E2 39 A2 03 84 86 AC 02 00 64 00 00 04 "...9.......d...
00000352: 00 20 09 92 22 29 92 A3 49 A6 66 6A AE 69 9B B6 . ..")..I.fj.i..
00000368: 68 AB B6 6D CB B2 2C CB B2 0C 84 86 AC 02 00 00 h..m..,.........
00000384: 01 00 04 00 00 00 00 00 A0 69 9A A6 69 9A A6 69 .........i..i..i
00000400: 9A A6 69 9A A6 69 9A A6 69 9A A6 69 9A 66 59 96 ..i..i..i..i.fY.
00000416: 65 59 96 65 59 96 65 59 96 65 59 96 65 59 96 65 eY.eY.eY.eY.eY.e
00000432: 59 96 65 59 96 65 59 96 65 59 96 65 59 96 65 59 Y.eY.eY.eY.eY.eY
00000448: 96 65 59 40 68 C8 2A 00 40 02 00 40 C7 71 1C C7 .eY@h.*.@..@.q..
00000464: 71 24 45 52 24 C7 72 2C 07 08 0D 59 05 00 C8 00 q$ER$.r,...Y....
00000480: 00 08 00 40 52 2C C5 72 34 47 73 34 C7 73 3C C7 ...@R,.r4Gs4.s<.
00000496: 73 3C 47 74 44 C9 94 4C CD F4 4C 0F 08 0D 59 05 s<GtD..L..L...Y.
00000512: 00 00 02 00 08 00 00 00 00 00 40 31 1C C5 71 1C ..........@1..q.
00000528: C9 D1 24 4F 52 2D D3 72 35 57 73 3D D7 73 4D D7 ..$OR-.r5Ws=.sM.
00000544: 75 5D 57 55 55 55 55 55 55 55 55 55 55 55 55 55 u]WUUUUUUUUUUUUU
00000560: 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 UUUUUUUUUUUUUUUU
00000576: 55 55 55 55 55 81 D0 90 55 00 00 04 00 00 21 9D UUUUU...U.....!.
00000592: 66 96 6A 80 08 33 90 61 20 34 64 15 00 80 00 00 f.j..3.a 4d.....
00000608: 00 18 A1 08 43 0C 08 0D 59 05 00 00 04 00 00 88 ....C...Y.......
00000624: A1 E4 20 9A D0 9A F3 CD 39 0E 9A E5 A0 A9 14 9B .. .....9.......
00000640: D3 C1 89 54 9B 27 B9 A9 98 9B 73 CE 39 E7 9C 6C ...T.'....s.9..l
00000656: CE 19 E3 9C 73 CE 29 CA 99 C5 A0 99 D0 9A 73 CE ....s.).......s.
00000672: 49 0C 9A A5 A0 99 D0 9A 73 CE 79 12 9B 07 AD A9 I.......s.y.....
00000688: D2 9A 73 CE 19 E7 9C 0E C6 19 61 9C 73 CE 69 D2 ..s.......a.s.i.
00000704: 9A 07 A9 D9 58 9B 73 CE 59 D0 9A E6 A8 B9 14 9B ....X.s.Y.......
00000720: 73 CE 89 94 9B 27 B5 B9 54 9B 73 CE 39 E7 9C 73 s....'..T.s.9..s
00000736: CE 39 E7 9C 73 CE A9 5E 9C CE C1 39 E1 9C 73 CE .9..s..^...9..s.
00000752: 89 DA 9B 6B B9 09 5D 9C 73 CE F9 64 9C EE CD 09 ...k..].s..d....
00000768: E1 9C 73 CE 39 E7 9C 73 CE 39 E7 9C 73 CE 09 42 ..s.9..s.9..s..B
00000784: 43 56 01 00 40 00 00 04 61 D8 18 C6 9D 82 20 7D CV..@...a..... }
00000800: 8E 06 62 14 21 A6 21 93 1E 74 8F 0E 93 A0 31 C8 ..b.!.!..t....1.
00000816: 29 A4 1E 8D 8E 46 4A A9 83 50 52 19 27 A5 74 82 )....FJ..PR.'.t.
00000832: D0 90 55 00 00 20 00 00 84 10 52 48 21 85 14 52 ..U.. ....RH!..R
00000848: 48 21 85 14 52 48 21 86 18 62 88 21 A7 9C 72 0A H!..RH!..b.!..r.
00000864: 2A A8 A4 92 8A 2A CA 28 B3 CC 32 CB 2C B3 CC 32 *....*.(..2.,..2
00000880: CB AC C3 CE 3A EB B0 C3 10 43 0C 31 B4 D2 4A 2C ....:....C.1..J,
00000896: 35 D5 56 63 8D B5 E6 9E 73 AE 39 48 6B A5 B5 D6 5.Vc....s.9Hk...
00000912: 5A 2B A5 94 52 4A 29 A5 20 34 64 15 00 00 02 00 Z+..RJ). 4d.....
00000928: 40 20 64 90 41 06 19 85 14 52 48 21 86 98 72 CA @ d.A....RH!..r.
00000944: 29 A7 A0 82 0A 08 0D 59 05 00 00 02 00 08 00 00 )......Y........
00000960: 00 F0 24 CF 11 1D D1 11 1D D1 11 1D D1 11 1D D1 ..$.............
00000976: 11 1D CF F1 1C 51 12 25 51 12 25 D1 32 2D 53 33 .....Q.%Q.%.2-S3
00000992: 3D 55 54 55 57 76 6D 59 97 75 DB B7 85 5D D8 75 =UTUWvmY.u...].u
00001008: DF D7 7D DF D7 8D 5F 17 86 65 59 96 65 59 96 65 ..}..._..eY.eY.e
00001024: 59 96 65 59 96 65 59 96 65 09 42 43 56 01 00 20 Y.eY.eY.e.BCV..
00001040: 00 00 00 42 08 21 84 14 52 48 21 85 94 62 8C 31 ...B.!..RH!..b.1
00001056: C7 9C 83 4E 42 09 81 D0 90 55 00 00 20 00 80 00 ...NB....U.. ...
00001072: 00 00 00 47 71 14 C7 91 1C C9 91 24 4B B2 24 4D ...Gq......$K.$M
00001088: D2 2C CD F2 34 4F F3 34 D1 13 45 51 34 4D 53 15 .,..4O.4..EQ4MS.
00001104: 5D D1 15 75 D3 16 65 53 36 5D D3 35 65 D3 55 65 ]..u..eS6].5e.Ue
00001120: D5 76 65 D9 B6 65 5B B7 7D 59 B6 7D DF F7 7D DF .ve..e[.}Y.}..}.
00001136: F7 7D DF F7 7D DF F7 7D DF D7 75 20 34 64 15 00 .}..}..}..u 4d..
00001152: 20 01 00 A0 23 39 92 22 29 92 22 39 8E E3 48 92 ...#9.")."9..H.
00001168: 04 84 86 AC 02 00 64 00 00 04 00 A0 28 8E E2 38 ......d.....(..8
00001184: 8E 23 49 92 24 59 92 26 79 96 67 89 9A A9 99 9E .#I.$Y.&y.g.....
00001200: E9 A9 A2 0A 84 86 AC 02 00 00 01 00 04 00 00 00 ................
00001216: 00 00 A0 68 8A A7 98 8A A7 88 8A E7 88 8E 28 89 ...h..........(.
00001232: 96 69 89 9A AA B9 A2 6C CA AE EB BA AE EB BA AE .i.....l........
00001248: EB BA AE EB BA AE EB BA AE EB BA AE EB BA AE EB ................
00001264: BA AE EB BA AE EB BA AE EB BA AE EB BA 40 68 C8 .............@h.
00001280: 2A 00 40 02 00 40 47 72 24 47 72 24 45 52 24 45 *.@..@Gr$Gr$ER$E
00001296: 72 24 07 08 0D 59 05 00 C8 00 00 08 00 C0 31 1C r$...Y........1.
00001312: 43 52 24 C7 B2 2C 4D F3 34 4F F3 34 D1 13 3D D1 CR$..,M.4O.4..=.
00001328: 33 3D 55 74 45 17 08 0D 59 05 00 00 02 00 08 00 3=UtE...Y.......
00001344: 00 00 00 00 C0 90 0C 4B B1 1C CD D1 24 51 52 2D .......K....$QR-
00001360: D5 52 35 D5 52 2D 55 54 3D 55 55 55 55 55 55 55 .R5.R-UT=UUUUUUU
00001376: 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 UUUUUUUUUUUUUUUU
00001392: 55 55 55 55 55 55 55 55 55 55 D5 34 4D D3 34 81 UUUUUUUUUU.4M.4.
00001408: D0 90 95 00 00 19 00 00 84 C5 07 A1 8C 52 12 93 .............R..
00001424: D4 5A EC C1 58 8A 31 08 A5 06 E5 31 85 14 83 96 .Z..X.1....1....
00001440: 84 C7 98 42 CA 51 4E A2 63 0A 21 E5 30 A7 D2 39 ...B.QN.c.!.0..9
00001456: 86 8C 91 DA 62 0A 99 32 42 59 F1 3D 76 8C 21 87 ....b..2BY.=v.!.
00001472: 3D 18 9D 42 E8 24 06 42 43 56 04 00 51 00 00 06 =..B.$.BCV..Q...
00001488: 49 22 49 24 C9 F2 3C A2 47 F4 2C CF E3 89 3C 11 I"I$..<.G.,...<.
00001504: 80 E4 79 34 8D E7 49 9E 47 F3 78 1E 00 49 F4 78 ..y4..I.G.x..I.x
00001520: 1E 4D 93 3C 91 E7 D1 34 01 00 00 01 0E 00 00 01 .M.<...4........
00001536: 16 42 A1 21 2B 02 80 38 01 00 8B 24 79 1E 49 F2 .B.!+..8...$y.I.
00001552: 3C 92 E4 79 34 4D 14 21 8A 96 A6 89 1E CF 13 45 <..y4M.!.......E
00001568: 9E 26 8A 44 D3 34 A1 9A 96 A6 79 22 CF 13 45 9A .&.D.4....y"..E.
00001584: 27 8A 4C 51 35 61 9A 9E E8 99 26 D3 74 55 A6 A9 '.LQ5a....&.tU..
00001600: AA 5C 59 96 21 BB 9E 27 9A 26 D3 54 5D A6 A9 AA .\Y.!..'.&.T]...
00001616: 64 57 96 21 CB 00 00 00 2C 4F 33 4D 9A 66 8A 34 dW.!....,O3M.f.4
00001632: CD 34 89 A2 69 C2 34 2D CD 33 4D 9A 26 9A 34 CD .4..i.4-.3M.&.4.
00001648: 34 89 A2 69 C2 34 3D 51 54 55 A6 A9 AA 4C 53 55 4..i.4=QTU...LSU
00001664: B9 AE EB C2 75 3D D1 54 55 A2 A9 AA 4C 53 55 B9 ....u=.TU...LSU.
00001680: AE EB C2 75 01 00 00 48 9E 66 9A 34 CD 34 69 9A ...u...H.f.4.4i.
00001696: 29 12 45 D3 84 69 5A 9A 67 9A 34 CD 34 69 9A 68 ).E..iZ.g.4.4i.h
00001712: 12 45 D3 84 69 7A A6 E8 AA 4C D3 55 99 A2 AA 52 .E..iz...L.U...R
00001728: 5D D7 85 EB 7A A2 A9 BA 4C 53 55 89 A6 AA 72 55 ]...z...LSU...rU
00001744: D7 85 EB 02 00 00 D0 4C D1 75 89 A2 AB 12 45 55 .......L.u....EU
00001760: 65 9A AE 0A D5 D5 44 D3 75 89 A2 EA 12 45 55 65 e.....D.u....EUe
00001776: 9A AA 0B 55 15 55 53 76 99 A6 EB 32 4D D7 A5 AA ...U.USv...2M...
00001792: AE 0B D9 15 4D D5 95 99 A6 EB 32 4D D7 A5 BA AE ....M.....2M....
00001808: 0B 57 06 00 00 00 00 00 00 00 00 80 A8 9A B2 CC .W..............
00001824: 34 5D 97 69 BA 2E D5 75 5D B8 AE 68 AA B2 CC 34 4].i...u]..h...4
00001840: 5D 97 69 BA 2E 57 95 5D B8 AE 00 00 80 01 07 00 ].i..W.]........
00001856: 80 00 13 CA 40 A1 21 2B 01 80 28 00 00 8B E3 48 ....@.!+..(....H
00001872: 92 65 79 1E C7 91 24 4B F3 3C 8E 23 49 9A E6 79 .ey...$K.<.#I..y
00001888: 24 C9 B2 34 4D 14 61 59 9A 26 8A D0 34 CF 13 45 $..4M.aY.&..4..E
00001904: 68 9A E7 89 22 00 00 02 00 00 0A 1C 00 00 02 6C h..."..........l
00001920: D0 94 58 1C A0 D0 90 95 00 40 48 00 80 C5 71 24 ..X......@H...q$
00001936: C9 B2 34 CD F3 44 D1 34 4D 93 E4 48 92 A6 79 9E ..4..D.4M..H..y.
00001952: E7 89 A2 69 AA 2A 49 B2 2C 4D F3 3C CF 13 45 D3 ...i.*I.,M.<..E.
00001968: 54 55 96 64 59 9A E6 79 A2 68 9A AA AA BA B0 2C TU.dY..y.h.....,
00001984: 4D F3 3C 51 34 4D 55 75 5D 68 9A A6 89 A2 28 9A M.<Q4MUu]h....(.
00002000: A6 AA BA 2E 34 4D F3 44 51 14 4D 53 55 5D 17 9A ....4M.DQ.MSU]..
00002016: E6 79 A2 68 9A AA EA BA B2 0C 3C 4F 14 4D 53 55 .y.h......<O.MSU
00002032: 5D D7 75 01 00 00 00 00 00 00 00 00 00 00 00 00 ].u.............
00002048: 00 00 00 00 04 00 00 1C 38 00 00 04 18 41 27 19 ........8....A'.
00002064: 55 16 61 A3 09 17 1E 80 42 43 56 04 00 51 00 00 U.a.....BCV..Q..
00002080: 80 31 88 31 C5 98 61 0A 4A 29 25 34 8A 41 29 25 .1.1..a.J)%4.A)%
00002096: 94 08 42 48 A9 A4 94 49 48 2D B5 D6 32 28 29 B5 ..BH...IH-..2().
00002112: D6 5A 25 A5 B4 56 5A CA A4 A4 D6 52 6B 99 94 D4 .Z%..VZ....Rk...
00002128: 5A 6B AD 00 00 B0 03 07 00 B0 03 0B A1 D0 90 95 Zk..............
00002144: 00 40 1E 00 00 83 90 52 8C 31 C6 18 45 48 29 C6 .@.....R.1..EH).
00002160: 18 73 8E 22 A4 14 63 8C 39 47 11 52 8A 31 E7 9C .s."..c.9G.R.1..
00002176: A3 94 2A C5 18 73 CE 51 4A 95 62 8C 39 E7 28 A5 ..*..s.QJ.b.9.(.
00002192: 4A 31 C6 98 73 94 52 C6 18 63 CC 39 4A A9 94 8C J1..s.R..c.9J...
00002208: 31 E6 1C A5 94 52 C6 18 63 8C 52 4A 29 63 8C 31 1....R..c.RJ)c.1
00002224: 26 00 00 A8 C0 01 00 20 C0 46 91 CD 09 46 82 0A &...... .F...F..
00002240: 0D 59 09 00 A4 02 00 38 1C C7 B2 34 4D D3 3C 4F .Y.....8...4M.<O
00002256: 14 25 C7 B1 2C CF 13 45 51 34 4D CB 71 2C CB F3 .%..,..EQ4M.q,..
00002272: 44 51 14 4D 93 65 69 9A E7 89 A2 69 AA 2A CB D2 DQ.M.ei....i.*..
00002288: 34 CF 13 45 D3 54 55 A6 E9 79 A2 68 9A AA EA BA 4..E.TU..y.h....
00002304: 54 D5 F3 44 D1 34 55 D5 75 01 00 00 00 00 00 00 T..D.4U.u.......
00002320: 00 00 00 01 00 E0 09 0E 00 40 05 36 AC 8E 70 52 .........@.6..pR
00002336: 34 16 58 68 C8 4A 00 20 03 00 80 31 06 21 64 0C 4.Xh.J. ...1.!d.
00002352: 42 C8 18 84 10 42 08 21 84 10 12 00 00 30 E0 00 B....B.!.....0..
00002368: 00 10 60 42 19 28 34 64 25 00 90 0A 00 40 18 A3 ..`B.(4d%....@..
00002384: 14 63 CE 49 49 A9 32 46 29 E7 20 94 D2 5A 65 90 .c.II.2F). ..Ze.
00002400: 52 CE 41 28 A5 B5 66 29 A5 9C 83 92 52 6B CD 52 R.A(..f)....Rk.R
00002416: 4A 39 27 25 A5 D6 9A 29 19 83 50 4A 4A AD 35 95 J9'%...)..PJJ.5.
00002432: 32 06 A1 94 94 5A 6B CE 89 10 42 4A AD C5 D8 9C 2....Zk...BJ....
00002448: 13 21 84 94 5A 8B B1 39 27 63 29 29 B5 18 63 73 .!..Z..9'c))..cs
00002464: 4E C6 52 52 6A 31 C6 E6 9C 53 AE B5 16 63 CD 49 N.RRj1...S...c.I
00002480: 29 A5 5C 6B 2D C6 5A 0B 00 40 68 70 00 00 3B B0 ).\k-.Z..@hp..;.
00002496: 61 75 84 93 A2 B1 C0 42 43 56 02 00 79 00 00 90 au.....BCV..y...
00002512: 52 4A 31 C6 18 63 4C 29 A5 18 63 8C 31 A6 94 52 RJ1..cL)..c.1..R
00002528: 8C 31 C6 98 53 4A 29 C6 18 63 CC 39 A7 14 63 8C .1..SJ)..c.9..c.
00002544: 31 E6 9C 63 8C 31 C6 18 73 CE 31 C6 18 63 8C 39 1..c.1..s.1..c.9
00002560: E7 18 63 8C 31 C6 9C 73 CE 31 C6 18 63 CE 39 E7 ..c.1..s.1..c.9.
00002576: 18 63 8C 31 E7 9C 73 8C 31 C6 98 00 00 A0 02 07 .c.1..s.1.......
00002592: 00 80 00 1B 45 36 27 18 09 2A 34 64 25 00 10 0E ....E6'..*4d%...
00002608: 00 00 18 C3 94 73 CE 41 28 25 95 0A 21 C6 20 74 .....s.A(%..!. t
00002624: 50 4A 4A AD 55 08 31 06 21 84 52 52 6A 2D 6A CE PJJ.U.1.!.RRj-j.
00002640: 39 08 21 94 92 52 6B D1 73 CE 41 08 A1 94 94 5A 9.!..Rk.s.A....Z
00002656: 8B AA 85 50 4A 29 25 A5 D6 5A 74 2D 74 52 4A 49 ...PJ)%..Zt-tRJI
00002672: A9 B5 18 A3 94 22 84 90 52 4A AD B5 18 9D 13 21 ....."..RJ.....!
00002688: 84 92 52 6A 2D C6 E6 9C 8C A5 A4 D4 5A 8C 31 36 ..Rj-.......Z.16
00002704: E7 64 2C 25 A5 D6 62 8C B1 39 E7 9C 6B AD B5 16 .d,%..b..9..k...
00002720: 63 AD CD 39 E7 5C 6B 29 B6 18 6B 6D CE 39 A7 7B c..9.\k)..km.9.{
00002736: 6C 31 D6 58 6B 73 CE 39 9F 5B 8B AD C6 5A 0B 00 l1.Xks.9.[...Z..
00002752: 30 79 70 00 80 4A B0 71 86 95 A4 B3 C2 D1 E0 42 0yp..J.q.......B
00002768: 43 56 02 00 B9 01 00 8C 52 8C 31 E6 9C 73 CE 39 CV......R.1..s.9
00002784: E7 9C 73 CE 49 A5 18 73 CE 39 08 21 84 10 42 08 ..s.I..s.9.!..B.
00002800: 21 94 4A 31 E6 9C 73 10 42 08 21 84 10 42 28 19 !.J1..s.B.!..B(.
00002816: 73 CE 39 07 21 84 10 42 08 21 84 50 4A E9 9C 73 s.9.!..B.!.PJ..s
00002832: 10 42 08 21 84 10 42 08 A1 94 D2 39 E7 20 84 10 .B.!..B....9. ..
00002848: 42 08 21 84 10 42 29 A5 73 CE 41 08 21 84 10 42 B.!..B).s.A.!..B
00002864: 08 21 84 52 4A 08 21 84 10 42 08 21 84 10 42 08 .!.RJ.!..B.!..B.
00002880: A5 94 52 42 08 21 84 10 42 08 21 84 10 4A 29 A5 ..RB.!..B.!..J).
00002896: 84 10 42 08 21 84 10 42 08 21 94 52 4A 09 21 84 ..B.!..B.!.RJ.!.
00002912: 10 42 08 21 84 10 42 28 A5 94 12 42 08 21 84 10 .B.!..B(...B.!..
00002928: 42 08 25 84 50 4A 29 A5 94 10 42 08 A1 84 10 42 B.%.PJ)...B....B
00002944: 08 A1 94 52 4A 29 21 84 52 4A 29 21 84 10 42 29 ...RJ)!.RJ)!..B)
00002960: A5 94 52 42 28 A1 84 10 42 08 21 94 52 4A 29 A5 ..RB(...B.!.RJ).
00002976: 94 12 42 29 21 84 10 42 08 A5 94 52 4A 29 A5 94 ..B)!..B...RJ)..
00002992: 52 42 08 21 84 10 4A 29 A5 94 52 4A 29 A5 84 50 RB.!..J)..RJ)..P
00003008: 42 08 21 94 52 4A 29 A5 94 52 42 28 25 84 12 42 B.!.RJ)..RB(%..B
00003024: 28 A5 94 52 4A 29 A5 84 50 42 08 21 84 50 4A 29 (..RJ)..PB.!.PJ)
00003040: A5 94 52 4A 09 21 84 12 42 08 A1 00 00 A0 03 07 ..RJ.!..B.......
00003056: 00 80 00 23 2A 2D C4 4E 33 AE 3C 02 47 14 32 4C ...#*-.N3.<.G.2L
00003072: 40 85 86 AC 04 00 D2 02 00 00 43 AC B5 D6 5A 6B @.........C...Zk
00003088: AD B5 D6 5A 6B 0D 52 D6 5A 6B AD B5 D6 5A 6B AD ...Zk.R.Zk...Zk.
00003104: B5 46 29 6B AD B5 D6 5A 6B AD B5 D6 5A 6B A9 B5 .F)k...Zk...Zk..
00003120: D6 5A 6B AD B5 D6 5A 6B AD B5 D6 5A 6B AD B5 D6 .Zk...Zk...Zk...
00003136: 5A 6B AD B5 D6 5A 6B AD B5 D6 5A 6B AD B5 D6 5A Zk...Zk...Zk...Z
00003152: 6B AD B5 D6 5A 6B AD B5 D6 5A 6B AD B5 D6 5A 6B k...Zk...Zk...Zk
00003168: AD B5 D6 5A 6B AD B5 D6 5A 6B AD B5 D6 5A 6B AD ...Zk...Zk...Zk.
00003184: B5 D6 5A 6B AD B5 D6 5A 6B AD B5 D6 5A 6B AD B5 ..Zk...Zk...Zk..
00003200: D6 5A 6B AD B5 D6 5A 6B AD B5 D6 5A 6B AD B5 D6 .Zk...Zk...Zk...
00003216: 5A 6B AD B5 D6 5A 6B AD B5 D6 5A 6B AD B5 D6 5A Zk...Zk...Zk...Z
00003232: 6B AD B5 D6 5A 6B AD B5 D6 5A 6B AD B5 D6 5A 4B k...Zk...Zk...ZK
00003248: 29 A5 94 52 4A 29 A5 94 52 4A 29 A5 94 52 4A 29 )..RJ)..RJ)..RJ)
00003264: A5 94 52 4A 29 A5 94 52 4A 29 A5 94 52 4A 29 A5 ..RJ)..RJ)..RJ).
00003280: 94 52 4A 29 A5 94 52 4A 29 A5 94 52 4A 29 A5 94 .RJ)..RJ)..RJ)..
00003296: 52 4A 29 A5 94 52 4A 29 A5 94 52 01 D8 05 1B 0E RJ)..RJ)..R.....
00003312: 80 D1 13 ...
OOOGGValidate.exe:
ERROR 516: Lost Sync
well, i posted a ticket in MusicBrainz Picard bugtracker, so the bug is going to be checked in the program, but now i'm interested in recovering my files
i can't re-rip the songs, the original CD was given to a friend as a souvenir when he left the country, i searched the HA forums back to 2004 and found nothing about repairing Vorbis files, at least, nothing that matches my case...
i've uploaded one track for the developers of Picard to examine, you can get it here:
http://www.megaupload.com/?d=NWUSS7QD (http://www.megaupload.com/?d=NWUSS7QD)
i hope someone could tell if it's possible to recover the data, if it's only a corrupt header, then there might be a chance to edit it manually, but if it's corruption in the stream itself, then i wonder if there's any kind of protection in OGG at all!!? i used to think it does CRC32 checksums... or am not right?
any help, info, anything... is really appreciated, as now i'm making a copy of every folder before tagging...
thanx in advance
H.Q.
As for this file, a header page is damaged or CRC check sum is not right.
The revision of the error is possible technically. However, I do not know software for the purpose.
well, thanx Aoyumi
so does that mean that a header could be rewritten manually (i'll try to do it later tomorrow anyway), or can i reset the CRC (pretty imaginary, i guess )... i tried to search for tools, nothing satisfactory till the moment...
i think i'll have to experiment with a hex editor, i have
ConTEXT but it's pretty buggy, any clues for some good Hex editor?
PS: if you don't feel that this thread belong to the Tech subforum, please someone move it ... i understood "Tech" as technical problems or so, as i haven't any similar clue to such problems in either General or Tech Vorbis subs... thanx anyway
well, thanx Aoyumi
i think i'll have to experiment with a hex editor, i have ConTEXT but it's pretty buggy, any clues for some good Hex editor?
For one safe method, it is to overwrite the header page that is not normal in a normal header page.
A procedure
(1) You use "Lancer SSE3 20061110" and encode the suitable sound file of the 44.1kHz/2ch stereo in Quality9 (without padding).
(2) You change the serial number of the file which you encoded to a serial number same as a damaged file (I use vserial).?
(3) You copy normal header pages on the header pages that failed. (I use hex editor Stirling. but it is not english menu).
Hi,can you tell me where to find OOOggdump.exe
it comes as a part of the illiminable oggcodecs direct show filters... i have oggcodecs v.0.73.1936 which is a beta as i recall, you can download it from HERE:
http://www.illiminable.com/ogg/ (http://www.illiminable.com/ogg/)
A procedure
well, i was overly busy for the past month, i couldn't even thank you for the reply
i didn't try those steps yet, and i have a few questions:
(1) what do you mean by "suitable" sound file? you mean the SAME ORIGINAL sound file from which i've made the rips? or simply any 44.1KHz/2ch wav that has the same track length in seconds, or even in samples? or is it just ANY PCM 44KHz stereo?
(2) question 2 cancelled ... i found vserial along with a bunch of more ogg tools
i'll keep you informed on whatever i come up with
thanx
Aoyumi
The condition is ...
1. The same sampling frequency
2. The same channels
3. The same encoder
4. The same quality setting
(5. The same ogg serial number & page number)
If these are common, the headers are common.
