Ok, I think it might be something with the Lyrics plugin. It's only happening when I play Bob Dylan's "Ballad of a Thin Man", even across different pressings, so it's not the file itself. I also tried with the latest dev build from git, same thing happens.
I can't post the full crash log from Wine, there's a 20000 character limit here, so here's the bits I think are relevant:
Illegal operation:
Code: E06D7363h, flags: 00000001h, address: 7B642447h
Additional parameters: 19930520h 022BFD34h 006E73E4h
Message: bad allocation
Last win32 error: 8
Call path not available.
Code bytes (7B642447h):
7B642407h: EC 54 8B 4D 08 8B 45 10 C7 45 B4 00 00 00 00 C7
7B642417h: 45 B8 00 24 64 7B 8B 55 14 89 4D AC 8B 4D 0C 83
7B642427h: E1 01 89 4D B0 85 C0 74 04 85 D2 75 24 C7 45 BC
7B642437h: 00 00 00 00 8D 45 AC 89 04 24 FF 15 88 AB 6F 7B
7B642447h: 8B 5D FC 83 EC 04 C9 C2 10 00 8D B4 26 00 00 00
7B642457h: 00 83 F8 0F B9 0F 00 00 00 0F 47 C1 89 45 BC C1
7B642467h: E0 02 8B 4C 02 FC 89 4C 05 BC 83 E8 01 83 F8 04
7B642477h: 72 C2 83 E0 FC 31 C9 8B 1C 0A 89 5C 0D C0 83 C1
Stack (022BFC9Ch):
022BFC7Ch: 00000002 00000000 00000000 77671690
022BFC8Ch: 022BF9B0 022BFCF0 7B642447 022BFC9C
022BFC9Ch: E06D7363 00000001 00000000 7B642447
022BFCACh: 00000003 19930520 022BFD34 006E73E4
022BFCBCh: 022BFD04 00000000 00000000 00000002
022BFCCCh: 00000008 022BFCE4 7B6AE79B 00000002
022BFCDCh: 022BFCE0 00000000 022BFD2C 779CABDA
022BFCECh: 19930520 022BFD24 77747E86 E06D7363
022BFCFCh: 00000001 00000003 022BFD18 00D345B0
022BFD0Ch: 00D345B0 00000000 022BFD34 19930520
022BFD1Ch: 022BFD34 006E73E4 022BFD40 00647006
022BFD2Ch: 022BFD34 006E73E4 00678BE4 00684C8C
022BFD3Ch: 00000000 022BFD44 022BFEE4 00465FE0
022BFD4Ch: 00002823 00000000 00D345B0 00000000
022BFD5Ch: 022BFEB4 0046144F 022BFED0 00D345B0
022BFD6Ch: 00704D14 00D345B0 00C2AFA8 00000000
022BFD7Ch: 00D538B8 00000000 00C25960 00000000
022BFD8Ch: 00C25920 02B99F78 00000040 022BFDD0
022BFD9Ch: 00D54588 00000000 022BFE6C 00D54D60
022BFDACh: 022BFDBC 00000000 00D54D48 00000000
Registers:
EAX: 022BFC9C, EBX: 022BFD34, ECX: 00000008, EDX: 022BFD18
ESI: 022BFEB4, EDI: 006E73E4, EBP: 022BFCF0, ESP: 022BFC9C
Timestamp:
168445ms
Crash location:
Module: kernelbase
Offset: 12447h
Symbol: "RaiseException" (+42h)
[9111ms] You are on the most current version of Georgia-ReBORN
[14850ms] Biography Server: wikipedia: : not found
[20841ms] Error walking directory (Invalid path syntax): file://Z:\home\anon\hdd-wd-blue-rz\Music\Bob Dylan\1965 - Highway 61 Revisited\1994 - DCC Compact Classics GZS-1021 United States\05 Ballad of a Thin Man.flac
[20841ms] setConfigBlob(cfg_var.7D53C550-CDA5-4C83-A030-1024B40417BC,436 bytes)
[20842ms] setConfigBlob(cfg_var.7D53C550-CDA5-4C83-A030-1024B40417BC,452 bytes)
[20850ms] on_metadb_changed(): 1 handles, fromhook: false
[20850ms] Playlist added
[20866ms] Playlist initialized in 1ms
[41596ms] Opening track for playback: "Z:\home\anon\hdd-wd-blue-rz\Music\Bob Dylan\1965 - Highway 61 Revisited\1994 - DCC Compact Classics GZS-1021 United States\05 Ballad of a Thin Man.flac"
[41601ms] setConfigFloat(core.totalTimePlayed,0.0000000)
[41602ms] Automatic resampling: using Resampler (dBpoweramp/SSRC): 96000 Hz, Resampler (RetroArch): 96000 Hz
[41617ms] Device: PulseAudio Output
Mix format: 96000 Hz / 32-bit float / 4 channels (0x33)
[41653ms] Sending stream: 96000 Hz / 32-bit float / 4 channels (0x33)
[41960ms] Found band logo: Z:\home\anon\Music\Audio players\Georgia-ReBORN_2024-01-21\profile\georgia-reborn\images\artistlogos\Bob Dylan.png
[42030ms] Found Record label: Z:\home\anon\Music\Audio players\Georgia-ReBORN_2024-01-21\profile\georgia-reborn\images\recordlabel\DCC Compact Classics.png
[42037ms] on_metadb_changed(): 0 handles, fromhook: undefined
[42335ms] [eslyric][musixmatch]parse exception: cannot read property 'Symbol.iterator' of undefined
[53870ms] [eslyric]parse xml failed: <?xml version="1.0" encoding="utf-8"?>
<QrcInfos>
<QrcHeadInfo SaveTime="1394677013" Version="100"/>
<LyricInfo LyricCount="1">
<Lyric_1 LyricType="1" LyricContent="[ti:Ballad of a Thin Man (Remastered)]
[ar:Bob Dylan]
[al:The Complete Album Collection - The 70's]
[by:]
[offset:0]
[0,13260]Ballad(0,631) (631,631)Of(1262,631) (1893,631)A(2524,631) (3155,631)Thin(3786,631) (4417,631)Man(5048,631) (5679,631)((6310,631)2008(6941,631) (7572,631)Remaster(8203,631))(8834,631) (9465,631)-(10096,631) (10727,631)Bob(11358,631) (11989,631)Dylan(12620,631)
[13264,1170]You (13264,160)walk (13424,150)into (13574,170)the (13744,170)room(13914,520)
[15714,1580]With (15714,160)your (15874,150)pencil (16024,240)in (16264,190)your (16454,200)hand(16654,640)
Here's right where it crashes, but sometimes it makes it a little farther, sometimes less:
[347062,5562]Do (347062,375)you (347437,1312)Mister (348749,750)Jones (349499,3125)
[352624,7435]Well (352624,1376)you (354000,435)walk (354435,376)into (354811,314)the (355125,372)room(355497,4562)
[360059,7628]Like (360059,441)a (360500,435)camel (360935,934)and (361869,1506)then (363375,562)you (363937,1500)frown(365437,2250)
[367687,4000]You (367687,372)put (368059,314)your (368373,314)eyes (368687,313)in (369000,311)your (369311,251)pocket(369562,2125)
[371687,4000]And (371687,500)your (372187,376)nose (372563,374)on (372937,310)the (373247,252)ground(373499,2188)
[375687,3247]There (375687,563)ought (376250,371)to (376621,566)be (377187,250)a (377437,250)law(377687,1247)
[378934,2810]Against (378934,310)you (379244,442)comin' (379686,436)around(380122,1622)
[381744,2630]You (381744,378)should (382122,566)be (382688,562)made(383250,1124)
[384374,2812]To (384374,376)wear (384750,437)earphones(385187,1999)
[387186,7746]Because (387186,376)something (387562,748)is (388310,812)happening (389122,686)here(389808,5124)
[394932,4002]But (394932,568)you (395500,310)don't (395810,252)know (396062,312)what (396374,246)it (396620,442)is(397062,1872)
[398934,1816]Do (398934,500)you (399434,498)Mister (399932,378)Jones (400310,440)
[400750,3125](400750,188)(400938,182)(401120,190)(401310,188)(401498,188)(401686,189)(401875,247)(402122,188)(402310,190)(402500,313)(402813,373)(403186,689)
</LyricInfo>
</QrcInfos>
[67875ms] setConfigInt(metadb.last-gc,133503628576307597)
[102794ms] on_metadb_changed(): 1 handles, fromhook: true
[165625ms] Unrecoverable playback error: bad allocation
[165786ms] deleteConfigInt(core.playbackStatistics.playing)
[165786ms] deleteConfigInt(core.playbackStatistics.bumped)
[165786ms] deleteConfigInt(core.playbackStatistics.position)
[165786ms] setConfigFloat(core.totalTimePlayed,123.8695041)
[165786ms] setConfigBlob(config_object.B572C86F-4206-40A0-8476-C7B27E74DB2D,1 bytes)
[170385ms] [eslyric]script search service: eval script failed, null
Machine specifications:
OS: wine-9.0, on: Linux / 6.5.0-14-lowlatency
CPU: AMD Ryzen 3 5300G with Radeon Graphics, features: MMX SSE SSE2 SSE3 SSE4.1 SSE4.2 AVX LZCNT
CPU threads: 8
Audio: Navi 10 HDMI Audio Digital Stereo (HDMI); UMC404HD 192k Analog Surround 4.0; PulseAudio Output
