Topic: Alpha9: new extreme vs. standard (Read 2940 times) previous topic - next topic
Dibrom,
I was just curious as to how good you think the new extreme is compared to the new standard in the latest ICL compile.
Obviously you have tested and tweaked standard much more time-wise than extreme...perhaps porting over the tricks learned from tweaking standard will not always translate perfectly to extreme, and then again perhaps not.
So for example,
(1) are there any files where extreme does not sound as good as standard?
(2) are there any files where the new extreme adds artifacts that standard does not? (I remember you mentioned in the old days :-) the lower ath of extreme combined with other factors sometimes caused high frequency artifacts that standard did not have.
(3) In short, is extreme very safe to use now or do you still consider extreme and insane to be "EXPERIMENTAL"?
Thanks and have a great holiday...
It should be safe to use the extreme mode.  In the alt-presets I have spent much more time tuning extreme and insane than I ever did with the --dm-presets, and also I think due to the way the newer modes are designed there is much less of a chance for there to be some sort of "fluke" where quality could decrease in going from a lower to higher preset.  So far I don't know of any cases where extreme or insane are worse than standard.  I no longer consider (and actually haven't for awhile now) them "experimental".
Np, and you too
