Topic: FLAC 1.3.2 pre1 release (Read 14519 times) previous topic - next topic
Re: FLAC 1.3.2 pre1 release
I'm planning on transcoding my entire Wavpack collection to flac so I can enjoy music on my android device.
That seems like a lot of trouble. Aren't there any Android players you like that support WavPack? I know Foobar2000 does.
GoneMad is quite the competent player on android and supports playback of WavPack.
Are there any settings that makes FLAC get near the compression ratio of WavPack?
Not really: FLAC is optimized for decoding speed, not for the absolute max compression. I use WavPack on a few files, but I do not use the extra high setting. You cannot have it both.
(That said, TAK impresses me - it is the only thing that can compete both with FLAC on speed and with WavPack on compression.)
Using -ep in FLAC is just not worth it, too slow for almost the same compression.
IIRC, that is even more true with 1.3, where the -8 setting got more clever.
Well, I need a player that can connect to the files on my server (Windows SMB).
I am a foobar addict, but never knew it was available on android. Will try that tonight. I hope I can get SMB support there or any other method that works with Windows.
A new pre-release is out:
Hi all,
New pre-release here is at:
  http://mega-nerd.com/tmp/flac-1.3.2pre3-win.zip
  http://mega-nerd.com/tmp/flac-1.3.2pre3.tar.xz
Changes:
* Fix tests with Makefile.lite build system.
* Fixes for non-Intel CPUs.
MD5 and SHA256 sums:
md5sum flac-1.3.2pre3*
  61aa8597a220303daf4beb2b8756979d  flac-1.3.2pre3.tar.xz
  8b470ceac02340600db73bc6daea4fc7  flac-1.3.2pre3-win.zip
sha256sum flac-1.3.2pre3*
  9f3e333db6bf9aea8fa211a0d598ec28e2e24c47830ba2f585dc5647b756e4c8  flac-1.3.2pre3.tar.xz
  f0af11afb7f2187317677fd719cad1493d3bd52d0498a4facc8a937ce366ba88  flac-1.3.2pre3-win.zip
Really need someone to test the Windows binaries because I don't have Windows.
Erik
Anyone here using Windows who can put it to the test? This version has a good chance of becoming the Final if everything goes well.
Every night with my star friends / We eat caviar and drink champagne
Sniffing in the VIP area / We talk about Frank Sinatra
Do you know Frank Sinatra? / He's dead
And the title of this message is "1.3.2pre3 (Hopefully final)".
So if you want to test FLAC pre-release then please do it now.
Did some testing on Windows with pre3. I hope this info is useful.
Got no errors, seems 1.3.2pre3 is a tad slower, but shaves of some bytes compared to 1.3.1.
Test setup
System info:
OS: Windows 10 Pro x64
CPU: Intel i7-4700MQ
SSD: 850 Evo
Encoders used:
- v1.3.1 x64 from xiph.org http://downloads.xiph.org/releases/flac/flac-1.3.1-win.zip
- v1.3.2pre3 x64 from this thread
Using Foobar2000
- Command: "-s -V --ignore-chunk-sizes -8 - -o %d"
- Test 1 is with metadata. Test 2 and 3 is without.
- No attached pictures, neither before or after conversion
- I closed all other programs but foobar2000
TEST 1: 1553 flac files (only file size comparison)
v1.3.1: 43 356 518 257 bytes
v1.3.2pre3: 43 337 307 601 bytes
TEST 2: One huge WAV to FLAC, from ssd to ssd, single core performance and output size.
Original: WAV 44.1khz 16bit
Duration: 6:45:47.887
Size: 4 294 967 300 bytes
.WAV -> v1.3.1
Size: 2 851 985 379 bytes
Time: 2:32
.WAV -> v1.3.2pre3
Size: 2 851 850 574 bytes
Time: 2:52
TEST 3: One huge wave64 to FLAC, from ssd to ssd, single core performance and output size
Original: Wave64 44.1khz 16bit
Duration: 2d 9:52:20.193
Size: 36 751 210 120 bytes
.WAVE64 -> v1.3.1
Size: 24 274 277 266 bytes
Time: 24:45
.WAV64 -> v1.3.2pre3
Size: 24 272 811 306 bytes
Time: 25:55
Reply #32
Thanks! I've shared your findings on the dev mailinglist.
Just did some quick testing on an already flac album using the xiph binaries (1.3.2 was just released) on my FX8320. ~137x on 1.3.1 and ~135x on 1.3.2. Only difference was 20kb smaller on 1.3.2. Was using -8.
Reply #34
For me, flac 1.3.1 is a bit faster. Using an Intel i5 4460 @ 3.2 GHz
flac 1.3.2 x64: Total encoding time: 0:04.353, 126.18x realtime, File size : 66.1 MB (69 322 460 bytes)
flac 1.3.1 x64: Total encoding time: 0:02.902, 189.27x realtime, File size : 66.1 MB (69 322 460 bytes)
