Topic: Columns UI appearance (Read 3298226 times) previous topic - next topic
0 Members and 5 Guests are viewing this topic.
Reply #1650
Hey guys, there are some great foobars out there, nice work.
Over the past day I've been having a go at copying iTunes (just for the challenge really) as precisely as I can, and have so far come up with this:
[a href="http://img237.imageshack.us/my.php?image=itunesfoobarim6.jpg" target="_blank"]
The next step would be adding in cover flow (not too tough) and album display (maybe a bit more tricky).
Would be good to hear your comments!
What's the component that this user is using to sort his albums by Genre | Artist | Album? I used to have that but I changed it a long time ago and now I can't remember how to do it.
Reply #1651
I do not use CUI, but that looks like a series of filter panels, a part of columns not a separate component.  You can add them to your layout via preferences>Display>CUI>layout
Reply #1652
Here's my config, based on Gosha and foo_silk with some enhancements from marc2003's amazing scripts.
Coolest features (and things to do in bold)
  • Album art: cycle through all pictures in folder with mousewheel (WSH Cover Panel Mod)
    Add function that doubleclick on picture returns to currently played track. That's available in the old Album Art Panel
  • Last.fm integration. The warning button is for banning tracks.
    Reintegrate the playback function into the last.fm "chart" tab. That makes the chart tab on the left redundant
  • Show all images in a nice gallery
    Looking for an option to show local pictures and last.fm pictures at the same time
Any suggestions for further enhancements?
The biggest task in the future will be integration of my classical music that requires a whole new tagging (and filter) system. I would basically need two media libraries. 1. Classical Music (two folders), 2. Everything else (5 folders). Best thing would be that I could chose from a drop down menu (or tabs) which media library is active. Anyone has a suggestion on how to do that?
Reply #1654
i've spent the last few days verifying my CD rips against the accuraterip database with cue tools and writing the info to my file tags.
Reply #1655
Nice UI - is this shared by you (as your WSH Panel Mod Scripts)?
Reply #1656
The biggest task in the future will be integration of my classical music that requires a whole new tagging (and filter) system. I would basically need two media libraries. 1. Classical Music (two folders), 2. Everything else (5 folders). Best thing would be that I could chose from a drop down menu (or tabs) which media library is active. Anyone has a suggestion on how to do that? I'd also like to know how to add that volume bar with the dB meter.
How do I get that lastfm chart tab?
Reply #1658
Thanks Pintu
Here's mine. I still need to learn how to change the background of the menu bar and, for some reason, the volume bar has this thick borders I don't know how to remove:
Reply #1659
it's just standard scripting. you can create multiple grouping scripts, and they get applied in the order they are listed. my second one displays the disc number if it exists, then puts the country and genre info over on the right. the right-justification of that second bit of info erases the line that would otherwise appear.
note that a second grouping script will further divide your albums if the data being displayed is not the same for each track, as is the case with the disc numbers for one of the albums in my screenshot. i also use this space for disc labels, and for separating out different versions of singles that have the same title (UK version, maxi, etc).
to those requesting that i upload this - sorry, no. it's just not designed to be shared, and past versions that i've uploaded have tended not to work very well for other users, especially new users...
Reply #1660
I'm using http://hanulbi.deviantart.com/art/fooPlace...anulbi&qo=1 as my skin (first attempt to style foobar
I don't have chinese / japan language support here and like to replace the plugin foo_alsong_lyric.dll with anything else that works (I can see only squares on the menu entries for it's functions and it won't download any lyrics automatically).
Can anyone describe how I can replace it with something that actually works?
Tia,
highend
Reply #1661
Hello Pintu
Your skin really nice. How do i get bio tab & lastfm tab on bottom left. Cause I'm new here. Thanks in advance
Reply #1662
Here's my updated configuration, which I named CANDY-EYE.
Why? There are 3 main reasons I chose this config.
First, I really, really, really, really, really, really…, really hate configs with high contrast colors like everything in black and white or really dark backgrounds with gleaming sparkly elements, which is extremely hurtful to your eyes.
Second, another thing I personally do not appreciate, is having to click on tabs all the time for whatever reason. So, I reduced the amount of tabs to absolute minimum, keeping almost everything on the same “window”. In a nutshell: simple, practical and efficient, at least for me!
Third, absolutely no programming and scripting skills required!
(PS: All the captions are custom titles in Portuguese.)
My updated foo_title, which I did from scratch this time.
(Some programming and scripting skills required.)
Reply #1663
Reply #1665
Reply #1666
mind sharing that album art/now playing panel?
Reply #1668
Something new again. Too much free time lately  Is on deviantart if someone wants.
Reply #1670
[a href="http://postimage.org/image/1ci7xx8o4/" target="_blank"]". I'm also encountering an error message:
"Scripting Engine Initialization Failed (Art Reader by marc2003 / modified by mhe84, CODE: 0x80020101)
Check the console for more information (Always caused by unexcepted script error)."
How can I fix this? Thanks for any help
sin(α) = v sound/v object = Mach No.
Reply #1671
Actually it's just two instances of foobar running to get them in same screenshot. Can you check console what it says regarding the error?
Reply #1672
It is surprising to note how many hours one can spend configuring and fine-tuning the user interface of foobar2000.
Just a simple UI, nothing fancy, but a very smooth look in my opinion.
I saves a lot of space using the Group Info function of EsPlaylist (or $select(%tracknumber%,...,) in any other playlist)
Gonna add multiple genre support soon.
Edit: meh, downscaling of the image makes the spectrum analyzer look very dark. Zoom in to see actual look.
Reply #1673
Reply #1674
