Topic: Simple Surround Disables Subwoofer Feed (Read 3357 times) previous topic - next topic
If I enable simple surround, it disables the subwoofer feed.
I have a SB Live and am using the WinXP SP1 driver with 4 speaker surround sound and a Cambridge Soundworks 5.1 speaker set.
simple surround simply reverses the phase of one of the channels, which simply cancels out any mono info, which is why you get no bass, there's no fix except don't use simple surround
Start/Settings/Control Panel/Sound and Audio Devices/Speaker settings/
Advanced.../Speaker setup/5.1  surround sound setup/Apply/OK/OK
[span style=\'font-size:8pt;line-height:100%\']"We will restore chaos"-Bush on Iraq[/span]
when doing this + chosing simple surround i get no bass too
re-read my post
Simple surround is too simple to avoid killing your sub's signal. Disable it.
