Topic: Biography Text, Album Info, Picture. www.last.fm (Read 74975 times) previous topic - next topic - Topic derived from Re: WSH Panel Mod scr...
Re: Biography Text, Album Info, Picture. www.last.fm
Reply #250
hello kgena_ua
new version tested (with smp 1.4.1):
loading time has improved. (on my old pc)
no more blocking with lastfm-access
"similar artists" now also fits
good work - thank you
Reply #251
hello kgena_ua
if the field with the red border is "header 2", then the colour selection does not work here.
Reply #253
thanks for the explanation
Reply #254
Biography, Albums, Title, Similar artist, Lyrics info
version: 25082021
Spider Monkey Panel.
Add: allmusic.com review.
reload menu "Properties"
UR5EQF. Ukraine
Reply #255
hello kgena_ua
thanks for allmusic - good work.
problem: remap artist + album
allmusic may save differently than lastfm.
suggestion: (maybe you have a better one)
in the very front of the two remap-txt-files insert the separation
lastfm#...
allmusc#...
for this you also need 2 new remap entries in the contextmenue
then select the correct entry when reading.
PS: if you are still adding this,
can you please insert lastfm# (allmusic does not exist yet) the first time, automatically in both files
thanks
Reply #256
I'm sorry I can't reply to private messages yet.
UR5EQF. Ukraine
Reply #257
version: 03052022
Spider Monkey Panel v.1.6.1.
Optimization.
Bugfix.
Improvements.
This version is not compatible with the previous version.
UR5EQF. Ukraine
Reply #258
Hi :) @kgena_ua.
Thanks for good work.
I have one request.Would you please change the default font?
(I know how to change it. from the property.)
Yu Gothic UI
SHURE SRH1840, SENNHEISER HD660S2, SENNHEISER HD 490 PRO, DT 1990 PRO, HiFiMAN Edition XS, Bowers & Wilkins P7, FiiO FT5, 水月雨 (MOONDROP) 空鳴 - VOID, Nakamichi Elite FIVE ANC, SONY WH-ULT900N (ULT WEAR) (made a Upgrade/Balanced Cable by myself)
Reply #259
Air KEN, thanks.
Change Font name: use "Text" menu.
Change Font size: mouse wheel + Shift over selected text.
Change Font сolor: use "Custom Colors" menu.
Сustomize the main menu for yourself using the menu "Main menu setting".
UR5EQF. Ukraine
Reply #260
Thank you for your reply.
I know that.
I have a weak impression, so could you change the default font (Arial)?  ::)
Reply #261
As long as you can do it yourself.
I'm sorry if I understand you correctly. English is not my native language.
UR5EQF. Ukraine
Reply #262
hi kgena_ua
nice to have you back.
Version from 03.05.:
the colour set for "selected text" is not displayed, but that of "text 2".
I personally like it better when there is a blank line before "last.fm/allmusic" and after.
is it possible to read the user settings (font, size, colour, ...) first and then use them in the new script ?
This would save you a lot of work.
greetings
Reply #263
hi kgena_ua
lender1257. Hi.
I'm not going anywhere. Just a difficult time for my country.
The error will be corrected.
Air KEN, Foobar2000 default font will be added.
UR5EQF. Ukraine
Reply #264
Changed the search method from the history list. So I think it will be better.
Example of matching by "BLU"
UR5EQF. Ukraine
Reply #265
What a wonderful evening. And at night you expect the arrival of rockets and bang bang bang  bang.... Such booming sounds. Scary, yes. Scary - no, because we are right.
The worst thing is that children are dying.
UR5EQF. Ukraine
Reply #266
Is it possible to have 2 biography. One for the artist and one for the performer ?
Ex : Mozart and Bernstein as performer .
Thanks .
Reply #268
Hello. Wish your everything are all right now!
Reply #269
Hi everyone,
Is there a way to disable the ability to drag&drop the text around?
This was never answered.  I'd like to know this as well.
Reply #270
I need this as a separate component for 64 bit foobar  :'(
Reply #271
allmusic is showing 'Text not found'. Has something on the site changed?
Reply #272
I don't use this but my own script is borked which means the site has changed.
Tbh, I don't think it's fixable. If you browse the website in a browser and read any review, when you right click and "view source", the content is not there. I guess it's injected after the initial page load by some fancy script but I really have no idea what I'm talking about. I know less than nothing about the "web". :P
Reply #273
Ok, thanks for the info. I just noticed it's also not working on WilB's Bio.
