Topic: Biography Text, Album Info, Picture. www.last.fm (Read 74917 times) previous topic - next topic - Topic derived from Re: WSH Panel Mod scr...
Re: Biography Text, Album Info, Picture. www.last.fm
Reply #125
Hi everyone,
Is there a way to disable the ability to drag&drop the text around? It would be cool if the user could select the text instead of moving it around.
Reply #126
1. The function of "Remap album name" will be fixed.
New metod to remap: Artist(Remaped Artist)*Album*Remaped Album.
2. I want add to this script my script "Get Covers (Artwork)..." to view external and embedded covers.
Sorry. I can not understand.
UR5EQF. Ukraine
Reply #127
Thank you for a great mod.
It works perfectly with local playlist, but when i open online radio (somafm.com/listen for example) it shows red screen with "JavaScript error" and following error message:
"JScript Panel v2.5.3 (Biography, albums, title, similar artist info.www.last.fm. v10062020 by kgena_ua)
JavaScript runtime error:
Object not a collection
File: <main>
Line: 975, Col: 5"
Is it solvable?
Reply #128
On line 971, replace the existing Eval function with this...
function Eval(field) {
    if (!metadb) return "";
    complete_path = metadb.Path;
    directory_path = fb.Titleformat("$directory_path(%path%)").EvalWithMetadb(metadb);
var tfo = fb.TitleFormat("[" + field + "]");
if (fb.IsPlaying && complete_path.indexOf('://') > 0) {
return tfo.Eval();
} else {
return tfo.EvalWithMetadb(metadb);
Reply #129
snotlicker
Solved, thank you!
Reply #130
Biography, Covers, Albums, Title, Similar artist, Lyrics info.www.last.fm.
version "06042021
tested on Wsh Panel Mod v1.5.10.
Add: covers review.  See menu item "Image source".
Choice:
     - external covers;
     - embedded covers, or external and embedded covers;
     - priority external covers;
     - priority embedded covers;
     - cover information
Add: set the default cover image.  See menu item ""Image" - "Default image ".
Fixed: New "Album remap" metod.
Many changes
The Properties menu must be updated.
Check your "_download" folder. Some files will be renamed.
UR5EQF. Ukraine
Reply #131
hi kgena_ua
I have tested your new script a little with jscript-panel v.1.3.2.2
so far i only noticed this (see picture)
Reply #132
another little thing found:
the first header of "similar artists" is missing
this is how it looked in the last version:
Reply #133
Hi, lender1257.
Yes, i changed it. Now first header - similar artist. Second header - years activity.
UR5EQF. Ukraine
Reply #134
hello kgena_ua
i have tested a little again with jscript-panel v. 1.3.2.2
thank you:
- for sorting remap files.
- the change to remap-album also works very well
(duplicate album names can now be distinguished)
this does not fit yet (see picture)
artist=chicago; this will be shown when switched to "similar artists"
please put back "similar artists" as in the previous version.
otherwise you don't know that you have changed to "similar artist".
you haven't changed the other settings (album, most popular albums, ...) either (they are the same as before).
I also think it's clearer.
thank you
Reply #135
lender1257[/b],
I cannot understand why this does not work with jscript-panel.
I tested it with:
https://jsfiddle.net/a8c1z4x6/
everything is ok. The code is written correctly.
I use Wsh Panel Mod v1.5.10.
type=thumb]post_tmp_125956_341f5ff53d74bd49bd768392f4d1b685[/attach]
in any case, there will be an update since I found several bugs[attach
UR5EQF. Ukraine
Reply #136
hello kgena_ua
a few notes what i have done.
properties completely new.
listeners, scrobbles, ... switched off
birthday, active ...  switched on
when loading the data from the database, birthday or active comes up with <P>.
you can recreate this at any time with "refresh". (pic1)
when foobar is restarted + the same artist, the data is read from the hard disk.
now the birthday, active line is missing (pic2)
(no problem for me)
I hope this helps a little bit
Reply #137
Done.
Similar artists are added to history.  Done.
Fix errors (remap function), Done.
Wot else ?
UR5EQF. Ukraine
Reply #138
the test will show ...
please release the new script
addendum: please sort the history_list file
thank you
Reply #140
@kgena_ua
thanks for the changes.
have now installed both panels
foo_jscript_panel-v1.3.2.2 (from 2017)
foo_uie_wsh_panel_mod-1.6.3 (from 2015)
jscript-panel shows in addition to "active + founded" also the members of the band - maybe that's where the error comes from (<P>)
wsh-panel shows only "active + founded - no band members
Reply #141
Check with foo_spider_monkey_panel.
Works fine.
X
An hour with a timer needs someone
UR5EQF. Ukraine
Reply #142
spider-monkey panel:  will try it out soon
question: Similar artists are added to history - why?
Reply #143
"History" is my favorite function. I use it a lot.
For spider-monkey panel need to redo a lot. If there is a need, I can try.
UR5EQF. Ukraine
Reply #144
i think it would be good to have a 2nd panel available. it will be a lot of work. and you always have to change everything 2 times.
maybe it would be better to create your own bio-plugin.  :D
have a nice sunday
Reply #145
version 14042021
tested with Spider Monkey Panel v 1.4.1
This is my first experience with SMP.
UR5EQF. Ukraine
Reply #146
very good work - congratulations !
I noticed:
history file: called "similar artists" 2 times
the entries are duplicated and each entry is 2 lines long
Birthdates and years active are not shown.
Addendum:
after looking at the artist's "most popular albums" and going back to artist, the birthday announcement is also there !!
Reply #147
Hi, lender1257. Thanks.
"History code" has been changed. The old file "history_list.txt" may not be merged with the new version. Delete it.
Function "Years active" while temporarily disabled. Saving is disabled. If you use the old saved data, then it is read.
The main thing is that the script works with Spider Monkey Panel. Working on this panel is a pleasure.
Now I plan to use the JSON format to save the data. I study.
I am interested in how the function of displaying covers works - "Image source : Covers".
UR5EQF. Ukraine
Reply #148
do you mean it is currently deactivated in your SMP-script and will be reactivated with the next update? or am i doing something wrong?
i'm sorry, i don't use the cover-feature.
Reply #149
version  01052021
Fixes.
Added menu item "Cusnom colors".
UR5EQF. Ukraine
