Topic: gogo-no-coda Ver.3.11 (Read 22888 times) previous topic - next topic
A quick question about the lametag option.
With this feature activated, will encspot identify the file as lame 3.88 or some other version of Lame? Or will it identify itself as a gogo file?
If it says that the file is something it is not, that doesn't seem like much of a feature.
It will be identified as Lame 3.92 because Gogo identifies itself like this. This should be solved in new Gogo versions.
The file size should be around 190-200 kbps. I know Lame is pretty fast but I want Xing-speed and Lame quality. Possible? If so, which settings?
Now I don't know anything about Gogo, but if it's true that it's basically an assembler-tuned LAME v3.88, I would guess that it sounds quite similar to LAME v3.89 which I happen to know quite well, because I helped to integrate it into MP3Coder, a Win3x GUI for several DOS tools.
As this was the last version without the --alt-presets, you're stuck to the older presets, if you don't want to use your own command line options. A good overview of these presets and their equivalent parameters can be found with --preset help on the command line (sorry for widening everyone's screen solution in this thread now):
LAME version 3.89 (http://www.mp3dev.org/)
Presets are shortcuts for common or carefully tuned settings.
Several separate collections of preset profiles are available.
Basic- presets covering a wide span of qualities and bit rates
      These presets may be combined with -v for VBR MP3s.
                phone phon+   lw  mw-eu mw-us   sw    fm  voice radio  tape  hifi   cd  studio
--resample           8    11    11    11    16    11    32    24
--highpass       0.125   0.1
--lowpass          3.4     4     4     4   7.6     4    15    12    15    18    18
--lowpass-width      0     0     0     0     0     0     0     0     0   0.9   0.9
--noshort          yes   yes    no    no    no    no    no   yes    no    no    no    no    no
-m                 -mm   -mm   -mm   -mm   -mm   -mm   -mj   -mm   -mj   -mj   -mj   -ms   -ms
-q                 -q5   -q5   -q5   -q5   -q5   -q5   -q3   -q5   -q3   -q3   -q5   -q5   -q5
-b                  16    24    24    24    40    24   112    56   128   128   160   192   256
-- PLUS WITH -v -------------------------------------------------------------------------------
-V                   6     4     3     3     3     3     3     4     3     3     2     1     0
-q                 -q5   -q5   -q5   -q5   -q5   -q5   -q3   -q5   -q3   -q3   -q2   -q2   -q2
-b                   8    16    16    16    24    16    80    40    96    96   112   128   160
-B                  24    32    56    56   112    56   256   112   256   256   320   320   320
EXAMPLES:
a) --preset fm
   equals to: -mj -b112 --resample 32 --lowpass 15 --lowpass-width 0 -q3
b) -v --preset studio
   equals to: -ms -V0 -b160 -B320 -q2
I've cleaned up this table for my own purposes, so it probably looks a bit different from yours, if Gogo will put out something similar at all.
As you can see, your aim is probably best achieved with --preset cd -v, so you would use a variable bitrate with a minimum of 128 and a maximum of 320 kbps, averaging somewhere at 192 kbps. This setting already sounded very good to me, but I did no comparisons with a newer LAME version and --alt-preset standard, because I lost interest in these high bitrates soon thereafter.
A little flaw with the high-range presets is also shown in this table: when not using -v together with --preset hifi, cd or studio, the -q setting is defaulted to -q5 which is of course wrong, because it should rather be -q2, -q1 and -q0. But this is not the case when you combine these presets with a variable bitrate.
ZZee ya, Hans-Jürgen
BLUEZZ BASTARDZZ - "That lil' ol' ZZ Top cover band from Hamburg..."
INDIGO ROCKS - "Down home rockin' blues. Tasty as strudel."
Sorry, but gogo do not offer presets.
Gabriel is quite right, no presets in GoGo.
Reply #30
So I guess Gogo doesn't have any presets?
OK, then he would have to use the command line parameters that make up the suggested CD preset with VBR: -V1 -b128 -B320 -k, or do they also have different names in Gogo?
Whoaaa... I really don't like to fiddle around with command lines. I tried the new gogo together with CDex and I played around with some of the few options available. q=0 and psychoacoustic-box checked. Dunno... I didn't think it was much faster than Lame really. The quality it provided was ok as far as I could tell. I'll probably stick with Lame :-)
And yes, EncSpot v1.0 lets you know when you have a file encoded with gogo. It says something like gogo >3.XX or >3.8X. Can't remember, I deleted the file.
BTW, a file encoded with FastEnc (vbr, not the buggy one) around 180-190 kbps, how good is it compared with Lame? I was baffled how fast it is.
//From the barren lands of the Northsmen
As I already mentioned, I don't know Gogo, but I assume "q=0" probably means the same as in LAME for CBR which is the best but also slowest setting concerning the psychoacoustic model in use. So it's no wonder that you noticed a slow-down with this setting.
Speaking of VBR settings in LAME, "q=0" can be misunderstood, because the command line would afford -V0 for the highest quality VBR setting, but the LAME display would both show "q=0" for this and also "q=2" for the psy model setting. I think this hasn't changed in newer LAME versions, but I'm too lazy to check it right now.
As far as I know, there haven't been any serious listening tests with these codecs at those high bitrates yet, so you would probably have to trust your own ears - which some people obviously just can't do...
Reply #33
Thanx. You're right, in the end, you just have to trust your ears. I actually think the FastEnc provides very good sounding files. I haven't decided which one to use, Fastenc or Lame. I don't think I'll give Gogo another try.
Reply #35
But why don't include the polyphase lowpass filter in GoGo?
It will help to increase the quality..
And maybe some automatic preset should be included too; this because a lot of people still use GoGo and simple presets like -192 or -160 will make easier the encoding.
[ Commodore 64 Forever...! ]
