Topic: Feature request: Undo should also work after sort by column header click (Read 990 times) previous topic - next topic
Hi
Running foobar2000 1.5 on Windows 10 Pro.
On occasion I will click on a column to sort tracks in a playlist (sometimes by accident) and then I would like to be able to revert to my previous (manually) sorted playlist. Undo works perfectly when selecting tracks and sorting using the right click menu/the top drop down menu, but not when using any of the columns right on top of the tracks.
See attached image + webm for reference of my UI.
So my feature request is this: Undo should also work after clicking any of the headers (title, track, number, album, date, etc.).
Re: Feature request: Undo should also work after sort by column header click
It is working on Default UI.
Maybe it is bug / not possible with Columns UI.
Somewhere, there's someone dying in a foreign land
Meanwhile, the world is crying stupidity of man
Tell me why, tell me why
Silly me. I was running an antiquated version of Columns UI. Updated to latest version and the problem is solved. I tend to forget that foobar is put together by many different developers...
Thank you so much for the pointer! Much appreciated. :)
