Topic: f2k crashing when I play audio cds (Read 1103 times) previous topic - next topic
Bother.
I'm running two parallel (and identical) installations of f2k v0.8.3. It's under XP, latest SP and up-to-date. It's righting to a text file which is read by jalcds - though I don't think this is pertinent.
Prob: For some reason, the program has taken to hanging when I try to play audio CDs, on either CD player, on either installation of foobar. The foobar screen blanks out and the whole thing gets stuck in limbo for a couple of minutes. I've killed the prog from task manager a number of times (where it is shown as "not responding") - but I've noticed that if I wait long enough it tends to come back and play.
From what I can tell, this has something to do with freedb lookups - either it's having trouble getting a connection, or doing its searches, or both, or something else.
Any tips? In particular - assuming its a lookup problem - is there any way to get foobar just to go ahead a play - and look up later??
Here's the stuff:
INFO (CORE) : startup time: 281 ms
INFO (foo_freedb) : New CD inserted, looking up titles...
INFO (foo_freedb) : Querying freedb server...
INFO (foo_freedb) : Found inexact match(es)
INFO (foo_freedb) : blues 7d0a770a Zucchero / Spirito Di Vino
INFO (foo_freedb) : Getting data for category blues, discid 7d0a770a
INFO (CORE) : opening file for playback :
INFO (CORE) : location: "cdda://00BF088D,01" (0)
INFO (foo_out_dsound_ex) : Created stream: 44100Hz 16bps 2ch
WARNING (foo_cdda) : cd access error, attempting to reread
INFO (foo_cdda) : reread successful
Best,
Mike
