Topic: MDCT Window (Read 3237 times) previous topic - next topic
MDCT Window
Opus Celt uses Vorbis window (Modified_discrete_cosine_transform)
or this formula is used only from 60 to 180 and from 300 to 420 sample (whole window has 480 samples) as is in Fig. 3 in aes135_opus_celt.pdf ? I have written program which uses this window and results are not so good, the best results give me Dolph-Chebyshev Window (but if this window has features for overlapping?)
MDCT Window
The window formula only generates the smooth transition from 0 to 1, samples 60 to 180 for example in fig 3.
What do you mean with "not so good"? What are the criteria?
"I hear it when I see it."
MDCT Window
Do you know the Princen-Bradley condition for MDCT windows? www.hydrogenaud.io/forums/index.php?showtopic=86431
Chris
MDCT Window
n = 0:119;
L = 120;
w = sin(pi/2*sin(pi*(n+1/2) / (2*L)).^2);
plot(n, w, n, w(end:-1:1), n, w.^2, n, w.^2+w(end:-1:1).^2)
with cheb:
w = chebwin(L*2); w = w(1:L);
MDCT Window
clt_mdct_forward uses (unlike aes135_opus_celt.pdf ) near square window: from 0 to 1/4-delta windows function is equal zero, from 1/4+delta to 3/4-delta is equal 1, from 3/4+delta to 1 is equal again zero, where delta is very small = 1/32.
This follows from: all window has 1920 points, is 1080 non zero points, and 120 is length Vorbis function.
That window generates big side lobes.
KBD is many better than Vorbis i see. Dolph-Chebychev not satisfy Princen-Bradley condition
Princen-Bradley condition:
2. h(k) = h(2N-1-k)
This condition disable non asymmetric windows?
MDCT Window
The condition is for a symmetric window to overlap resulting in a power sum of 1 at each point.
Fig. 3 shows the lengths of the parts of the window pretty clearly.
0-60 = 0
60-180 = Vorbis power-complementary window
180-300 = 1
Alse see https://www.xiph.org/vorbis/doc/Vorbis_I_sp...l#x1-230001.3.2
MDCT Window
Also, the window code used in libcelt is:
 for (i=0;i<mode->overlap;i++)
    window[i] = Q15ONE*sin(.5*M_PI* sin(.5*M_PI*(i+.5)/mode->overlap) * sin(.5*M_PI*(i+.5)/mode->overlap));
