Topic: Retractable Panels (Read 3027 times) previous topic - next topic
Retractable Panels
Hey
Can anyone help me make retractable panels in foobar 2000?
What I want is the panel to pop in when i click a button
Re: Retractable Panels
Popup Panels - separate window.
Panel Stack Splitter - hiding/showing/resizing within the same window.
So I should put a Panel Stack Splitter inside a Popup panel?
No (although you can), these are separate options. Start with popup panels.
I'm already using Panel Stack Splitter
Is there a function to resize the panels on button click or should I stick with showpanel?
It depends on what you're trying to do but:
$movepanel in connection with $init_ps_global, $showpanel_c,  Setglobal: and some conditions. Windowsize: width:height - for resizing. $isvisible_c(caption) for checking the status.
I'm using something like this (just an example, may not be the simplest or the best way  O:) ):
$init_ps_global(VISIBLE,2)
SETGLOBAL:VISIBLE:$ifgreater(%VISIBLE%,2,$if($isvisible_c(Bottomrow),2,1),3) - command part of a button script, this one is for two buttons, three panels. May be simpler like that: $ifequal(%VISIBLE%,1,2,1) but with appropriate numbers
$ifequal(%VISIBLE%,3,
$movepanel_c(Playlist,1,66,$sub(%_width%,2),$sub(%_height%,75)),
$movepanel_c(Playlist,1,66,$sub(%_width%,2),$sub(%_height%,226)))
$ifequal(%VISIBLE%,2,
$showpanel_c(Bottomrow,1),
$showpanel_c(Bottomrow,0))
$showpanel_c(EsPlaylist_row,1),
$showpanel_c(EsPlaylist_row,0))
This might be of some help. It's essentially what michtar is explaining using $init_ps_global and $showpanel.
I actually learned to use PSS from that tutorial. But it just gives instructions for switching between panels. What i wanted to do was have a panel slide in from the side no matter which panel i was viewing. I guess I didnt think of isvisible cos the panel kept blocking the others.
Thanks michtar and jazzthieve. You've been a big help.
BTW..Is there anyway i could get the panel to show when i hover over an area with my mouse?
- For Columns UI  there are some in options in layout - item details -  hidden, auto hide, toggle area etc. I don't use it so you'd have to check it yourself how it works,
- No hover for Panel Stack Splitter AFAIK, you can use hidden-background colour/visible on mouse on button or you might try some conditional showing/hiding panels, based on isplaying, time elapsed or whatever.
- WSH panel mod
I suggest using foo_uie_mega_panel_splitter , combined with wsh_panel_mod scripting to show hide windows on request (button,hover etc).
foo_uie_mega_panel_splitter allows you to move/show/hide your panels anywhere and with any size inside the mega_panel_splitter.
You will need to be familiar with jscript/wsh panel mod scripting.
Also foo_uie_mega_panel_splitter has no documentation.
Here you can download a sample layout if you feel like giving it a try.
https://www.dropbox.com/s/a2ugqhkfq904gyx/megahover.rar?dl=0
Video Preview
Create a portable installation and extract the contents of megahover.rar to that directory.
Edit: typo
