Topic: Where is "Total Time Played" data stored? (Read 2993 times) previous topic - next topic
Title says it all.  I've put going on two weeks in the 3 months since I found foobar and I'd like to see how much I do in a year.
New .cfg file format isn't compatible with old one, tough luck. You can still write the old value down in old foobar2000 if you haven't overwritten/deleted it.
what? you can't make a converter in 2 minutes from old config format to new??? ro you don't want to?....
who | grep -i blonde | date; cd ~; unzip; touch; strip; finger; mount; gasp; yes; uptime; umount; sleep
The way config variables work has changed, old values inside the file can't be simply mapped to new ones.
