Topic: foo_uie_lyrics3 (Read 874116 times) previous topic - next topic
foo_uie_lyrics3
Reply #1201
¿How can I align text to the center of the panel?, not just the top. thanks in advance
foo_uie_lyrics3
Reply #1202
for the wikia lyrics plugin can you please remove the part where it fetches the artist and the song title as well?
Artist : Train
Title : Hopeless
I hopelessly, helplessly, wonder why.....
foo_uie_lyrics3
Reply #1203
someone on the last page asked about that and this was the reply.
2) The info is added by lyrics3, but I like it so I'm not going to remove it, and I cba to put an option in sorry.
foo_uie_lyrics3
Reply #1204
@maXelo:
Have you got any extra lines in the fallback text? Just returns on their own won't affect the number of lines displayed, but if there is a space on the line then that will put it off centre.
@alekksander:
If you don't want it to search for lyrics online then just remove the search sources in preferences.
@slayerming2:
I need more information about your set up in order to help. Which search sources have you got enabled? Have you tried searching for songs in the search dialogue?
Edit:
I've uploaded version 0.4.1 to the repository.
Changelog
- Crash fix when closing batch search during a search
- Changed the output of the batch search when the lyric isn't saved
- Hopefully finally fixed the SSE issues
foo_uie_lyrics3
Reply #1205
@alekksander:
thanks for reply, however i love the fact that its searching online, the thing i don't like is that its looking for it every time when i switch the song, instead of searching when i want it to do so. for example if one of 50 played tracks has lyrics, why it has to look those 49 times if i want lyrics just one this time? i'd love to see checkbox in preferences to search only on demand, and then "search now" field under right click.
foo_uie_lyrics3
Reply #1206
Edit:
Changelog
Yes, my ancient Pentium III accepted version 0.4.1!
Many thanks!
foo_uie_lyrics3
Reply #1207
> Changelog 0.4.1
My old AMD with WinXP-SP3 also work well with 0.4.1
No error in DLL loading.
No error code (3221225501) as previously found in 0.4.0.
Many Thanks,
Phanapa
foo_uie_lyrics3
Reply #1208
@maXelo:
thanks mate
foo_uie_lyrics3
Reply #1210
Hope this is the place to ask (cant find Documentation)
I do auto-save each Sync lyric found in the same directory with Filename Format _Lyric~%tracknumber%
Saves works well and Files are in the Dir
Now the question is:
How to I set "Local File Search" to find the _Lyric~%tracknumber% file that was saved?
I've tried "Custom Filename Format" and "Custom Search path" with things like
_Lyric~%tracknumber%.lrc
or
$directory(%path%,1)\_Lyric~%tracknumber%.lrc
Does not work
Help Please!
foo_uie_lyrics3
Reply #1211
Could you make it not display the lyrics for darklyrics if there are no lyrics? Darklyrics will sometimes have the album/songs listed on their page but not have the lyrics and lyrics show panel will just display a blank page if that happens.
foo_uie_lyrics3
Reply #1212
hello guys,
I have a problem that it started a few days ago. foo_uie_lyrics comp.(0.4.1) can't get lyric over db timestamped 3, why? what should i do? *
foo_uie_lyrics3
Reply #1213
I can confirm the load fail issue with timestamped 3. Hopefully the Vern can fix it or its a temporary issue with the database.
foo_uie_lyrics3
Reply #1214
I have a bug where Foobar will not automatically play the next song after finishing one. When I uninstalled Lyric Show Panel 3, it was back to normal. Checked the options, nothing was checked that shouldn't have been.
foo_uie_lyrics3
Reply #1215
I was just going to post about this. Timestamped 3 is for www.viewlyrics.com which is used by the program/company MiniLyrics. The site is down, gone, or something.
foo_uie_lyrics3
Reply #1216
Hello I just discovered your plugin today and absolutely loved it until I ran into a major problem.  I have a very high standard for how synchronized my lyrics are to the song and as such create custom .lrc files for them, however when I select my .lrc files, the plugin does not seem to be reading it as an .lrc file as it displays my timestamps and tags.  The file is in the same folder as the .mp3 is.
For example, this is part of one of the .lrc files I was in the process of timestamping.
[ti:My Soul, Your Beats!]
[ar:Lia]
[al:Angel Beats! OST-CD1]
[by:DirtyMonk]
[offset:0]
[00:20.83]mezamete ha kurikaesu nemui asa ha
[00:27.17]eri no TAI wo kitsuku shime
kyoushitsu no DOA kuguru to honno sukoshi mune wo hatte arukidaseru
sonna nichijou ni fukinukeru kaze
kikoeta ki ga shita
kanjita ki ga shitan da
furuedasu ima kono mune de
mou kuru ki ga shita
The plugin will simply display everything as shown instead of just the lyrics.  I am not too sure why that is or what is going on.  I would be tremendously grateful if anyone more experienced with this plugin than me could offer help as I really want to replace minilyrics with this plugin.
Edit: I should probably add that I have minilyrics running at the same time and it is reading my .lrc files perfectly.
foo_uie_lyrics3
Reply #1217
Drahciruohz, you have to have the entire file timestamped for it to display properly.
foo_uie_lyrics3
Reply #1219
It's working here.
lyrics.mirkforce.net appears to be down at the moment, but the others are working fine (apart from timestamped 1 and lyrdb.com - but I have only briefly tested them). Does the google search not work?
Can you provide example artist and titles for me to test?
Now I'm using version 0.4.1, and the problem (online search not working) solved. Thank you very much.
Keep up the good work!
foo_uie_lyrics3
Reply #1220
I can't seem to use the scroll wheel on my mouse to scroll through lyrics anymore. It works again temporarily if I go to Panel Preferences>
  • Enable Scroll (Unsynced Lyrics) and then untick it again.
foo_uie_lyrics3
Reply #1221
I'm sort of new to this Lyrics. Once I get the lyrics for the songs I like to listen to, what is a good software player that will sync the lyrics with the music that is being played.
Thank You.
David
( ͡° ͜ʖ ͡°) if you don't stand for something
foo_uie_lyrics3
Reply #1222
Hello, I'm a novice to Foobar. I've installed this popular theme and everything seems to be ok except for the lyrics.
I remember using a theme long time ago that had a feature in which Foobar highlighted the lyric being sang at a particular moment, so I assumed a theme like this would have it too, but it's not working.
So now I'm wondering, maybe they are not synced? Because playing around with the options I stumbled upon the one on the screenshot and according to it, none of the lyrics are synced to the song. If that's the reason why this feature is not properly working, I think I need to set up another server to get the lyrics from. In that case, which one is the "best" one?
foo_uie_lyrics3
Reply #1223
@ vze2mp9g
foo_uie_lyrics 3 has flexible options and integrates with both default ui and columns ui of foobar2000
@ firewater
You should be able to tell if the lyrics are synced by selecting about current lyrics on the right click menu or choose edit lyrics and see if timestamps are present at the start of the lines, e.g. [00:19.13].
For sync lyrics I use in order timestamped 3, then timestamped 2 then lrc123.com with synced only or prefer synced as the lyric search type. I would always recommend saving lyrics in case databases become unavailable.
foo_uie_lyrics3
Reply #1224
@ firewater
The first thing is good to know. Those lyrics where not synced.
Now, how do I add timestamped 3 to the list? I only have 2 and 1.
I only got one song to work with synced lyrics, "I was a fool" by Tegan and Sara. Apparently, It's a single so that explains that someone took the time to sync it, but I think It's weird how I've had no luck with huge artists such as The Smiths or The Sundays. Couldn't find a single synced lyrics and I tried many songs.
I have it set it as "prefer synced" and "query all and pick the best..." (can't read the rest). I've tried it with "only query the next source if no valid lyrics..." but It's basically the same. Is this common?
Also, what is the use for the "avaliable sources" box under preferences? I don't see anything listed there, in case it helps.
