HydrogenAudio
Hydrogenaudio Forum => Uploads => Topic started by: ivailo91 on 2010-08-02 09:31:06
Title: CueMounter released
Post by: ivailo91 on 2010-08-02 09:31:06
CueMounter makes it easier to use audio disc images - .cue and an audio file. It mounts them as a virtual drive and allows you to explore the tracks inside as separate .wav files, play, analyze and recode them, without any intermediate storage.
You can use it to:
Post by: ivailo91 on 2010-08-05 09:07:56
I've just released version 0.5. It contains some bug fixed and can be considered stable. The automatic AuCDTect scanning is also more stable.
A good addition is a portable version, which requires no installation (just unzip). Dokan is still required to be installed, as it work as a kernel mode software.
Both the portable version and the installer, and Dokan, can be downloaded from http://cuemounter.codeplex.com (http://cuemounter.codeplex.com)
Post by: b66pak on 2010-08-05 18:49:25
thanks a lot...
_
Post by: ivailo91 on 2010-08-05 20:17:42
Can you please provide some feedback? Did you find it useful, did you find any bugs? Any feature requests?
thanks a lot...
_
Post by: Alex B on 2010-08-05 20:54:32
Thank you for your release.
Could you please explain how the needed "Dokan library" component works? Will it emulate an optical drive similarly like Daemon Tools, Virtual CloneDrive and some other usual emulators? Is it known to cause any conflicts with other installed emulators? Does it replace any original Windows components? Does it show up as a new SCSI/RAID controller & an optical drive in Device Manager? Does it have a properly working uninstaller? Etc...
I visited the Dokan site and tried to find answers, but obviously the site is not intended for users that use a specific application that is based on the Dokan library.
Post by: Alex B on 2010-08-05 22:10:46
I found this article: http://softwareobjects.net/technology/2010...em-prototype-2/ (http://softwareobjects.net/technology/2010/07/20/dokan-mem-a-filesystem-prototype-2/) . If I understood correctly, a mounted "Dokan" drive emulates a regular storage drive, not a drive with the features of a CD/DVD drive.
If possible, I still would like to know a bit more about its features, appearance, etc before installing it and .NET 4. (I have avoided installing all previous .NET versions until I have really needed them.)
Post by: ivailo91 on 2010-08-05 23:01:21
It emulated wav files mounted in a regular disk drive - it's intended purpose is written in the project description on CodePlex - suit recoding to other formats, scanning with AuCDTect, etc - all operations that are most comfortable with wav files as they are so common. It also contains a ram disk (files hosted entirely in memory) which provides great speed and no disk usage when handling temporary files.
A very key feature is integration with AuCDTect (you can see it in the screenshots). It provides on-the-fly scanning with full multicore support (it will use all the cores your system has) and report track by track the results from the scan.
As for Dokan - I'm using it together with Alcohol, VMWare, DaemonTools - all of which advanced system software and have found any glitches yet - it operates as a kernel mode driver, but it doesn't alter anything - it just hooks there. Therefore, it is simple and safe to deinstall. Dokan installation is required, as it hooks a few things in the kernel.
However, application installation is not required - the installer is available, but optional. You can just download the application zip and use it from anywhere. The application itself doesn't modify the system in any way (not even registry entries).
Also, I'm uploading some screenshots, enjoy.
