Topic: foobar2000 v1.4.1 beta 5 - ReplayGain-scan output files as album does not work (Read 1327 times) previous topic - next topic
When converting an album from FLAC tracks to FLAC image using an converter preset with "ReplayGain-scan output files as album" option checked, it does not save the replaygain metadata in the output image.
Re: foobar2000 v1.4.1 beta 5 - ReplayGain-scan output files as album does not work
Are you using "Generate multi-track files" or "Merge all tracks into one output file"? The latter doesn't support tagging individual songs in the resulting output file, and in fact will discard most of your tracks' tags.
He's using the correct output with internal CUE. I have confirmed the feature is broken at the moment.
Thanks for reporting.
Verified regression since 1.4, fixing for the next update.
We are the bork. Your software bugs will be added to our own. Resistance is futile.
Thanks for the fix. Works as expected in 1.4.1 beta 6.
