Topic: Unable To Switch To Mono Sound (Read 1860 times) previous topic - next topic
I just downloaded Foobar200 version 1.1.10 today and I must say I love its sound and simplicity. Just a problem though: I can't seem to figure out a way to switch to Mono sound (I only have one speaker). I checked under Playback>DSP Manager and found "Convert Mono To Steroe" but no "Convert Stereo To Mono". Anyway to switch it to Mono? Any help would be appreciated. I use Windows XP if it helps. Here is my component list:
Core (2011-12-02 15:07:36 UTC)
    foobar2000 core 1.1.10
foo_albumlist.dll (2011-12-02 15:06:12 UTC)
    Album List 4.5
foo_cdda.dll (2011-12-02 15:06:00 UTC)
    CD Audio Decoder 3.0
foo_converter.dll (2011-12-02 15:05:44 UTC)
    Converter 1.5
foo_dsp_std.dll (2011-12-02 15:06:12 UTC)
    Standard DSP Array 1.0
foo_input_std.dll (2011-12-02 15:05:54 UTC)
    Standard Input Array 1.0
foo_rgscan.dll (2011-12-02 15:05:48 UTC)
    ReplayGain Scanner 2.1.2
foo_ui_std.dll (2011-12-02 15:06:24 UTC)
    Default User Interface 0.9.5
Downmix Channels to Mono.
Steps to use:
  • Do File.Preferences to open the prefs dialog
  • In the "Components" pane, open the "Playback" submenu.
  • Select "DSP Manager"
  • In the rght hand side, select "Downmix channels to mono" and click the button with the left-facing arrow to add the Downmix to the "Active DSPs" pane.
