Topic: Home stereo display (Read 268523 times) previous topic - next topic
Home stereo display
hmmmmm... cannot get it to work properly..... The 7 segment font does not work....
I already installed the 1.1 version fonts in the windows/fonts directory apparently to no avail....
any pointer as to what might be wrong? thanks.
Open Windows\System32\charmap.exe and check if the fonts from the archive are installed.
P.S. You're using version 1.1,it's better to use V 1.1.1 instead.
Favourite artist:CD-R
Favourite album:700MB
Home stereo display
Does anybody know what font contains this symbol?
Home stereo display
I think i've seen it in Arial Unicode MS, but are not sure.
Home stereo display
Russell777, could you please keep the 1st post up-to-date with the latest version? Makes it a lot easier to find it that way. And you can avoid confusion with troubleshooting, probably.
Life is Real...
(But not in audio :) )
Home stereo display
This is a good idea! I got a problem though... for some reason glass.png isn't loading. Yes, I have it in my images directory. PNG buttons work fine so the libs are okay. I have the trackinfo_mod from the 17th which is the latest. Any ideas? Everything else looks good and works fine.
Home stereo display
Reply #33
Great work.
I'm on Windows 2000 and do not have "franklin gothic medium", the system seems to use kinda arial then, which is bigger.
The glass/png stuff does not seem to work here on my 2000 system? Same as with custom buttons, this will be not possible?
EDIT: It works.
rodan321, you probably did the same mistake like me. The images directory belongs to where your foobar2000.cfg is, this may be %appdata%\foobar2000\.
Home stereo display
Reply #34
That was it, figured it out right before I refreshed and saw your post. I saw a little blurb on the wiki. Thanks!
Home stereo display
Reply #35
Open preferences->General if you have the "Enable user support" box checked,you should place the image
inside your profile directory (...Application data\foobar2000\images\glass.png).
2 Squealer It might be your problem too.
Home stereo display
Reply #36
BTW, I think the realtime vbr display is useless, as the panel just refreshes once a second. I'd rather use %__bitrate%
Home stereo display
Reply #37
Tried this and the font does not appear to be installed.... odd.... it's in the fonts directory:
[a href="http://img235.imageshack.us/my.php?image=bugtrackinfo2ek2.png" target="_blank"]
Home stereo display
Reply #38
Rating, mood, placount, last played
By rating do you mean the %rating% tag,that has been edited manualy,or rating value calculated by some
code ("Hotness","Hot or not")?
For me, regular rating and hotness would be great.
Home stereo display
Reply #39
from the rating tag could you provide some form of symbol fitting with the rest of the symbols as Id love to see what you come up with
My Name is Sean and I'm here to leech off your genius.
Home stereo display
Reply #41
Do I need something special to get the glass overlay.  The path is correct and I have the png libraries in the foobar directory, but i'm not seeing the glass effect
thanks
- FLAC/200GB external
- AAC 128 vbr/local
- iPod Nano 2G 8GB
Home stereo display
Reply #42
Install the font as you have to install fonts in windows: Visit the fonts folder and choose the install fonts dialog from the file menu.
@LanceUppercut: See the rodan321 postings above.
@Thread starter: Add precise info about where to put the image and how to install fonts.
BTW can someone provide the franklin gothic medium? On w2k I do not have it. (if this is the font of "LOCAL DRIVE, STREAMING, REMOVABLE", my system shows arial)
Home stereo display
Reply #43
And is there an easy way to create left padding?
Oh and sometimes it shows the track number, sometimes it doesn't... and I don't really know why. :-\
Home stereo display
Reply #44
Thats awesome. Can we get a filefront link or upload section?
Because rapidshare no worky for NTL users
hi
Home stereo display
Reply #45
Just give me a link to the desired storage.
Home stereo display
Reply #47
awesome work russell
Thank you! I've posted new version (V 1.2) See the first post.
I've added some of the features,you guys asked for,but i'm uncertain about the others.
Some of you asked for a "mood" value to be displayed,but as i understand it's not restricted to contain
specific sort of data and every one uses it in his own way,so symbolic display is not possible,unless you tell me
what do you write to this tag.Also i would like to pull a version with color schemes (for now it was monochrome)
so please post images of your home stereo's displays to give me some inspiration.Enjoy
Home stereo display
Reply #48
This is some awesome work you've done Russell777, I'm loving this stereo display thingy!
we was young an' full of beans
Home stereo display
Reply #49
This is the greatest thing ever! I am not really into track info panel but your code got me hooked up.
