Topic: RESYNC (Read 2247 times) previous topic - next topic
RESYNC
OK, I did a search and came up dry on this.  I keep getting the following: "INFO (foo_input_std) : mpeg stream resync successful" when playing some tunes.  The search said the buffer for this has been increased from 128K to 1 meg.  Cool.  But what the devil does the message mean and what can I do to prevent this and its accompanying hiccup in sound??
Nov schmoz kapop.
RESYNC
The MP3 file itself is slightly corrupt. A re-sync occurs to compensate for the confusion. If the buffer is increased, the file is read further ahead of real time to repair errors before they are encountered, though there will still probably be a skip in the sound.
Not foobar2000's fault at all!
RESYNC
Thanks for the heads-up.  I believed it was not a FB2K problem.  I was also pretty sure t here was an encoding problem in the MP3 file.  This is what the error message indicated to me but I wanted to see someone who knew comment.  I will increase the buffer to the max.
Thanks again.
Nov schmoz kapop.
