Topic: Running Foobar in Linux (Read 593603 times) previous topic - next topic
Re: Running Foobar in Linux
Reply #625
Really?  That's hardly justified.  I don't claim to be an expert, I am just reporting my honest experience.  It took some fiddling to get to IE9, as you know (because IIRC you helped me get there).  These are low-powered netbooks, if you recall.
If you are saying that it should be possible to implement 32-bit v2 etc etc, then I'll create a restore point and see if I can (at some point - not right now).
What's this got to do with Wine?
Reply #627
Anyone start having a black screen and 100% CPU usage when opening foobar2000 lately? wine version 8.3.
Reply #628
wine-8.3 (Staging) here no problem.
But one time foobar started as a black screen for me.
I close it, move the theme file from profile. Start again. Close. Replace the new theme file crated for the old one, and it starts normal again.
But this time didn't show 100% CPU so maybe could not be related
Reply #629
There are some redraw issues, but that's a minor annoyance. The real showstopper is a crash bug caused by library scan. Only happens when it encounters some non ASCII characters. There is a Wine bug filled for this, but no activity on that yet.
Reply #630
Unchecking the "Allow window manager to ..." options in winecfg seems to fix it for me, at least temporarily. 100% CPU is not always the case, maybe was related to something else the other day.
Reply #631
I don't think that both case were related too. In fact, I never have 100% CPU usage when the window starts black, but I point it down because it can help somebody with the same behavior.
As it only happens from time to time and randomly it not worth the cost of disallow the window manager to draw decorations and manages the window.
At least in gnome that supposed to forgot about alt+tab, no entry in windows bar list, etc. and the window always on top. Not so practical.
Less costly to do the trick when it happens, that anyway is very rarely.
But it has a benefit, in this situation the full screen visuals work.
