Topic: Stream Data Radio (Read 1385 times) previous topic - next topic
Stream Data Radio
I have some Radios that transmit data relating to the author, title, etc... which are spaced out by this symbol ~
This does not allow the correct distribution and visualization of the data.
Is it possible to do something?
Re: Stream Data Radio
Hi there!
@ApacheReal
For the Biography script (by @WilB ), add to the file advanced_radio_stream_parser.js the following:
Spoiler (click to show/hide)Similarly for other streams of this radio station.
Thanks for MC2 ;)
Hi there!
@ApacheReal
Thanks for MC2 ;)
I understood that it is possible, but I have not been able to do it.
I use TAGS.
I entered from line 94:
case 'https://edge.singsingmusic.net/mc2nudisco':
case 'https://edge.singsingmusic.net/singsingweb005':
item = item.split('~');
artist = (item[0] || '').trim();
title = (item[1] || '').trim();
breaks;
But it did not work.
I add that I see four data:
Artist
Title
Album Title
Year
ApacheReal,
Could you try the working file in the attachment? Save your file first.
As you know this file is located here: \foobar2000\profile\foo_spider_monkey_panel\package_data\{BA9557CE-7B4B-4E0E-9373-99F511E81252}\
What does the console display while listening to the MC2 stream?
Thank you for your availability and patience, but unfortunately it doesn't work.
Log /console follows
m-TAGS:: REFERENCED FILE: https://edge.singsingmusic.net/singsingweb006 [0]
Track couldn't be analyzed
No, that doesn't work either.
original item ["Bliss", "Manvantara", "Quiet Letters", "2003"]
artist Bliss
title Manvantara
artist Bliss
In console though it looks correct
Is in playlist view which appears incorrect
The parser only displays the transformation in the biography panel. It doesn't alter other elements like the playlist view.
in console it's right after you add:
        //mtag match $info(@)
        const mtag = $.eval('$info(@)', focus, ignoreLock);
        switch (mtag) {
At this point I wanted to understand if you see the correct data flow.
The correct artist and title is working and displaying ONLY in the Biography Panel as I explained above.
You should notice that the Biography panel is now showing the artist.
The data is not used in other panels, except by the Find and Play script.
Question :
I write in Jscript Panel 3 :
                var item_artist = tfo.artist.Eval();
                var item_title = tfo.title.Eval();
                item_artist = item_artist.split('/');
                item_title = item_title.split('/');
it works fine and remove '/' . But i need to remove also '~' ????
                item_artist = item_artist.split('/' + '~')  NOT WORKING ? HELP
In sample Text Display (custom title)
$replace($replace(%title%,:,),~, - )
Fix name.....
item_artist = item_artist.split(/[\/~]+/)
HTH.
Alessandro
EDIT:
item_artist = item_artist.split('/~')
should work as well, if item_artist is something like 'text1/~text2/~text3'
In streaming radio stream, this instruction:
$left(%title%,$sub($strchr(%title%,~),1,))
displays the title correctly, but removes the artist's name as seen in the image:
Is it possible to implement the string in such a way as to make the title and artist appear correctly and eliminate the rest?
Thank you
