Topic: How to re-adjust/re-size a UI element width with column UI ? (Read 995 times) previous topic - next topic
Hi there
I reinstalled foobar 1.6.16 few times today, due to some issues with the 64bit v.2.0.
I have 2 backed up folders (%appdata%, and Program files (x86)), and usually I just copy and paste them every time I need to go back to previous favorite settings.
Now, I don't remember what I have changed in the settings ,but I can't resize elements' with anymore, they are blocked (i.e.: playlist view, VU meter and all the panels).
I recall that with the DUI it was a matter of right click, un ticking the "lock width" or "lock height" options and then I could resize the borders of elements on the app.
I'm using Columns UI, and the panels are unlocked, but this is the only thing I can see who relevant for this resizing.
Please see screenshot attached, with the context menu while pointing on the borders of the VU meter for example.
Thanks in advance
Re: How to re-adjust/re-size a UI element width with column UI ?
It might be a case of going to Preferences -> Display -> Columns UI -> Layout -> Misc tab and making sure you have a Divider width of >0.
I'd actually quite like an option for this within the interface itself because i frequently turn the dividers on and off for this reason, not wanting them aesthetically but wanting them functionally.
Hope that solves your problem.
THANK YOU SO MUCH!!!
That worked amazing, I wasted so much time, eventually I uninstalled everything, reinstalled v1.6.16, started from scratch (almost one by one,according to settings from a portable version) , and then I updated to version 2.0 (32 bit, because of components I like to use).
Now everything looks and works fine and better I hope.
I recall now that a year ago I was looking for a way that I won't be able to change the width and height  of elements, but I totally forgot how I did it.
Thanks again for you great help!
