Topic: fb2k not playing AAC stream (Read 996 times) previous topic - next topic
https://d10kxd8jv78zl6.cloudfront.net/main.m3u8
The above radio URL streams as AAC. Foobar2000 does not play the stream.
The console has this message repeatedly:
error decoding AAC frame #54: Unsupported format or corrupted file
AIMP & SMPlayer have no problems playing it.
Any suggestions on what I might check or what decoders I might be missing?
Added on edit:
I am using fb2k 1.6.16
Re: fb2k not playing AAC stream
Foobar 2.0 x64 doesn't play it by default, but I got it to play using FFMPEG and FFmpeg Decoder Wrapper:
https://www.foobar2000.org/components/view/foo_input_ffmpeg
https://github.com/GyanD/codexffmpeg/releases (use files fom "bin" folder. 64-bit only, so will not work on 32-bit OS)
I added *.AAC to the wrapper config. If your OS is 32-bit, you need to find 32-bit builds of FFMPEG.
Thank you for checking it.
After installing the FFmpeg Decoder Wrapper component the stream still does not play for me. Are there maybe additional changes I need to make in the properties section? (Please see the screenshots)
As a test I installed a 64-bit portable fb2k ver.2 and after installing the FFmpeg Decoder Wrapper component in it I tried the stream and it did not play.
Read out from the console of 64-bit portable fb2k ver.2:
[2023-05-02 12:30:53.831] Components loaded in: 0:00.015640
[2023-05-02 12:30:53.831] Configuration read in: 0:00.001411
[2023-05-02 12:30:53.831] foobar2000 v2.0 x64 [portable]
[2023-05-02 12:30:53.925] Playlist #1 loaded in 0:00.000308
[2023-05-02 12:30:53.956] User Interface initialized in: 0:00.115748
[2023-05-02 12:30:53.956] FFmpeg version: 6.0
[2023-05-02 12:30:53.956] Startup time : 0:00.156836
[2023-05-02 12:30:53.956] Library initialized after 0:00.157337
[2023-05-02 12:30:57.176] Opening track for playback: "https://d10kxd8jv78zl6.cloudfront.net/main.m3u8"
[2023-05-02 12:30:57.647] error decoding AAC frame #1: Unsupported format or corrupted file
[2023-05-02 12:30:57.647] error decoding AAC frame #2: Unsupported format or corrupted file
[2023-05-02 12:30:57.647] error decoding AAC frame #3: Unsupported format or corrupted file
[2023-05-02 12:30:57.647] error decoding AAC frame #4: Unsupported format or corrupted file
[2023-05-02 12:30:57.647] error decoding AAC frame #5: Unsupported format or corrupted file
[2023-05-02 12:30:57.647] error decoding AAC frame #6: Unsupported format or corrupted file
[2023-05-02 12:30:57.658] error decoding AAC frame #7: Unsupported format or corrupted file
[2023-05-02 12:30:57.658] error decoding AAC frame #8: Unsupported format or corrupted file
[2023-05-02 12:30:57.658] error decoding AAC frame #9: Unsupported format or corrupted file
[2023-05-02 12:30:57.658] error decoding AAC frame #10: Unsupported format or corrupted file
[2023-05-02 12:30:57.658] error decoding AAC frame #11: Unsupported format or corrupted file
[2023-05-02 12:30:57.658] error decoding AAC frame #12: Unsupported format or corrupted file
[2023-05-02 12:30:57.658] error decoding AAC frame #13: Unsupported format or corrupted file
[2023-05-02 12:30:57.658] error decoding AAC frame #14: Unsupported format or corrupted file
[2023-05-02 12:30:57.658] error decoding AAC frame #15: Unsupported format or corrupted file
[2023-05-02 12:30:57.658] error decoding AAC frame #16: Unsupported format or corrupted file
[2023-05-02 12:30:57.658] error decoding AAC frame #17: Unsupported format or corrupted file
[2023-05-02 12:30:57.658] error decoding AAC frame #18: Unsupported format or corrupted file
[2023-05-02 12:30:57.658] error decoding AAC frame #19: Unsupported format or corrupted file
[2023-05-02 12:30:57.658] error decoding AAC frame #20: Unsupported format or corrupted file
[2023-05-02 12:30:57.658] error decoding AAC frame #21: Unsupported format or corrupted file
[2023-05-02 12:30:57.658] error decoding AAC frame #22: Unsupported format or corrupted file
[2023-05-02 12:30:57.658] error decoding AAC frame #23: Unsupported format or corrupted file
[2023-05-02 12:30:57.658] error decoding AAC frame #24: Unsupported format or corrupted file
[2023-05-02 12:30:57.658] error decoding AAC frame #25: Unsupported format or corrupted file
[2023-05-02 12:30:57.658] error decoding AAC frame #26: Unsupported format or corrupted file
[2023-05-02 12:30:57.658] error decoding AAC frame #27: Unsupported format or corrupted file
[2023-05-02 12:30:57.658] error decoding AAC frame #28: Unsupported format or corrupted file
[2023-05-02 12:30:57.658] error decoding AAC frame #29: Unsupported format or corrupted file
[2023-05-02 12:30:57.658] error decoding AAC frame #30: Unsupported format or corrupted file
[2023-05-02 12:30:57.658] error decoding AAC frame #31: Unsupported format or corrupted file
[2023-05-02 12:30:57.658] error decoding AAC frame #32: Unsupported format or corrupted file
[2023-05-02 12:30:57.658] error decoding AAC frame #33: Unsupported format or corrupted file
[2023-05-02 12:30:57.663] error decoding AAC frame #34: Unsupported format or corrupted file
[2023-05-02 12:30:57.663] error decoding AAC frame #35: Unsupported format or corrupted file
[2023-05-02 12:30:57.663] error decoding AAC frame #36: Unsupported format or corrupted file
[2023-05-02 12:30:57.663] error decoding AAC frame #37: Unsupported format or corrupted file
[2023-05-02 12:30:57.663] error decoding AAC frame #38: Unsupported format or corrupted file
[2023-05-02 12:30:57.663] error decoding AAC frame #39: Unsupported format or corrupted file
[2023-05-02 12:30:57.663] error decoding AAC frame #40: Unsupported format or corrupted file
[2023-05-02 12:30:57.663] error decoding AAC frame #41: Unsupported format or corrupted file
[2023-05-02 12:30:57.663] error decoding AAC frame #42: Unsupported format or corrupted file
[2023-05-02 12:30:57.663] error decoding AAC frame #43: Unsupported format or corrupted file
[2023-05-02 12:30:57.663] error decoding AAC frame #44: Unsupported format or corrupted file
[2023-05-02 12:30:57.663] error decoding AAC frame #45: Unsupported format or corrupted file
[2023-05-02 12:30:57.663] error decoding AAC frame #46: Unsupported format or corrupted file
[2023-05-02 12:30:57.663] error decoding AAC frame #47: Unsupported format or corrupted file
[2023-05-02 12:30:57.663] error decoding AAC frame #48: Unsupported format or corrupted file
[2023-05-02 12:30:57.663] error decoding AAC frame #49: Unsupported format or corrupted file
[2023-05-02 12:30:57.663] error decoding AAC frame #50: Unsupported format or corrupted file
[2023-05-02 12:30:57.663] error decoding AAC frame #51: Unsupported format or corrupted file
[2023-05-02 12:30:57.663] error decoding AAC frame #52: Unsupported format or corrupted file
[2023-05-02 12:30:57.663] error decoding AAC frame #53: Unsupported format or corrupted file
[2023-05-02 12:30:57.663] error decoding AAC frame #54: Unsupported format or corrupted file
[2023-05-02 12:30:57.663] error decoding AAC frame #55: Unsupported format or corrupted file
[2023-05-02 12:30:57.663] error decoding AAC frame #56: Unsupported format or corrupted file
[2023-05-02 12:30:57.663] error decoding AAC frame #57: Unsupported format or corrupted file
[2023-05-02 12:30:57.663] error decoding AAC frame #58: Unsupported format or corrupted file
[2023-05-02 12:30:57.663] error decoding AAC frame #59: Unsupported format or corrupted file
[2023-05-02 12:30:57.663] error decoding AAC frame #60: Unsupported format or corrupted file
[2023-05-02 12:30:57.663] error decoding AAC frame #61: Unsupported format or corrupted file
[2023-05-02 12:30:57.663] error decoding AAC frame #62: Unsupported format or corrupted file
[2023-05-02 12:30:57.663] error decoding AAC frame #63: Unsupported format or corrupted file
[2023-05-02 12:30:57.663] error decoding AAC frame #64: Unsupported format or corrupted file
[2023-05-02 12:30:57.789] error decoding AAC frame #1: Unsupported format or corrupted file
[2023-05-02 12:30:57.789] error decoding AAC frame #2: Unsupported format or corrupted file
[2023-05-02 12:30:57.789] error decoding AAC frame #3: Unsupported format or corrupted file
[2023-05-02 12:30:57.789] error decoding AAC frame #4: Unsupported format or corrupted file
[2023-05-02 12:30:57.789] error decoding AAC frame #5: Unsupported format or corrupted file
[2023-05-02 12:30:57.789] error decoding AAC frame #6: Unsupported format or corrupted file
[2023-05-02 12:30:57.789] error decoding AAC frame #7: Unsupported format or corrupted file
[2023-05-02 12:30:57.789] error decoding AAC frame #8: Unsupported format or corrupted file
[2023-05-02 12:30:57.789] error decoding AAC frame #9: Unsupported format or corrupted file
[2023-05-02 12:30:57.789] error decoding AAC frame #10: Unsupported format or corrupted file
[2023-05-02 12:30:57.789] error decoding AAC frame #11: Unsupported format or corrupted file
[2023-05-02 12:30:57.789] error decoding AAC frame #12: Unsupported format or corrupted file
[2023-05-02 12:30:57.789] error decoding AAC frame #13: Unsupported format or corrupted file
[2023-05-02 12:30:57.789] error decoding AAC frame #14: Unsupported format or corrupted file
[2023-05-02 12:30:57.789] error decoding AAC frame #15: Unsupported format or corrupted file
[2023-05-02 12:30:57.789] error decoding AAC frame #16: Unsupported format or corrupted file
[2023-05-02 12:30:57.789] error decoding AAC frame #17: Unsupported format or corrupted file
[2023-05-02 12:31:22.598] Shutting down...
If it should matter somehow I am using Windows 11 64-bit
I checked all the boxes in the wrapper config (maybe it's HLS and RTMP?)
The obvious: 64-bit ffmpeg with 64-bit foobar.
I hear Spanish?
File name : main.m3u8
Folder name : https://d10kxd8jv78zl6.cloudfront.net
File path : https://d10kxd8jv78zl6.cloudfront.net/main.m3u8
File size : 214 B
Last modified : 2023-05-02 13:00:14
Attributes : remote
Sample rate : 44100 Hz
Channels : 2
Bitrate : 107 kbps
Codec : AAC
<CODEC_LONG_NAME> : AAC (Advanced Audio Coding)
I used ffmpeg 6.0
Components loaded in: 0:00.003887
Configuration read in: 0:00.000460
Playlist #0 loaded in 0:00.000134
User Interface initialized in: 0:00.036627
FFmpeg version: 6.0
Startup time : 0:00.051248
Library initialized after 0:00.051374
Launching ffprobe:
"C:\Users\User\Downloads\foobar2000\ffprobe.exe" -of xml -show_format -show_streams -show_chapters -hide_banner "https://d10kxd8jv78zl6.cloudfront.net/stream-48.aac"
Launching ffmpeg:
"C:\Users\User\Downloads\foobar2000\ffmpeg.exe" -i "https://d10kxd8jv78zl6.cloudfront.net/stream-48.aac" -map 0:0 -f w64 -acodec pcm_f32le -
It is obviously something on my end that is faulty. I had a copy of ffmpeg and ffprobe on hand that I tried, but I also tried with the builds from the Github page you posted.
I also tried with moving those required ffmpeg and ffprobe exes to different places on the computer, not just off the c:/ drive root (I guess that is the way it is expressed?).
I am stumped so I am going to back off from it for awhile. When I want to play that particular stream I will use AIMP.
I greatly appreciate the help you gave.
I did get as far one time as to installing the FFmpeg Decoder Wrapper Component, but I did not know about having to add *.AAC to the list.
And I will add that that particular radio station does have a habit of perodically changing its stream URL.
Just to see what would happen. I put the below in a .bat file and ffplay.exe played the stream. I know that doesn't prove or fix  anything, except to perhaps show that part of the ffmpeg suite plays it.
ffplay https://d10kxd8jv78zl6.cloudfront.net/main.m3u8
Edit: fixed typo
It could be a misconfigured server/encoder at their end, or a splitter/source/demuxer filter bug in foobar?
Did you try checking all the boxes in the wrapper config?
Yes I tried it with all of the file formats selected
One time after I tried it after I said I was going to back off, the fb2k console had a line in it stating something about ffmpeg: Patch Welcome then the line after that just continued with the Unsupported format or corrupted file message.
Under Preferences, Playback, Decoding, I moved the wrapper to the top of the list.
It's still playing for me, in Spanish, which I don't understand.
YOU DID IT. Now I hear Spanish too. Thank you, again and again.
That's great! Glad it worked :D
Problem acknowledged, thanks for reporting.
The cause seems to be MPEG-TS stream disguised as .aac due to a server configuration error. Actual audio is served with wrong both extension and mime type.
It will be worked around in next foobar2000 update.
foobar2000 v2.1 preview 2023-05-09 clean portable install (nothing added or removed)
The stream now plays instantly.
