Topic: Foobar2000 v2 Resume Playlist suggestion (Read 327 times) previous topic - next topic
I noticed that foobar2000 v2 already saves your position in playlists without any additional plugins. It would be nice if it were easier to resume a playlist after playing a different playlist. Highlighting the last played track in playlists would be very helpful, and a "Resume Playlist" context menu command as well. Right now, the only way to resume a playlist after playing a different playlist is to select the playlist, close foobar2000, reopen foobar2000, and press play.
Re: Foobar2000 v2 Resume Playlist suggestion
You could enable Playback follows cursor from the the Playback menu. Now when you switch playlist and press the Play button, it should start playing from the focused track.
If you don't want to enable that option, you could try this component I released a few weeks back.
https://marc2k3.github.io/component/play-track/
